  1. Aug 24, 2019 at 3:55 PM
    Trd_taco93
    Trd_taco93 Member
    Freddy
    03 Red trd taco
    Installed a new carrier bearing since the old one was pretty shot, seems to have helped with some clunking while driving.9F80DCC8-B63D-4F93-ADD0-A61AA9089628.jpg 1936A916-7962-4F2F-9002-580D3AD9FB51.jpg
    SwampYota and CS_AR like this.
  2. Aug 24, 2019 at 4:02 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Since I have the knuckles off for new ball joints, I decided to pump a little additional grease into my non-greaseable tie rod end boots.
    The grease injection needle can slide behind the boot opening and get right on the ball socket.
    Then I worked it in while moving the ball around in the socket.
    Feels as smooth as butter now.
    chrslefty and xtremewlr like this.
  3. Aug 24, 2019 at 4:06 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    What grease did you use??
    CS_AR[QUOTED] likes this.
  4. Aug 24, 2019 at 4:16 PM
    CS_AR
    I use a synthetic polymer grease from Omni Lubricants that mixes with lithium and petroleum based greases. I've been using it for many years with great results on ball joints and tie rod ends. I even use it on some lowered CV axle joints that typically last only 3 years. Its still going and the joints are smooth after 4 years.
    I learned about it from some guys who use it to grease the bearings on their boat trailers that get submerged in salt water. I'm not planning on submerging the Taco in salt water anytime soon. But the grease would hold if it happened.
    If you get it on your hands or clothes, look out. It is very hard to wash out.
    http://www.omnilubricants.com/
  5. Aug 24, 2019 at 4:24 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    It's whole again. Runs great but seems a little hard to start sometimes. Maybe just the ECU needing to learn the newly rebuilt injectors. Drove it over to the DIY car wash and gave it a quick bath then came home and put the tent back on the rack as I'm heading out the California for Labor Day weekend.
  6. Aug 24, 2019 at 4:25 PM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    Nice, thanks!!
  7. Aug 24, 2019 at 4:48 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    That's not anodizing it's bluing, it's just like what's on black sockets and it rusts badly if left in the elements.
  8. Aug 24, 2019 at 6:06 PM
    yeahkkyle
    yeahkkyle Well-Known Member
    Kyle
    PA
    2002 Tacoma TRD Offroad 3.4L 5spd
    I love the needle to grease things but man are they a pain to get off the gun sometimes.
  9. Aug 24, 2019 at 6:16 PM
    CS_AR
    The gun I use has an end tip that screws in and out. Check to see if you can loosen the tip by rotating it so it will open up for the grease needle socket.
    You can see how the tip can be rotated and the three bits inside the end will open. Then once you get the grease needle inside, tighten it up.
  10. Aug 24, 2019 at 6:28 PM
    yeahkkyle
    Kyle
    PA
    My tip is the same way. Never even thought about loosening it. Thanks.
  11. Aug 24, 2019 at 7:37 PM
    paposalsa
    paposalsa Well-Known Member
    Long time that I don't visit this site, However about a month ago got a paint correction detailing which came out real good and today finally got the gloss back front grill and side markers installed, got rid off of that ugly OEM one ...
    TacoYankee and Babybluetaco like this.
  12. Aug 24, 2019 at 8:23 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    :worthless:
  13. Aug 24, 2019 at 10:48 PM
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
    Hey fellas
    Which aftermarket headlights lenses are you’ll using for the ‘02-‘04s?
    Thanks
    Ace115 likes this.
  14. Aug 25, 2019 at 5:49 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Both. I would love to have heated water
  15. Aug 25, 2019 at 7:01 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    01 counts too...
    I just got a set of CAPA certified ones off Amazon. If you don’t buy CAPA certified you may as well get the cheapest you can find.
    GQ7227 and CS_AR like this.
  16. Aug 25, 2019 at 7:49 AM
    TacoSauce04
    TacoSauce04 Well-Known Member
    David
    2004 Lunar Mist SR5 TRD Double Cab 4x4 Tow Package
    ARE Shell
    just rotated my tire a few days ago. this morning driving to get a coffee with my windows down i hear a loud scraping sound coming from what seems to be my rear driverside tire. the sound is intermittent, it makes a sound once per tire rotation. i figured a rock but this sound is more of a metal on metal sound. the only thing i can see is the weights used to balance are very close to my rear drum. i have 15" wheels so the tolerance is very tight.
    Anyone have any ideas?
    Update: i got under the truck to check it out.
  17. Aug 25, 2019 at 8:22 AM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    Oreilly’s sells two models, I bought the cheapest ones two years ago. Still clear, good deal.
  18. Aug 25, 2019 at 8:44 AM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    Safe traves.
    Is that red cap on the drivers side for your washer fluid?
    Did you clean your mass air sensor?
    xtremewlr[QUOTED] likes this.
  19. Aug 25, 2019 at 8:47 AM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Yes and yes.
    Here's the link to the washer fluid reservoir I built.
    chrslefty[QUOTED] likes this.
  20. Aug 25, 2019 at 11:02 AM
    Zam15
    Zam15 Well-Known Member
    Derek
    San Diego
    Needs power..
    ARMOR
    Fridge is in! [​IMG] This time I can actually use my ARB slide! Can open the fridge inside and outside the camper now. Also makes cleaning the fridge a whole lot easier! Also have another battery from the previous Flip-Pac owner and I'm thinking about mounting it behind the fridge on the slide. Everything clears just perfectly! No more fridge bouncing around the back of the truck! Also fridge vents right next to the window so hopefully that will help keep the heat and power usage down.
    turbodb, butters_, xtremewlr and 7 others like this.
