  1. Sep 25, 2019 at 10:15 AM
    drewmo
    drewmo Well-Known Member
    1995.5 4x4 Taco
    Hmm ok then is it even worth flushing the system and switching over to the pink stuff? I figured I would need to flush it anyways as I can't trust any of the work that was done before I bought it.
  2. Sep 25, 2019 at 10:28 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    If you can't trust any of the work done on it from the PO and you haven't ever done anything with the cooling system yourself, i'd say it would be worth it for the peace of mind.
  3. Sep 25, 2019 at 10:31 AM
    drewmo
    1995.5 4x4 Taco
    For sure, I expect to go through everything on this truck at this point. I have to tackle some surface rust on the frame and put a new under coating on it soon too.
  4. Sep 25, 2019 at 11:44 AM
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    ok when i get a chance
  5. Sep 25, 2019 at 3:50 PM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    2017 TRD Sport 1996 Tacoma SR5 Sold
    So some more digging on the misfire and my code reader is showing LTFT at 14.1... Anyone know what it should be around for 3.4? And why it might possible be so high?
  6. Sep 25, 2019 at 4:06 PM
    eon_blue
    Azusa, CA
    Fuel trims should be between -10 and 10, closer to 0 the better...from what I gather. 14 is too high if that's what it's averaging out to be
    numbers too high in the positives = lean
    numbers too low in the negatives = rich
    Given you have a misfire code I would imagine the fuel trim numbers being off is related to that but beyond there I'm just guessing. Hopefully someone else knows
  7. Sep 25, 2019 at 4:11 PM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    That’s what my thought was. This misfire started after I filled the tank up so maybe bad gas?
  8. Sep 25, 2019 at 4:15 PM
    eon_blue
    Azusa, CA
    Could be if it happened right around after you filled up...or might just be coincidence. There are a lot of things that could cause a misfire, what's the code?
  9. Sep 25, 2019 at 4:16 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    very possible. bad gas can cause misfiring. but usually fuel trims will be in the 20s 30s if its e85 or shit gas
  10. Sep 25, 2019 at 4:17 PM
    eon_blue
    Azusa, CA
    I just saw he said he has a P0304 code in a previous post...that would mean it's isolated to just one cylinder then right, the 4th one? If it was bad gas wouldn't it effect all cylinders?
    1997tacomav6 likes this.
  11. Sep 25, 2019 at 4:17 PM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    P0304. I tried a new plug and swapping coils around. Nothing has changed. Gonna pick up wires and try that next.
  12. Sep 25, 2019 at 4:18 PM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    You would think. I’m just spit balling at this point. Hoping it’s not injectors
    Running Board Man likes this.
  13. Sep 25, 2019 at 4:20 PM
    eon_blue
    Azusa, CA
    I would take @Empty_Lord's advice given his profession but I wouldn't rule out the injector on that cylinder as a possibility. There's gotta be a way to narrow it down though without throwing parts at it
  14. Sep 25, 2019 at 4:22 PM
    Empty_Lord
    Dan
    could be wires. but these trucks are getting old.. wouldnt be surprised if its an injector.
    but before jumping on injector i would do a compression test.
    eon_blue likes this.
  15. Sep 25, 2019 at 4:24 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Yeah, I was having misfiring and replacing the spark plug wires fixed that issue. I tried swapping coils like @Teke and didn't fix it, but wires did.
  16. Sep 25, 2019 at 4:43 PM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    I just did wires 40k ago along with spark plugs so I don’t have high hopes.
    Yeah I was gonna do compression next. I’m more than capable of fixing it but I just don’t know if I will have the time to do it.
  17. Sep 25, 2019 at 6:00 PM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    Welp I guess it was the wires! Makes me feel much better. LTFT was 3.1 after I swapped wires and the misfire went away.
  18. Sep 25, 2019 at 6:10 PM
    eon_blue
    Azusa, CA
    Nice
    Teke[QUOTED] likes this.
  19. Sep 25, 2019 at 7:12 PM
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    Shake down trip complete.
  20. Sep 25, 2019 at 7:22 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    photoshop
    No way did he post a DCLB picture.
    Every run for me is a shakedown run to test the last repairs. :anonymous: Speaking of which, cracked the coil bucket nice and proper.
    Time for more repairs. :annoyed:
    TMFF[QUOTED] likes this.
