  1. Aug 13, 2019 at 10:10 AM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    There was a guy Bamatoy or something like that but he got the permaban recently.
  2. Aug 13, 2019 at 10:16 AM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Perma-Ban!! lol what did he do? that sucks. I was hoping to grab a kit
  3. Aug 13, 2019 at 10:22 AM
    RobZ9132
    RobZ9132 Well-Known Member
    Somewhere in NC
    2004 Double Cab TRD
    Hmm.. may need to order one.. Looks like it could come in handy!
  4. Aug 13, 2019 at 10:27 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Maybe it's time for me to enter the market since I need to build one for my truck.
    Sucks that all of their posts were deleted as well with the permaban. Here's another member posting about the kit they received so you can at least see the photos there. https://www.tacomaworld.com/threads/stage-1-full-battery-harness-replacement.315939/
  5. Aug 13, 2019 at 10:29 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    There is lots of controversy on TW about Bamatoy. Building your own kit is very satisfying.
  6. Aug 13, 2019 at 10:42 AM
    Dan8906
    Daniel
    Concord, California
    Time is everything. Ill put it off to the winter and just build one then.
  7. Aug 13, 2019 at 10:54 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Yup basically all of this. Realistically building my own kit was easy enough, and I have already use the crimper tool for many other things. Used it to make my own harness for the winch, bringing a fuse panel the the bed, and will eventually use it for building a dual battery setup.
    Digiratus and jubei like this.
  8. Aug 13, 2019 at 11:51 AM
    Phessor
    Phessor Well-Known Member
    That explains why I never heard back from him about his high output alternator.
  9. Aug 13, 2019 at 12:23 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    That's what first gear, low range is for.
    Running Board Man and GQ7227 like this.
  10. Aug 13, 2019 at 1:38 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    That's to slow
  11. Aug 13, 2019 at 1:47 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Would be saving your pads though.
  12. Aug 13, 2019 at 2:38 PM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    OME 3" lift 881 coils, Dakar's 33" General Grabber AT2's TG low profile front bumper
    Ordered a napa rebuilt master cylinder, good or bad idea? OEM was pricey
    Running Board Man likes this.
  13. Aug 13, 2019 at 4:44 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    … popcorn on this one as I need to know also ….
    :spy:
    Lux[QUOTED] likes this.
  14. Aug 13, 2019 at 5:19 PM
    yeahkkyle
    yeahkkyle Well-Known Member
    Kyle
    PA
    2002 Tacoma TRD Offroad 3.4L 5spd
    I sprayed the fittings the day before a few times with PB blaster then just prior to breaking loose I used some Trizol Creep Penetrating Oil I got from work. 19mm and 14mm line wrench and they came right off. Just snugged them back up normal and no leaks. I had more trouble removing the bracket than getting the lines off. If it was replaced before, the previous guy half stripped the front nut.
  15. Aug 13, 2019 at 5:20 PM
    TacoYankee
    TacoYankee Well-Known Member
    Spotsylvania, VA
    2024 Trailhunter
    I had a heck of a time getting it to not leak. Wasn’t stripped, just had to be really tight.
  16. Aug 13, 2019 at 5:26 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Running Board Man and jubei like this.
  17. Aug 13, 2019 at 5:27 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Pics or it didn't happen.
    How'd you like the RTT?
  18. Aug 13, 2019 at 5:34 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    per @cruiserguy rec on best trim dressing/protectant to use I started the 1st treatment with this 303 Aerospace, it may require several apps to get back to 'near like-new' :cool:
    it has some associated streaking with it as it does not air dry well
    my OCD disorder desires the black trimmings on my tacoma to be sharp and the weather, sun, age has taken tolls onit
    i do not wish to replace all rubber trims unless they get torn, etc. just one spot on the driver door sil that has to be watched with TLC (that bastard mechanic left a friggn footprint onit last time i let somebody drive it)
    this will be the 4th product I have tried ... hoping this one has best results that will not wash off with rain, touchless wash, etc.
    I will let you know the deets on using this $9 bottle if you are at all interested
    if you have a better product you swear by (like @cruiserguy almost did lol) post 'em up
    the change of appearance in parts of the cowl i have done are good so far, ... i will try to expose it to elements for verification on durability
    peace!
    :proposetoast: cheers to all of the 1st gen 'unicorns' out there, wherever you may be! :proposetoast:
    chrslefty and CS_AR like this.
  19. Aug 13, 2019 at 8:21 PM
    Omicron6
    Omicron6 Well-Known Member
    Northern California
    03 SR5 DC TRD 4x4
    Some cool LED lights and a switch... King 2.5s - Front/Rear Total Chaos UCAs OME Dakar leafs
    Got some long boi shocks from a fellow TW member. Now gotta get em on!!
    Anyone wanna buy some King OEM replacements for their rear...huh... huh... anyone... anybody?
  20. Aug 13, 2019 at 8:25 PM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    Must be nice
