  1. Sep 3, 2019 at 12:57 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    What is a solid battery choice for our trucks? I have some additional things like lights and a winch if that makes a difference. My battery is 4 years old and needs to be replaced.
    GQ7227 likes this.
  2. Sep 3, 2019 at 1:02 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Northstar AGM.
    Stock size: 24F.
    I went with a 27F for my truck to get more reserve capacity and CCA's.
  3. Sep 3, 2019 at 1:02 PM
    Dan8906
    Daniel
    Concord, California
    does it fit easily?
  4. Sep 3, 2019 at 1:06 PM
    JasonLee
    15 TRD OffRoad
    Instead of cutting the plastic battery tray I just removed it. The clamp is about 1/4" wider than the 27f, so I cut a few pieces of bicycle inner tube and put it between the clamp and the corners of the battery and clamped it down tight.
    During my last 1200 mile road trip with many miles of washboard and rocks, it only shifted a tiny bit.
  5. Sep 3, 2019 at 1:39 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I can certainly see how it would save some ring gears and axles from exploding.
  6. Sep 3, 2019 at 1:52 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Before...
    After...
    Wheels on...
  7. Sep 3, 2019 at 2:04 PM
    Junetaco03
    Junetaco03 Well-Known Member
    Bay Area, California
    2019 TRD OFF ROAD 4x4 DCSB
    Not first gen related but just got back from a 8 hour trip with my 1984 pickup!
  8. Sep 3, 2019 at 3:04 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Nice truck!
  9. Sep 3, 2019 at 3:04 PM
    OneWheelPeel
    Phoenix, AZ
    No More ADS? How come?
    JKU3000, sandsloth and Dan8906 like this.
  10. Sep 3, 2019 at 6:14 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    @OneWheelPeel No problems with them after 5 yrs other than leaking seals. I have them in a box and will either have them rebuilt or sell them as cores. They are pretty beat up as you can see. They started putting salt on the roads in Alberta 2 years ago and it is wrecking my truck.
  11. Sep 4, 2019 at 5:04 AM
    Noob95.5
    Noob95.5 Well-Known Member
    96 xtra cab 3.4l 4x4 manual
    Tundra hardlines
  12. Sep 4, 2019 at 8:19 AM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 185k
    881/5100/Dakars 4R wheels / TBU / New frame
    Got approved for a frame replacement three weeks before my deadline!!!! I'm very excited. I needed to replace the LCA bushings and I was dreading that job.
    I was hoping to get the dealership to replace the input bearing on the transmission while they have everything apart.. Does that seem like a reasonable request to you guys? I figured half the labor to replace that bearing is dropping/reinstalling the transmission, so I was hoping to save some $$$ by having it done during the frame swap.
    sandsloth and SwampYota like this.
  13. Sep 4, 2019 at 8:38 AM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Ask, the answer might be yes.
    If you don't ask, the answer is still no.
  14. Sep 4, 2019 at 8:46 AM
    CrustyTaco
    Todd
    Louisville, KY
    I asked the service manager, and he said I would have to pay $120 to have it diagnosed (which I don't mind), but he didn't really give any indication if they would adjust the billed labor hours to account for the fact that they are already removing the transmission as part of the frame swap.
  15. Sep 4, 2019 at 9:03 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Finished routing the lines for the new PS cooler.
    [​IMG]Untitled by Michael Halat, on Flickr
    Hoping to save myself some headaches by putting the filter in an easy to replace spot. Also should make flushing easier with a hose outside the engine bay now.
  16. Sep 4, 2019 at 9:47 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    Anyone here know if dealerships will charge to break the rear diff bolt loose for you? I tried to get the fill bolt loose before breaking the drain loose and can not for the life of me get it to budge. I sprayed the bolt down with WD40 2 days in a row, have tried using a hammer on the ratchet to help break it, and nothing. All I'm getting now is the bolt head is starting to morph from trying so hard to break it loose. My PO always went to Toyota for service and I'm sure they overtightened the bolt
  17. Sep 4, 2019 at 9:49 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I’m sure they’ll charge. Tons of people have this problem and some end up welding a nut onto it to break it loose.
    Das it mang[QUOTED] likes this.
  18. Sep 4, 2019 at 9:51 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Yikes. This makes me wanna go look at my frame now. Amazing how clean it looks around that rust spot.
  19. Sep 4, 2019 at 9:54 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    Faak well I'll put changing the fluid on hold for now then. That's some bs tho, is it from overtightening the bolt or is that one in particular prone to not budging? Like when I change it should I bear that in mind and not tighten it too much? Was gonna put some oil around the threads too like an oil filter to make sure it doesn't happen again. Thanks for the help!
  20. Sep 4, 2019 at 9:58 AM
    JKO1998
    Utah
    Just prone to freeze or whatever.
    Someone more knowledgeable might chime in with more info.
