  1. Aug 9, 2019 at 5:57 PM
    xtwillie
    xtwillie Well-Known Member
    Kevin
    03 Tacoma
    Installed King 2.5 700lb Front Coilovers with SPC Upper Control Arms, Replaced lower ball joints, Installed ARB Rear Leaf Springs. Installed a set of Pro Comp 1069 16x8 with 285/75r16 BFG KO2. The ride is night and day difference now i can hit and driveway entrance and barely even feel it. Love this suspension, so glad i went with this setup. Shoutout to WheelersOffRoading
    https://www.instagram.com/p/B04RAFAAWNU4xBJ5Rpuk1DCL-_BQVbJouWBJBI0/
  2. Aug 9, 2019 at 6:06 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    You replace the bulb or the entire housing? Must have some big hands if just getting the bulb...
    JasonLee and Running Board Man like this.
  3. Aug 9, 2019 at 6:29 PM
    eon_blue
    Azusa, CA
    Always nice to learn the grinding coming from your wheel was just the brake shield against the rotor and not a wheel bearing taking a sudden crap
    Apparently I bent that sucker good last night when doing my outer tie rods, sounded pretty bad lol
    Running Board Man and cruiserguy like this.
  4. Aug 9, 2019 at 6:39 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Hell yeah I've heard those things scream like a shrill banshee and caught me totally off guard. Scared the bajeezus outta me cause I couldn't fathom what wtf it could be. Anywho, yeah they can be loud af
  5. Aug 9, 2019 at 6:41 PM
    eon_blue
    Azusa, CA
    I was only going to/from work on city streets so it sounded like a rotational grinding/hum....got home and took the wheel off and was pretty clear what was happening
    cruiserguy[QUOTED] likes this.
  6. Aug 9, 2019 at 6:47 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    @Wulf
    You didn't tell me the pellets are also a tasty snack
    chrslefty, CS_AR and xtremewlr like this.
  7. Aug 9, 2019 at 6:55 PM
    Speedytech7
    Yup, pulled em many times, they get stuck over the years, make sure you follow the FSM and get it in position and have at it.
  8. Aug 9, 2019 at 6:58 PM
    Speedytech7
    I've always just used a deep well socket and an extension. Are you sure you're looking at the right thing?
  9. Aug 9, 2019 at 6:58 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Is it the opposite of a laxative? Plugs all the holes...
  10. Aug 9, 2019 at 9:46 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    ^^ this. I haven’t had to remove anything to get to my bulbs, nor to install and plug in my ULTIMATE HALOGEN UPGRADE harness. And I wear XL size gloves.
    cruiserguy likes this.
  11. Aug 9, 2019 at 11:08 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Saw a neighbor pour two boxes of McCormick ginger into a leaking 1947 Ford truck radiator. I thought he was crazy at first. Then the leak stopped.
    I think Subaru cooling system sauce contains a lot of ginger since its an all-natural ingredient.
  12. Aug 9, 2019 at 11:14 PM
    Speedytech7
    It's not one of my more proud repairs attempts haha. But if it lasts for a week I'll be grateful
    cruiserguy and CS_AR[QUOTED] like this.
  13. Aug 9, 2019 at 11:15 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    gotta do what you gotta do
  14. Aug 10, 2019 at 8:46 AM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    Today was transmission fluid change. Last week was xfer case, week before was rear diff. Next week will be front diff. At some point gotta do the carrier bearing. Good bit of play in it and the truck has a wobble that I hope it will fix.
    Not sure when, if ever, this fluid was changed. Didn’t look horribly discolored but there was some blackness in it...
  15. Aug 10, 2019 at 9:10 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Had this truck about a month. The previous owner installed a nice kenwood radio and it had a usb plug hanging out under the dash to plug your phone, etc in. I didn’t like it visible so I got an extension with a mount and moved it into the lower center console out of sight. I loaded my music on a flash drive and leave it plugged in but I can plug my phone in it if I need to charge it. Here’s the extension I ordered. https://www.amazon.com/gp/product/B01NAMU8KY/ref=as_li_tf_tl?ie=UTF8
  16. Aug 10, 2019 at 2:12 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    That saying about taking everything but the kitchen sink?...bought the Tacoma a sink.
  17. Aug 10, 2019 at 2:27 PM
    Adude
    Adude Well-Known Member
    Pnw
    04 Double cab
    So since I eliminated Abs and removed the sensors. Do you have to use the tone ring to keep correct spacing. Or can you just use the seals for the 01-04 non abs
  18. Aug 10, 2019 at 2:55 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    They are like 800 lumen so they need a decent heat sink.
  19. Aug 10, 2019 at 3:46 PM
    itsmerandy
    itsmerandy Well-Known Member
    Kentucky
    1. Changed out my rear diff breather.
    2. Installed BPV relocation bracket
    3. Installed air intake
    Ignore the wet stuff - its Fluid Film.
    20190810_124607.jpg 20190810_124600.jpg 20190810_125108.jpg 20190810_180625.jpg
  20. Aug 10, 2019 at 5:38 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    V6 Triton brake/tail light.
    SwampYota, sandsloth and itsmerandy like this.
