  1. Sep 4, 2019 at 11:01 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Smack the plug with a hammer. Are you using a 6 point socket?
    Find a better penetrant than WD 40.
  2. Sep 4, 2019 at 11:04 AM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Breaker bar?
    Das it mang[QUOTED] likes this.
  3. Sep 4, 2019 at 11:05 AM
    04doublecab
    04doublecab Well-Known Member
    Jeff
    2004 Tacoma
    Didn't know they made 1/4" 24mm sockets
    Das it mang likes this.
  4. Sep 4, 2019 at 11:26 AM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    If the dealership follows the same method as mine, they don't break apart the engine and transmission. Both are affixed to the body, and raised with the body. They only cut brake and fuel lines, separate the exhaust, drive shaft, motor and transmission mounts, etc
    CrustyTaco[QUOTED] likes this.
  5. Sep 4, 2019 at 11:27 AM
    Seagull233
    Tom
    Upstate New York
    2004 DC 4x4 V6
    Much the same as mine, no sign on the outside until I pushed with my thumb, and it crumbled.
  6. Sep 4, 2019 at 11:29 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    My warranty is up in october. Im gonna give it a real good look over sometime this month. My truck has been in Roanoke VA most of its life so I doubt anything will show up, but it did get CRC'ed so I guess anything is possible.
    Seagull233[QUOTED] likes this.
  7. Sep 4, 2019 at 12:19 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    I need a backup for the moment.
    Unrelated...
    Does anyone know of a good circuit under the hood that comes on with the ignition? I need to wire my fogs as DRLs to pass the import inspection.
  8. Sep 4, 2019 at 12:20 PM
    eon_blue
    Azusa, CA
    I used an add a fuse that piggybacks off the dashboard gauge fuse for my AFR gauge, that way it's on whenever the truck is on.
    edit - never mind just saw you mentioned under the hood, this one is inside the cab
  9. Sep 4, 2019 at 12:22 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Yah I think the cig lighter would also be a good one if I have to come through the firewall.
    eon_blue[QUOTED] likes this.
  10. Sep 4, 2019 at 12:41 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Check near the bottom of the fuse box under the hood for any unused pigtails. I found a couple the other day but didn't actually check if they were ignition hot cause I already pulled the battery and other stuff.
    alphabravo[QUOTED] likes this.
  11. Sep 4, 2019 at 1:04 PM
    eon_blue
    Azusa, CA
    Got my new tailgate swing out installed last night, @GHOST SHIP makes them for 2nd gens and wanted to try out one for a 1st gen using my truck. Super happy with how it came out and looks, now I can finally get the spare out of my bed and free up some space, with room to mount some jerry cans on the other side of the tire since he designed it to be offset rather than centered.
    Anyone local in the southern CA area should hit him up if you're interested in one.
    Some pics (unpainted still, going to do that this weekend).
    Forgive the parking lot environment, I'm at work :luvya:
    jre32, sandsloth, jammer and 17 others like this.
  12. Sep 4, 2019 at 1:23 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I didn’t know you worked at a mall
  13. Sep 4, 2019 at 1:26 PM
    eon_blue
    Azusa, CA
    Might as well be one with how big our parking lot is, but nope it's an industrial lot.
  14. Sep 4, 2019 at 1:29 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Its easy to tell you work as a photo editor. Had to doctor up the pics of the truck lol.
    What color you planning on painting it?
  15. Sep 4, 2019 at 1:30 PM
    eon_blue
    Azusa, CA
    yeah that was just some quick Android photo app filters haha. Not quite deserving of the full blown Capture One/Photoshop treatment seeing as how they're just crappy camera pics.
    Just going to paint it black, undecided on whether I'll use a lightly textured bedliner or just do a flat black paint.
    I do like the bare metal look actually, though. But it'll need something to keep it from getting surface rust from the elements, especially with some of the places I take the truck.
  16. Sep 4, 2019 at 1:33 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    I wouldnt do flat. Satin is what most bumper companies use as a powdercoat, so if you ever go that route up front atleast it will match.
  17. Sep 4, 2019 at 1:51 PM
    Phessor
    Phessor Well-Known Member
    Bob
    1998 TRD XTra Cab
    Stuff
    How does it attach to the bed sides?
  18. Sep 4, 2019 at 1:53 PM
    eon_blue
    Azusa, CA
    It uses three of the mounting holes for the stock tailgate one each side, so 6 bolts total. The one Wilco used to make for our trucks that looks similar uses 6 total as well
  19. Sep 4, 2019 at 1:56 PM
    Phessor
    Bob
    1998 TRD XTra Cab
    Stuff
    I like, so what did it set you back?
  20. Sep 4, 2019 at 2:00 PM
    eon_blue
    Azusa, CA
    I was his 1st gen guinea pig so I got a solid deal on it, but from what I gather the ones he makes going forward (if he decides to depending on interest) will be priced around the same as the Wilco used to be, which if memory serves was ~ $600 or 700? Would have to hit him up to get an exact price on it though, I don't want to guess and be way off lol. He did say he'd be down to make more after he gauges interest, I'm not sure how shipping would work for those outside of SoCal but it might be able to be arranged
