  1. Sep 6, 2019 at 5:31 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    This. A squealing alternator likely has to do with belt tension. Try to tighten it or replace the belt if it's worn.
    My permatex ultra grey has been holding up great since regear 2 years ago.
  2. Sep 6, 2019 at 6:37 AM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Like @Running Man said, the biggest benefit is cleaning up the engine bay on the passenger side. I went with the Airaid tube on mine. I'm not a fan of metal intake tubes as I feel they retain too much heat from the motor, more so than the plastic does. Otherwise, there is no gain other than the looks and more sound from the intake.
  3. Sep 6, 2019 at 8:03 AM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    Were going to put a snorkel on it so thoes are a no go but good ideas. Thanks.
  4. Sep 6, 2019 at 8:06 AM
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    I know. I have a arid on my truck. But there kinda pricey and I'm going to shorten it up to fit the spacer so I don't want to pay that much for something I'm going to cut that's why I was asking about the pipe.
    It dose make the area look cleaner.
  5. Sep 6, 2019 at 8:17 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    and i only lost about $25 (maybe $37 with what i put back in) :spending: of Toyota coolant (1/2 gallon) that was only ~7k miles old
    i called Amanda at Camelback in regards to these black hose clamps they sent to me that look nothing like my originals
    she said they do not corrode but I have seen pics on TW with corroded hose clamps (from humidity i assume) but not sure what they are using so I just scraped some of the built up dirt on my silverish ones and slapped them back on.
    One Toyota mechanic told me to change the clamps that Toyota hoses do not fail that often
    but the indentations on my old hose were deep and set in over the years
    and the new hose has a rougher texture, not as smooth as the one i took off
    its all in the details anymore
  6. Sep 6, 2019 at 8:27 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    ill give it a try, the metal seems soft, it wont fk up too bad beating with a hammer?? and PB blaster maybe then, any recommendations? using a 4 point standard socket 1/4 inch. I was smacking the end of the socket with a hammer after reducing the slack but no success
  7. Sep 6, 2019 at 8:28 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    Think it'll help much more? just using standard 1/4 inch socket rn
  8. Sep 6, 2019 at 9:33 AM
    TacoSauce04
    TacoSauce04 Well-Known Member
    David
    2004 Lunar Mist SR5 TRD Double Cab 4x4 Tow Package
    ARE Shell
    I covered up some chrome with Plastidip.
  9. Sep 6, 2019 at 10:12 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Are you sure??
  10. Sep 6, 2019 at 10:45 AM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    I have one in a box that I had intended to install. I couldn't figure out how to do it without trimming the console surround. The fit up just didn't seem right since the metal plate is a bit thick.
    I opted for this route (Seidio, I think).
    SwampYota and FLBAdrian[QUOTED] like this.
  11. Sep 6, 2019 at 11:23 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    interesting. I had to have my axle housing replaced after being hit so I never got the chance to see how the rear was sealed.
  12. Sep 6, 2019 at 11:38 AM
    TRVsTRD
    TRVsTRD Well-Known Member
    Georgia
    02 Lunar Mist Prerunner TRD DCSB
    That's actually a nice touch, good job! I may have to store this idea away. :)
    TacoSauce04[QUOTED] likes this.
  13. Sep 6, 2019 at 12:30 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Replaced a broken corner light which I had converted to turn signals with amber VLEDS. Clear 3M over the lens.
  14. Sep 6, 2019 at 1:51 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    VLEDs are so worth it. I have gone through so many garbage Amazon LEDs that eventually have some kind of failure.
  15. Sep 6, 2019 at 1:57 PM
    Daddo
    Daddo Well-Known Member
    Paul
    2004 Doublecab Tacoma 4wd
    Full Total Chaos Long Travel
    Loaded up the Lt for some Suspension Adjustments.
  16. Sep 6, 2019 at 2:35 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
  17. Sep 6, 2019 at 3:21 PM
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
    Sorry if this is a dumb question, but what is the clear 3M for?
  18. Sep 6, 2019 at 3:56 PM
    defythemall
    defythemall Well-Known Member
    San diego
    01 RC 4wd, 03 DC 4wd
    Uv damage protection
    Side note, any output pics?
    quetzal[QUOTED] likes this.
  19. Sep 6, 2019 at 4:29 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    It protects the acrylic lens from rock chips, scratches, fogging. I've pulled it off old lenses after years and the lens is brand new.
  20. Sep 6, 2019 at 4:57 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    You get the clear stuff in bulk?
    Speedytech7 likes this.
