  1. Aug 14, 2019 at 5:04 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Not unless you stop and sit there for awhile. Water doesn't just rush in unless your windows are down.
    No. Positive pressure is coming out of your exhaust keeping the water from going in. If you were to stall and try and restart you might have problems.
    No
    I'd have two hydrolocked engines if I didn't have one. I agree they look stupid but it's saved me a couple thousand dollars.
    The only electrical issues I've had from flooding my truck are related to the airbag system. I still have not gotten around to figuring it out yet. Bearings are a different story though. Seized both tensioner pulleys and water pump bearing started weeping. First time I submerged it my wheel bearings took a shit shortly after. Drain your trans, tcase and diff fluids if you sit in water up to the door for long.
  2. Aug 14, 2019 at 5:08 PM
    Reh5108
    Idaho
    The stock airboxes are designed so that if a bit of water enters it it sits at the bottom and isn't sucked into the rest of the intake. A small amount of water isn't going to harm your engine, it may actually steam clean your cylinders.
    Edit: This may not be the case with the 3.4 but the 2.7 could probably hold a quart of water before it started to touch the filter.
    Running Board Man likes this.
  3. Aug 14, 2019 at 5:36 PM
    Captain Magma
    Captain Magma Well-Known Member
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    Kings and desert pinstripes
    Got the Methods mounted today with Meso TRD caps. Was planning on doing rear suspension first but a great deal popped up on these. Rear suspension is up next
  4. Aug 14, 2019 at 6:56 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Quoting myself below since some of us have actually been in water over the hood.
  5. Aug 14, 2019 at 7:13 PM
    AKsavanaman
    AKsavanaman Well-Known Member
    Lower 48 :( U.P MI
    01' Xtra Cab TRD, Kings, JBAs, Dakars and 295's on F5
    Kings, JBA's, Dakars, Prinsu Rack, ARB, Trail gear sliders... and rust
    Uhhmm... the internet told me that a snorkel will add 25hp due to "ram air" affect... pretty much like having a $200 supercharger. I mean i haven't dyno'ed it yet...but Causin Joe says he can feel the 25 horse increase in his pants! Joe and the Internet... ALWAYS right!
  6. Aug 14, 2019 at 7:17 PM
    AKsavanaman
    Lower 48 :( U.P MI
    Finished my Monstaliner paint job about a week ago... didn't turn out half bad!
  7. Aug 14, 2019 at 7:19 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Monstaline for the win
    cruiserguy and Yetimetchkangmi like this.
  8. Aug 14, 2019 at 7:29 PM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    So today while gong up an incline I hit the gas pretty hard. I got a pretty violent slam that I’m guessing is axel wrap from the extra power with the supercharger. This is even with Deavers. I’m planning on a traction bar to keep that from happening again. Anybody ever have that happen?
  9. Aug 14, 2019 at 7:32 PM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    This guy gets it.
  10. Aug 14, 2019 at 7:44 PM
    AKsavanaman
    Lower 48 :( U.P MI
    :rofl:funny thing is that I've got one
  11. Aug 14, 2019 at 7:58 PM
    Shortman5
    Supercharged TRD
    I was worried someone would mention the trans. Im pretty sure it downshifted before the slam. And I drove around a little while after and it was shifting just fine. Hopefully nothing broke.
  12. Aug 14, 2019 at 8:04 PM
    eon_blue
    Azusa, CA
    My experience with axle wrap in my last Tacoma (automatic) was that it happened when coming to a stop not when accelerating, but I guess it could go either way
    GQ7227 and Running Board Man like this.
  13. Aug 14, 2019 at 8:23 PM
    Shortman5
    Supercharged TRD
    It all happened pretty fast. Going up a on ramp while rolling on the throttle it down shifted to a low gear. I got going way too fast so I let off. Somewhere between the downshift, high RPM S/C whine and letting off the throttle there was a pretty startling slam.
    I guess it possible the downshift to high RPM, 80lb 285s, incline, soft springs, and extra power was enough to wrap the springs with a harsh rebound.
    I’ve had this happen once before after hammering the throttle then letting off. I believe it was with my stock springs though which wrapped at every stop and go.
  14. Aug 14, 2019 at 9:18 PM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    OME 3" lift 881 coils, Dakar's 33" General Grabber AT2's TG low profile front bumper
    The guys at Napa ordered the wrong master cylinder despite me having the one I needed directly in front of them when it was ordered. Waited a week for nothing. Got one on rock auto coming in Friday.
    GQ7227 likes this.
  15. Aug 14, 2019 at 10:31 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Went outside to play -
    Then I went to my buddy's shop; he suggested I go with a Frontrunner water tank for my water supply. It'll sit well with the mount attached to the bed where it sits in this pic-
    Phessor, BYJOSHCOOK, GQ7227 and 6 others like this.
  16. Aug 15, 2019 at 1:41 AM
    Robmonster117
    Robmonster117 Well-Known Member
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    I like the wooshy noises my snorkel makes with a supercharger :notsure:
    jubei and Fernando like this.
  17. Aug 15, 2019 at 6:27 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    would this be something that would happen in MT
    i got a little bit stuck in the sandy muck 15ft from the mighty Mo river the other day and did not force my way out of that mess, i just felt the rear grab in the sand, stopped and put it in 4lo and crawled right on out like a champ.
    but was that 'thuddish' feeling in the rear getting stuck (in 2wd) what is called or referred to as axle wrap
    you have had two Tacomas!?
  18. Aug 15, 2019 at 6:35 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    sharp truck
    rope hooks look good!
    Kwikvette[QUOTED] likes this.
  19. Aug 15, 2019 at 6:58 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Don't walk around without shoes on you'll get a cold!
    Ah that's a good song
    Digiratus likes this.
  20. Aug 15, 2019 at 6:59 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I knew someone would get the reference.
