  1. Aug 30, 2019 at 10:22 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    How different are there LCAs?
  2. Aug 30, 2019 at 10:25 AM
    eon_blue
    Azusa, CA
    I always air down and mine didn't last much longer lol. Just the nature of the crappy design.
  3. Aug 30, 2019 at 10:31 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Got 15k miles on my last set before they had a noticeable amount of play.
    Gotta pay to play...
  4. Aug 30, 2019 at 10:33 AM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    @eon_blue what grease are you using on your Daystar greasable shackles? How often?
    Been about four months since install and things are getting squeaky back there.
  5. Aug 30, 2019 at 10:42 AM
    eon_blue
    Azusa, CA
    Energy suspension grease or the Daystar grease that they sell, it's a silicone based PTFE one. I've heard that the Super Grease you can buy at Harbor Freight works too
    SwampYota[QUOTED] likes this.
  6. Aug 30, 2019 at 10:45 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    How do the long travel guys keep up? They still use stock LBJ's right?
  7. Aug 30, 2019 at 11:14 AM
    Squeaky Penguin
    Brett
    I think the difference is an occasional jump versus thousands of miles of spirited driving on bumpy roads...
    .... and the occasional jump.
    I'm sure they would kill them too, but a heavy vehicle used frequently for what we do is harder on parts that what most LT guys are doing.
  8. Aug 30, 2019 at 11:26 AM
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    2006 :thumbsup:
  9. Aug 30, 2019 at 11:32 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Working on my rooftop lighting project. Switches showed up today from @OTRATTW. These guys are awesome! If you need switches, check them out! 15% off for labor day as well.
    KiteGuam, BYJOSHCOOK and jubei like this.
  10. Aug 30, 2019 at 11:44 AM
    Reh5108
    Idaho
    I personally don't think it's that crappy of a design. I beat on it hard and it doesn't fail. The failures are from people not having there stuff inspected when it's beyond worn out. It's a wearable part. It sucks that the spindle separates but any other bj that's worn past its life will pull out of the socket also. Most you usually hear or feel it before it's to that point though. Owning a vehicle is your responsibility to maintain it. If that means taking it to someone to inspect it then it should be done.
    Running Board Man and jubei like this.
  11. Aug 30, 2019 at 11:48 AM
    Reh5108
    Idaho
    LT guys are often driving in sand which is a little more forgiving than rock also.
    Running Board Man likes this.
  12. Aug 30, 2019 at 12:29 PM
    TacoSauce04
    TacoSauce04 Well-Known Member
    David
    2004 Lunar Mist SR5 TRD Double Cab 4x4 Tow Package
    ARE Shell
    RE-Istalled my reverse camera. it stopped working for a few months. I replaced all the cables so hopefully I won't have any more problems.
  13. Aug 30, 2019 at 12:33 PM
    Reh5108
    Idaho
    You could very easily have a tie rod joint fall out of the socket if it is to far gone. You'd more than likely feel this. The point is once the ball in any ball and socket joint wears enough that it's diameter becomes smaller than the sockets, it's been fubar for way too long.
    jubei likes this.
  14. Aug 30, 2019 at 12:53 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    This is true. It's the fast driving on the 4-6" roundies at a decent pace that I'm sure fucks it up for me.
    Thanks homie. :cheers:
    They still connect to the spindle the same way.
  15. Aug 30, 2019 at 1:04 PM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    Going to get my oil changed today at Meineke bc they give me offers in the mails for the changes at 21.95. I called and asked about the cost to change rear diff fluid bc I know that needs to be done as well and I'd rather avoid doing it in AZ at 115 degrees. This mf had the nerve to quote me $129 to do the fluid!! Do these shops really have people dumb enough to pay for that?
    GQ7227 likes this.
  16. Aug 30, 2019 at 1:18 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    the arms are longer and i think wider. but the part the balljoint goes into is similar. might be able to make a tundra ball joint fit the taco lower. my tundra rolled and landed on the driver front bending the control arm. ball joint is original at 200k and is still tight even after that. the spindle is also different (larger bolts for the joint) but technically i think it'd work on tacos if the LCA can take the joint. 00-04 tundras were identical spindles to the tacos
  17. Aug 30, 2019 at 1:40 PM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    Yep I'm sure some people who dont have the time or tools.
    You can stop buy and do mine while your at it. I'll even let you narrow my shop fan . Ya know to help circulate the heat. Lol
    Das it mang[QUOTED] likes this.
  18. Aug 30, 2019 at 1:41 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    it cost $14.99 to change that out in 1992 at the quickie lube i worked at then
    $129 does seem a lot, are you sure that is not for the 4wd service and all diffs and transfer oil, even though you don't have the 4wd, perhaps they were confused?
    just curious if you have to bring your own toyota oil filter and possibly oil or do they stock that at Meineke, nevertheless 21.95 is a nice price
    make sure they get the oil drain plug back in securely
  19. Aug 30, 2019 at 1:42 PM
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    What model of pioneer do you have and how do you like it??
  20. Aug 30, 2019 at 1:43 PM
    eon_blue
    Azusa, CA
    If it was for a "4wd service" it probably would have cost upwards of a grand.
    Make something sound all inclusive and you can easily convince people that don't know otherwise that it's a good deal.
    I'm exaggerating of course on the $1k figure but you get what I mean.
    Das it mang likes this.
