  1. Sep 8, 2019 at 4:25 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i used a lot of the 303 spray on the black plastic parts and it cleaned very well
  2. Sep 8, 2019 at 4:49 PM
    Phessor
    Phessor Well-Known Member
    Bob
    1998 TRD XTra Cab
    Stuff
    Control Valve - Toyota (87240-04020)
    Ace115 and GQ7227 like this.
  3. Sep 8, 2019 at 4:50 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i thought this was going to work out ok but no way are these going to last how cheaply made they are!
    my blue gray OEMs weigh a guesstimated 3x more than these awful made 'OEM' fitted mats from Camelback
    CS_AR likes this.
  4. Sep 8, 2019 at 5:13 PM
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    Just out of curiosity...
    A little rust on the rope hooks bothers you.
    Some rust on your lug nuts bothers you.
    The bolts on your seat bother you.
    But the wrong color of floor mats is fine?
    AZ4x4Taco, SwampYota, nagorb and 8 others like this.
  5. Sep 8, 2019 at 5:23 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    its not the color per se, its just so my feet have an easier time to relax on the long journeys, I drive sock footed when I don't have to stop for hours
    they discontinued my color of floor mats! so I went with these tan/oak they had in stock still thinking they would be the SAME QUALITY as what i have had
    this is what the backs look like for comparison
    its missing the whole heavy duty rubber backing on the right one
    even the side stitching is bad to say the least!
    just a little creature comfort for my feet is all i wanted, with the Tacoma brand
    maybe I will need to look for some comfy Husky mats! along with some all-weather mats for the winters and other messy times.
    and the seat bolt(s) are definitely a nuisance and very hazardous to drive sometimes with the one not secure if it was the root cause of my seat problems
    maybe the heavy duty rubber washers can help fix it!
  6. Sep 8, 2019 at 6:00 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    If you don't like those mats and want something different, I'll take them off your hands. I need some oak mats like those.
    GQ7227[QUOTED] likes this.
  7. Sep 8, 2019 at 6:19 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i will have to call Amanda @ Camelback and see what the deal is.
    my lug nuts are just wrench worn and corrosion resistant blacks, but now I am not sure if i would get the same exact ones ordering new which are a bit pricey so no immediate plans for sure!
    it maybe best to just paint the ones I have black and keep at it whenever they get scuffed again from taking them off
  8. Sep 8, 2019 at 7:02 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    the dr said my blood pressure is extremely high already
    too much stress and not enough sleep :bananadead:
  9. Sep 8, 2019 at 7:25 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Truck threw a P0330 code. Blah knock sensor malfunction. Anyone got some tips?
    CS_AR and FLBAdrian like this.
  10. Sep 8, 2019 at 7:27 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Pull the upper and lower and even lower intakes off and get ready to replace both sensors and the sub harness. Just get an intake gasket kit, saves money over buying all 4 individually. Good time to see if your heater pipe in the valley is leaking too
    CS_AR likes this.
  11. Sep 8, 2019 at 7:27 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Nightmare to get to them(not really thought) Usually harness degradation or the center pipe has leaked coolant into the valley of your engine
    CS_AR likes this.
  12. Sep 8, 2019 at 7:28 PM
    Speedytech7
    Jinx, you owe me a coke, or a land cruiser valve grind kit
    Running Board Man likes this.
  13. Sep 8, 2019 at 7:28 PM
    Empty_Lord
    Dan
    Hmm. No
    chrslefty likes this.
  14. Sep 8, 2019 at 7:30 PM
    Speedytech7
    Well I tried
    Captain Magma likes this.
  15. Sep 8, 2019 at 8:08 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    Clean them both with a wire brush, and then you can't tell them apart. Give 'em a dose of antiseize and they won't rust again.
    Adude likes this.
  16. Sep 8, 2019 at 8:08 PM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    Time to start dismantling
  17. Sep 8, 2019 at 8:09 PM
    Speedytech7
    Gonna do yours while you're in there for the HG?
    GQ7227 likes this.
  18. Sep 8, 2019 at 8:14 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i wouldn't necessarily call that rusty since its not flaky and crumbly?
    just some discoloration oxidation of whatever they are made of
    some of it did wipe off with some WD40 and rag
    i am very anxious to hit the hardware store tomorrow and go shopping for a rubber washer or something of the sorts to cushion it from vibrating if it will no longer bolt down all the way
    you should see what that antiseize did to my fuel shield bolts
    there is nasty goopy goop under there now where i did that!
    and it has not even seen its first winter to check the powder coat durability
  19. Sep 8, 2019 at 8:16 PM
    Speedytech7
    The zinc / cadmium plating tarnished and the bolt rusted, it's rust. And yous seat mechanism is probably loose internally, years of having your weight supported by a tab of 1/8 steel about a 1/4 wide will do that. Things wear out
    Seagull233 likes this.
  20. Sep 8, 2019 at 8:21 PM
    Yucel
    Yucel Well-Known Member
    San Francisco Bay Area
    2023 Tacoma TRD Sport
    I was just googling, and saw the thing for a lot cheaper on eBay and stuff. Would not hurt to try, it's just a rubber piece with nothing special.
