  1. Aug 11, 2019 at 11:08 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    are those the original LBJs at ~226k miles?
    CS_AR[QUOTED] likes this.
  2. Aug 11, 2019 at 11:44 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Its been used with anti-freeze. I think it does nothing with anti-freeze. Looks like its for racers that just run plain water. Waste of money with anti-freeze.
    Running Board Man likes this.
  3. Aug 11, 2019 at 11:49 AM
    CS_AR
    I suspect the LBJs were changed at some point in the past. The boots are still intact. Though I can't tell when they were changed. The upper and lower control arms look to be fairly recent. I don't want to take any changes with unknown LBJs. The upper ball joints have been on for a while.
  4. Aug 11, 2019 at 11:49 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Wasn't bad at all. Broke two clips on the door panel but was able to salvage one of them. Really an easy process. For anyone interested, below is the process for 2002-2004. Other 1st Gen years may vary...
    I skipped step 2 and just twisted the door handle and pushed it back through the panel as I removed it.
    NOTE:
    you do not need to remove the tweeter.
    As for the door check, to remove -
    grab here and slide the cover off towards you
    Remove the door cover - this kind of snaps closed on one side, be careful as this is how you'll remove it from the checker.
    Remove the three marked in yellow above (10mm). Slide the checker back through the door and remove from the hole where the speaker is. Once the door checker is loose, BE CAREFUL as to not allow the door to open forward - nothing holding it with the checker removed.
    Install the new checker by sliding it back through the opening in the door, secure the two nuts and bolt it to the frame (blue thread locker on the frame bolt). Reinstall the covers, door panel. Done.
    If above is confusing in any way or still have q's on the removal process, reference these two vids:
    Not going to remove arm rest - remove panel only
    https://youtu.be/y_tR2Dv6iW0
    Door check removal only (ignore the silicone grease part) -
    https://youtu.be/ARo-la_2xU8?t=315
  5. Aug 11, 2019 at 11:59 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    do you have the all hard plastic door panels?
    i don't have tweeter speaker so one less thing lol
  6. Aug 11, 2019 at 12:02 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    You are correct. You use it with just plain water. That's why you don't want to use it where it freezes, when it freezes.
    I ran it in my F150 Lightning... but forgot to drain it and fill with antifreeze one winter... and I had to replace the radiator after we got a good freeze.
  7. Aug 11, 2019 at 5:00 PM
    MamaTried81
    MamaTried81 Well-Known Member
    Oakland, CA
    '02 TRD Tacoma 4x4 V6 XtraCab SR5
    Took my anti sway bar off.
    Oh and this :D
  8. Aug 11, 2019 at 5:21 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    What are you doing!? You can't do that without a snorkel?! :D:cool:
    Pyrifera and MamaTried81[QUOTED] like this.
  9. Aug 11, 2019 at 5:25 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
  10. Aug 11, 2019 at 5:49 PM
    cruiserguy
    Elijah
    SEKS
    Did you mean to have some text with this pic you posted?
    GQ7227[QUOTED] likes this.
  11. Aug 11, 2019 at 6:15 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    A lot of you guys 'liked' my kitchen sink post; what's in the back of my mind is, where do I stow it away when I'm out on the road heading out to my next spot?
    I'm thinking I can leave it behind the front seats (access cab)? I have limited space and I'd like to keep that space for stowing garbage bags for food waste, etc. in bear country, as well as my ice chest.
    I have a bed rack, so the contents of the truck bed are always exposed to the elements. I recently bought a plastic bin to put items like sleeping bags/etc. inside of but that space is all occupied.
  12. Aug 11, 2019 at 6:17 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Whatever you do, test different spots and their ease of access. Im on a trip right now, and putting all my clothes/bedding at the front of the bed (camper shell) has been a big pain. Shouldve put dishes up there.
  13. Aug 11, 2019 at 6:22 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    If I'm in non-bear territory, my method is -
    Against the bed of the truck, towards the cab, is my power tank (offset to the drive side), big ice chest in the center, and fuel jug (offset to the passenger side).
    Ice chest is held by a ratchet strap against the bed.
    After those items, a large plastic bin with bedding, and inside is a smaller container with a few dishes, paper plates, napkins, aluminum foil, etc.
    Next to that is another but smaller ice chest meant for foods. Next to that are my 2-3 foldable chairs, and canopy.
    I can access the ice chest like I had to a few weeks ago while being stuck on Highway 1; bed rack provides enough clearance to open the ice chest and it's easy to reach from either side of the bed.
    I'm just not sure if the sink should remain outside on the fold out table while at camp or not since it has a built in battery. For ease of access, I may just leave it inside the truck.
  14. Aug 11, 2019 at 6:36 PM
    taco57
    taco57 Well-Known Member
    Jeff
    Columbus Ohio
    2003 Tacoma SR5 4X4 2.7 5 speed
    I installed a new Denso fuel pump and all new rubber gaskets on the top of my fuel tank. Got rid of the emissions code P0456 and P0440. Fuel pump just because I was in there. I'll post my old one for free if I think someone would want it. It worked fine could go 100K more miles, who knows.
    cruiserguy likes this.
  15. Aug 11, 2019 at 6:38 PM
    MichaelsTacoma
    MichaelsTacoma Well-Known Member
    Michael
    Sacramento
    00 TRD 4wd e-locker
    donahoe racing coilovers, Camburg upper control arms, rear bilstein 5100, wheelers leaf pack, wheelers super bumps, 33 inch Cooper discovere stt pros
    Did some wheeling this weekend.
    A73AE7A3-BE38-4454-9D07-887D73CC980F.jpg 09135F25-B01D-48CB-B6B3-45D1F6700654.jpg
  16. Aug 11, 2019 at 6:46 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Garage cleaned after yesterday's Mod Day âś…
    Hood is back on the truck and aligned âś…
    Old passenger wheel bearing pressed out âś…
    New passenger wheel bearing pressed in âś…
    Now to go re-assemble the passenger side so my truck has 4 wheels again.
    turbodb, xtremewlr, CS_AR and 3 others like this.
  17. Aug 11, 2019 at 6:56 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    yes, i was currently in discussion with the truck about this piece
    what year did this type of panel first appear?
  18. Aug 11, 2019 at 7:18 PM
    MamaTried81
    Oakland, CA
    Taking calculated risks makes things a little more interesting :cheers:
  19. Aug 11, 2019 at 7:50 PM
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    Built some shifters for the dual cases.
    IMG_20190811_130501
    by Cory Bechtold, on Flickr
    Pulled the transfer-case for final assembly before I finished working on the truck today. Only need to figure out the electrical stuff at the moment. Rewiring the front diff disconnect to a switch in the cab. If anyone would happen to have a 4wd computer wiring diagram available, that'd be great. :anonymous: Driveshafts go in tomorrow to get redone. Should be driving the old girl again sometime mid-week.
  20. Aug 11, 2019 at 7:57 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Only 20% hack this time. Much better than the 100% Velcro I've been running the last week or two. At least now the thing won't slide into the dash when I press a button. :laughing:
    CS_AR, chuckers and SwampYota like this.
