  1. Aug 10, 2019 at 5:47 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Those look pretty damn bright and the pic is even in daylight. Are they really that bright? Easy visibility of you from afar, I'm sure
  2. Aug 10, 2019 at 6:57 PM
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    IMG_20190810_154934
    by Cory Bechtold, on Flickr
    Started this project yesterday, but it's finally starting to take shape today. Hopefully I'll finish it up tomorrow before I get my driveshafts redone.
  3. Aug 10, 2019 at 7:38 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    you should see the number of balancing weights they applied to the inner wheel on one of mine when I had it redone
    it seems very excessive! the tire has a potential defect then if too much weights?
    CS_AR[QUOTED] likes this.
  4. Aug 10, 2019 at 7:45 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Nice! Best mod ever!
    cbechtold[QUOTED] likes this.
  5. Aug 10, 2019 at 7:48 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Its just wrong when a tire takes that much weight in two places.
    Wulf and GQ7227[QUOTED] like this.
  6. Aug 10, 2019 at 8:09 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i will try to get a pic of what they did to mine that i don't understand
  7. Aug 10, 2019 at 11:18 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    FINALLY took the time to replace the driver side door checker (Part# 68620-04010). Door stays open again o_O
    new and old
  8. Aug 11, 2019 at 12:44 AM
    Funkensour
    Funkensour Well-Known Member
    Vincent
    Columbus, OH
    2004 Prerunner SR5 Tacoma 2WD
    scion xb seat swap/ 3rd gen 4 runner swap in progress
    Interested in the.seat cushion.swap. do you.have part # or link?
  9. Aug 11, 2019 at 4:21 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    this is potential source of the squeaky doors that i have off and on
    yesterday no squeak! it depends on the climate change (i think)
    but it may be a tad 'loose' as you once mentioned
    was removing the inside door paneling difficult or is there an easier way to get those door checks out?
  10. Aug 11, 2019 at 6:15 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    How much of a pita was this? My door wont stay open if slightly inclined
  11. Aug 11, 2019 at 6:56 AM
    Wulf
    rock raisin
    I need to do this, mine is practically a polished strip at this point lol
    Area51Runner[QUOTED] and GQ7227 like this.
  12. Aug 11, 2019 at 7:00 AM
    Wulf
    rock raisin
    Looks good to me, when I changed mine for the first time it came out darker than that :bananadead:
    Have you noticed an improvement with the redline? Before I switched it was a real PITA to get into 1st gear and it was pretty much impossible if temps got below freezing
  13. Aug 11, 2019 at 7:14 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    its not bad to remove at all, once you can get the door paneling stuff off safely, unless there is a spot to reach inside without panel removal?
    i took one off a taco at a salvage lot but the paneling had already been removed!
    picture of mine, just slip the black plastic cover off, a couple of nuts and then undo the part by the door hinge and then it pushes back inside the door
    i cannot comment about this item keeping door opened on an incline...i cannot recall mine EVER being able to do that?? but i will check it out next time i am on an incline
    ? it is just to prevent a wind gust while the door is open (or something to that effect) from hyper extending and doing damage to body panelS?
    Fernando[QUOTED] likes this.
  14. Aug 11, 2019 at 7:17 AM
    Cobra
    Cobra Well-Known Member
    Round Rock, TX
    2002 4WD TRD DBLCAB
    OME 883
    GQ7227 likes this.
  15. Aug 11, 2019 at 7:29 AM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    Yeah man, usually a little bit of a pain to get into Reverse. Smooth as butter now.
    CS_AR likes this.
  16. Aug 11, 2019 at 7:35 AM
    CS_AR
    MT90 is a staple around my place. It smoothed out some copper syncros on one of my transmissions. I use it for all kinds of touch and go applications.
    SwampYota[QUOTED] likes this.
  17. Aug 11, 2019 at 9:02 AM
    CS_AR
    Just ordered upper and lower ball joints with (8) bolts for the lowers. Might as well change out the ball joints since everything else has been replaced except the rack. Also, the split nut for the center bearing install with the two thin TSB washers.
  18. Aug 11, 2019 at 10:27 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    July 17, 2019.
    We're running the IDBDR! (intro post)
    July 18, 2019.
    ...And then - in the distance - a cloud of dust. Unsure what it was, we continued on. Eventually, the source became clear - dual combines churning through a field of wheat. Like any kid at heart, I've got a soft spot for big machines like this, and having never seen a combine at work up close, I couldn't help myself but to climb out of the truck to stand on top of the @Cascadia Tents RTT to snap a few photos.
    The grin on the combine driver's face said it all - even with some weirdo standing on top of his truck, snapping photos - he too was enjoying the experience.
    Read the whole story and see all the photos at IDBDR Pt. 2 - Across the Snake River Plain
    From IDBDR Pt. 2 - Across the Snake River Plain
    to read this (and future stories) in your inbox
    https://adventuretaco.com/subscribe
  19. Aug 11, 2019 at 10:59 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Don't use this anywhere were it freezes. Or if you do, make sure you drain and fill with antifreeze before it freezes.
    That stuff WILL freeze and split your radiator. I promise you.
    Ask me how I know :anonymous:
    And I live in California... It freezes much harder where you are than where I am.
  20. Aug 11, 2019 at 11:04 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Did some shit yesterday
    Adude, BYJOSHCOOK, alphabravo and 8 others like this.
