  1. Sep 8, 2019 at 9:01 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Thats what i ment. Lol
    SpikerEng[QUOTED] likes this.
  2. Sep 8, 2019 at 9:11 AM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    That is so pricey, oh well going to have to get it new
  3. Sep 8, 2019 at 9:45 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Greasing my uca's. Torque in the air or on the ground?
  4. Sep 8, 2019 at 9:54 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Ground
    Digiratus likes this.
  5. Sep 8, 2019 at 9:55 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    did your cousin determine what exactly went wrong with your HG?
    FLBAdrian[QUOTED] likes this.
  6. Sep 8, 2019 at 9:56 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Likely air in your MC. Tricky to bleed and to get air out.
    I like it. How do I buy it?
  7. Sep 8, 2019 at 9:58 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Really is a great thing the cable operated stuff. My Tundras all cable. Everything. The later 1st gen tacos some things were electrified.
    I think the rav4s up till 18 were cable too for whatever reason
  8. Sep 8, 2019 at 10:16 AM
    FLBAdrian
    Adrian
    Hanford Ca,
    Too many…
    Not yet it got super windy and dark plus we stripped a nut :annoyed:
    Running Board Man likes this.
  9. Sep 8, 2019 at 10:57 AM
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    I'd love to do this but a) is there a good spot to tap for a GM sensor b) calibration of said sensor- simply just a pull up or pull down resistor? Maybe needs a man-in-the-middle Arduino with a table to correct voltage output to OEM ecu. Need a table of the oe sensor output to temp relationship.
    I would like to think accurate temp to ECU would help with timing (pull timing with heat). Temp does not affect air fuel ratio nearly as much on mass air flow setups than MAP.
  10. Sep 8, 2019 at 11:01 AM
    Speedytech7
    I'm just gonna be the guy that says, switch to speed density and use a second MAP sensor for baro correction....
    Blackdawg likes this.
  11. Sep 8, 2019 at 11:07 AM
    BlackSportD
    Los Angeles
    Why? I mean I don't run a standalone and don't want to. If converting to speed density then IMO all the more reason to get an IAT post SC. But even on piggy I'm very curious what accurate IATs would reflect from the factory ECU. Pulled timing? Open loop sooner? Maybe almost nothing?
    I'm game to tap the SC is there is a good spot, and I like electronics projects.
  12. Sep 8, 2019 at 11:09 AM
    Speedytech7
    Nervermind then, for some reason I thought you had a full setup. I gave up on these stock computers long ago
  13. Sep 8, 2019 at 11:11 AM
    Daddo
    Daddo Well-Known Member
    Paul
    2004 Doublecab Tacoma 4wd
    Full Total Chaos Long Travel
    I'm kinda short for time packing for Kings Canyon but it is a Sportsmobile. I'll give details attached to my build thread. As Turbodb said not as nimble as a Tacoma. Completely different animal and for a different purpose than the Long Travel.
  14. Sep 8, 2019 at 11:34 AM
    SpikerEng
    SpikerEng Well-Known Member
    Leon
    Portland, OR
  15. Sep 8, 2019 at 11:46 AM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    The only place I would tap is one of the runners in the lower intake manifold. But it’s a tight spot so it may just get super heat soaked.
    Can’t the Greddy switch to speed density?
  16. Sep 8, 2019 at 12:05 PM
    BlackSportD
    Los Angeles
    Maybe cause I post about EMS here and there, I ran an ms3pro on the other car.
    Speedytech7[QUOTED] likes this.
  17. Sep 8, 2019 at 12:06 PM
    BlackSportD
    Los Angeles
    I don't think it has a MAP ecu like option but I could be wrong.
  18. Sep 8, 2019 at 12:42 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    messed up day!
    lost a piece of my ratty workshoe down in the corner LHS ...
    Kohls shoes SUCKass
    gotta goto thrift store get me a decent used one now
    trying to get that stupid seat back 2 good
  19. Sep 8, 2019 at 1:17 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    does the top hose look shot to you
    '97 bad hose 4.jpg '97 bad hose 3.jpg '97 bad hose 2.jpg '97 bad rad hose 1.jpg
  20. Sep 8, 2019 at 1:17 PM
    Empty_Lord
    Dan
    Not really... see aluminum corrosion inside of it.. they cheap enough I usually replace them. If I have them off.
    GQ7227[QUOTED] likes this.
