  1. Aug 16, 2019 at 1:02 PM
    eon_blue
    Azusa, CA
    I need to order a new stake nut before I do my carrier bearing...thought I might just re-use the old one since the videos I watched showed them reusing it, but on here I've heard that it sometimes gets fubar'ed when you take it off. Worth the peace of mind to just pick up a new one I guess
    CS_AR[QUOTED] likes this.
  2. Aug 16, 2019 at 1:04 PM
    eon_blue
    Azusa, CA
    Takes some guts to leave the windows up and doors shut when you jump out to film your truck crawling along the side of the road, haha. I'd be afraid it would lock itself and I'd have no way to get in it or stop it for that matter.
    Really jealous of that mod, especially since I've got a 5spd...super low range would be awesome for crawling in 1st gear without worrying about stalling or frying my clutch.
    Silver02Taco and jubei like this.
  3. Aug 16, 2019 at 1:16 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Installing 4.56s 3rd member into the rear tonight, does anyone have tips with dealing with the E locker? Or is it just a matter of pulling the actuator and everything else is straightforward? I was told by my local forum crew that I may need to manually lock the locker before removing the 3rd. Tips?
  4. Aug 16, 2019 at 2:07 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Mine was screwed up. Couldnt un stake it so I just hit it with an impact gun and messed it up on the process. I think it was $3ish at my local dealer.
    SR-71A and eon_blue[QUOTED] like this.
  5. Aug 16, 2019 at 2:46 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Yep. Already replaced the rack bushings. At some point, I need a new rack due to a small leak.
  6. Aug 16, 2019 at 2:47 PM
    CS_AR
    I got the TSB washers. Now to figure out where they go. LOL
  7. Aug 16, 2019 at 2:48 PM
    eon_blue
    Azusa, CA
    TSB washers? For the carrier bearing?
  8. Aug 16, 2019 at 2:52 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I reused mine on the 99, think that’s all I need to say
    eon_blue[QUOTED] likes this.
  9. Aug 16, 2019 at 3:49 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Thats some first gen bling bling right there.
  10. Aug 16, 2019 at 3:53 PM
    1997tacomav6
    Denver
    Gas tank holds how many gallons? Mine is 16
    mateo_roberto likes this.
  11. Aug 16, 2019 at 3:56 PM
    Wulf
    rock raisin
    I don't push it past 220 since I dented my gas tank :rofl:
  12. Aug 16, 2019 at 3:57 PM
    eon_blue
    Azusa, CA
    My 04 xtra cab holds 18
    1997tacomav6[QUOTED] likes this.
  13. Aug 16, 2019 at 4:01 PM
    1997tacomav6
    Denver
    So you have the Taco lean when the tank is full on the gas tank side?
  14. Aug 16, 2019 at 4:02 PM
    eon_blue
    Azusa, CA
    Yep, mostly just in the rear. Kind of annoying but it's only really noticeable with a full tank. Debated putting a small shim or spacer on that side to even it out but haven't committed to that idea yet.
  15. Aug 16, 2019 at 4:03 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Most aftermarket suspensions account for this. Even my cheapo leafs have different packs for drivers vs. passenger. Actually I think the drivers rear sits a tad higher than the passenger even with a full tank. Maybe a few years from now I wont be able to tell.
  16. Aug 16, 2019 at 4:47 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    O come on! Only 8k more! You can do it!
    Clutch start cancel it. The factory electric crawlbox is incredible!
    . 18.5 unless it's a 5 lug or been modified by rocks...
  17. Aug 16, 2019 at 4:57 PM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    I drove it on some dirt,
    I found a sweet campsite with it,
    and I put some seat covers on it.
    Omicron6, Phessor, chrslefty and 8 others like this.
  18. Aug 16, 2019 at 5:07 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    o_O
    (brother?)
  19. Aug 16, 2019 at 5:35 PM
    jubei
    NoCo
    Stuff. Also things.
    Nice! It’s a good bumper and I think it matches my Addicted front bumper pretty well. I’m going to pull the trigger on one of these soon, though. Much better clearance, and I really like how the cut edge of the bedside is covered by the bumper wings.
    BYJOSHCOOK, xtremewlr, CS_AR and 2 others like this.
  20. Aug 16, 2019 at 5:51 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Let me know when you'll be scrapping the current tube bumper. I may be interested...
    jubei[QUOTED] likes this.
