  1. Aug 22, 2019 at 12:17 PM
    eon_blue
    Azusa, CA
    I remember the 'clack clack clack clack' around corners usually turned heads
  2. Aug 22, 2019 at 12:18 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I wouldn't recommend one in the rear for street use. It's unnoticeable in the front on the street though.
    6mm smaller on the spindle side the rest of the axle is the same.
  3. Aug 22, 2019 at 12:23 PM
    Phessor
    Phessor Well-Known Member
    Bob
    1998 TRD XTra Cab
    Stuff
    When I had my Jeep TJ, I had a Detroit locker in the rear and a Lock Right in the front with no manual hubs. I loved it in mud and on the rocks, but living up north it was horrible on hard packed snow.
    I swapped an E-Locker into my old Hilux and had a Spartan in the front with manual hubs. I had the same results with hard packed snow, not good to be locked front and rear in that environment.
    Than being said, if I was to do it all again, I would go with a selectable locker front and rear.
    chrslefty and eon_blue like this.
  4. Aug 22, 2019 at 12:34 PM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    I have what ever you have I think.
    eon_blue[QUOTED] likes this.
  5. Aug 22, 2019 at 3:17 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Yep. Explains why the siphon pickup style that I have for the blasting cabinet really doesn't work. I may sell the blasting cabinet or donate it to charity. It's just taking up space in the garage that I don't have today.
  6. Aug 22, 2019 at 3:50 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    I drove my truck today, ran good!!
    lucky13don and GQ7227 like this.
  7. Aug 22, 2019 at 4:38 PM
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    No molding is going to fix that. Your truck has been aftermarket repair painted with the windshield in place. Hell, you can see the overspray on the molding. A larger molding will cover it, but the paint will continue to flake off. The only way to prevent it is to remove the windshield/molding and prep/paint the area.
    GQ7227 likes this.
  8. Aug 22, 2019 at 4:40 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Well, I thoroughly destroyed that rear axle seal removing it.
    :anonymous:
    Things are going well, if slowly, otherwise. Second side should be much quicker I'd imagine.
    m3bassman and xtremewlr like this.
  9. Aug 22, 2019 at 4:57 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Received my long awaited injectors. They were surprisingly pretty clean when comparing before and after.
    Before, right after removing from the motor and just a wipe down.
    After they were rebuilt. Haven't even taken them out of the bags yet.
    And finally the spec sheet showing before in GRAY and after clean/rebuild in WHITE. I'm impressed since they have 324k miles on them.
    Probably won't see any difference on the truck but it's good to know they are fresh again. Might start putting them back in tonight. Truck will be running again this weekend for sure.
  10. Aug 22, 2019 at 5:05 PM
    1997tacomav6
    Denver
    Who ever did the paint job did a marginal job with the over spay shown
    Gen1FTMFW and GQ7227 like this.
  11. Aug 22, 2019 at 5:25 PM
    Gen1FTMFW
    Hehe, marginal is a very polite way of putting it.
    GQ7227 and 1997tacomav6[QUOTED] like this.
  12. Aug 22, 2019 at 5:36 PM
    fdunlop
    fdunlop Well-Known Member
    Yeah, got it done while I was at school, so I was only driving 1 or 2 times a week. Pisses me off now but Had initially got it done because of body rust. If anything it'll make for a nice primer the second time around, Truck is still young and in good condition (145k miles). Just gotta save up and do it right. Definitely will spend the extra money to have all the trim removed now that I can afford it.
  13. Aug 22, 2019 at 6:06 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    That's how every job goes. I've done that job three times now, and could probably do it in a couple hours now.
    turbodb[QUOTED] likes this.
  14. Aug 22, 2019 at 6:08 PM
    1997tacomav6
    Denver
    3 times?
    Just curious why have the sealed failed that many times besides the obvious vent valve getting stuck closed
    GQ7227 likes this.
  15. Aug 22, 2019 at 6:10 PM
    Squeaky Penguin
    Brett
    They haven't.
    Once on my truck.
    Once on @Blackdawg s
    And another on mine when I swapped to chromoly axles to replace a bent one.
    1997tacomav6[QUOTED] likes this.
  16. Aug 22, 2019 at 6:54 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    how much is toyota fabric per yard? (approximate)
    found out today there is a 'source' out there that has my cloth material leftover from factory so I can do something with my seat situation
    that t4r i checked out earlier is not gonna work and left me very very frustrated
    looked like it was flooded because the underbelly of that seat was a crusted rusty heck of a mess, some kids probably ditched it in a pond in Kansas and salvage yard picked it up
  17. Aug 22, 2019 at 7:45 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    The seal is the easiest part too haha. Hardest part about the seal is making sure you don’t nick the inner axle tube and never knowing if it’s fully and evenly seated. The worst part of the job is setting the collar that rides on the seal.
  18. Aug 22, 2019 at 8:17 PM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    When I replaced my axle shafts I used it as an excuse to buy a slide hammer kit. The slide and the three jaw attachment popped the seals out perfectly. Waaaaay better than the cheesy seal pullers with the handle.
    BYJOSHCOOK and turbodb[QUOTED] like this.
  19. Aug 22, 2019 at 10:07 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    Yeah, I hear ya. Second axle took a little under 2.5 hours. Probably helped that I wasn't taking photos. Plus, confidence.
    LOL, not for me. Seal was the hardest part. I think because I had trouble with my camshaft seal when doing the timing belt - so I was worried about it before I even started.
    Setting the collars was easy (for me). I knew it was an important place to get right, so spent some time on it the first time, got a rhythm down, and the second one was just bang-bang.
    Yeah, that was the only SST I didn't purchase. Ended up making something similar from some steel rod and a block of wood I could pound on. :thumbsup:
    jubei[QUOTED] likes this.
  20. Aug 23, 2019 at 4:13 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Did you just measure or did you test the ring/seal by reinstalling the axle and marking the collar?
