  1. Aug 21, 2019 at 10:41 AM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    Is that the kobalt toolbox ?
  2. Aug 21, 2019 at 10:46 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Same thing, Craftsman. Bought it at Lowe's. Says it fit 2005 and up but I put it on here. It only hangs over about a 1/2" on both sides. I wanted the 12" wide instead of the 20" so I wouldn't lose more bed space than I had to.
    FLBAdrian[QUOTED] likes this.
  3. Aug 21, 2019 at 10:53 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    My blast in bucket kit never worked properly because I don't have a compressor that put out 7 CFM at 80 PSI. It doesn't seem like a lot but most hobbiest's compressors do not put out that much air.
    Thank you :thumbsup:
    Running Board Man likes this.
  4. Aug 21, 2019 at 10:59 AM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    Hehehehe
  5. Aug 21, 2019 at 11:00 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Lace sells studs. No need for them unless your going to push some power.
    Running Board Man and Wulf like this.
  6. Aug 21, 2019 at 11:38 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    Even with regular head bolts I haven't heard of anyone lifting the heads on a 5VZ with a boosted engine :notsure:
  7. Aug 21, 2019 at 12:12 PM
    FLBAdrian
    Adrian
    Hanford Ca,
    Too many…
    Yeah I have the kobolt one for it a few years ago I think I have the 12” wide B81377DE-0208-4B30-BFDB-6B492855C885.jpg
  8. Aug 21, 2019 at 2:52 PM
    1997tacomav6
    Denver
    Got the OEM radiator body mount parts installed today
    Here are the part numbers just in case
  9. Aug 21, 2019 at 3:12 PM
    Taco86er
    Taco86er Well-Known Member
    Bay Area
    04 Dbl Cab TRD
    3” Eibach/Bilstein Lift, TG Low Pro Bumper, Hella 700’s, HID Retrofits, Hella Supertones, Deckplate, Grey Wire, Shell w/Thule Rack and Basket, LED Shell Lighting, Rear Bumper LED Pod Reverse Lights, Tinted Tails
    Damn that mountain range in the far distance looks gnarly!!!
  10. Aug 21, 2019 at 3:23 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    The Tetons are impressive!
  11. Aug 21, 2019 at 3:29 PM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    In my life I have made that statement many times!!
  12. Aug 21, 2019 at 5:15 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Replaced my tail gate.
    Hoping to do my rear shock relocation mod sooner than later.
    FLBAdrian likes this.
  13. Aug 21, 2019 at 5:25 PM
    Daddo
    Daddo Well-Known Member
    Paul
    2004 Doublecab Tacoma 4wd
    Full Total Chaos Long Travel
    One of our favorite places, In The Summer/Fall. Winter is probably great for skiing, which I don't do any more due to knee replacements and have no desire to camp in the snow any more.
  14. Aug 21, 2019 at 5:33 PM
    NewEnglandSmoke
    NewEnglandSmoke Member
    2004 Xtracab 4x4 2.7
    I broke my tacoma :( rusted out spring cup finally gave out over a pothole today... (driver side)
    Luckily I have 5100s and my OME 880s should come in tomorrow! Figured this was an appropriate time to make my first post :wave: Ill come and update when the new gear is on. Im hoping the 880s will come close to leveling my ride out...
  15. Aug 21, 2019 at 5:34 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    880's gave my 2.7L extended cab 1.75" of lift.
  16. Aug 21, 2019 at 5:35 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Kinda.. Many years ago I bought the predecessor to this unit from Harbor Freight. Its more like a small suitcase with the nozzles
    I use it the most because its easy to reload. If something happened to that unit, I would get one of these to replace it.
    Then I have one of these units that I haven't used much because its a pain to reload.
    The real secret to success with these blasters comes from this compressor.
    I buy black diamond media at Tractor Supply for $8.99 a bag. .
  17. Aug 21, 2019 at 5:40 PM
    CS_AR
    Very similar results with a 3.4L Prerunner. Its just what I wanted in lift.
  18. Aug 21, 2019 at 6:32 PM
    FLBAdrian
    Adrian
    Hanford Ca,
    Too many…
    Ewww
  19. Aug 21, 2019 at 6:53 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    Just the most basic of maintenance on mine today. Oil change, Mobile 1 synthetic, filter, OEM D3, grease all the shafts, new air filter. Oh, and even treated her to a new drain plug gasket!! Tomorrow I am planning to make a sun shield for my winch. I notice a distinct fading on the exposed synthetic winch line. I am guessing those areas would be the first to fail. So going to cut and bend some aluminum flashing to cover it.
    GQ7227 likes this.
  20. Aug 22, 2019 at 7:11 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    July 24, 2019.
    ...Armed with the absolutely beautiful book Backcountry Roads--Idaho, by Lynna Howard, we had a few extra waypoints along the Lolo - in addition to the couple provided by the BDR creators - that we decided to check out. They were of course slight detours off of the route, but even a day behind schedule, we were happy to take the time to experience the area fully.
    See what the Lolo has to offer in IDBDR Pt. 8 - Driving the Lolo Motorway
    catch up on the whole story
    [part 1] [part 2] [part 3] [part 4] [part 5] [part 6] [part 7] [part 8]​
