  1. Oct 19, 2019 at 5:29 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    I’m curious if there’s any 12 hole injectors out in the wild that fit the 5vz..
  2. Oct 19, 2019 at 5:41 PM
    Empty_Lord
    Dan
    You see Avalon’s in junkyards? Fuck. I can’t find an 06 to save my life
  3. Oct 19, 2019 at 5:45 PM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    Look like Is300 318cc injectors. Either redrilled by Trd or random person. They run smooth as butter.
  4. Oct 19, 2019 at 5:47 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Up until like 2002 usually. Not as common as camrys but more common than any Toyota SUV or truck.
  5. Oct 19, 2019 at 6:15 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    chrslefty likes this.
  6. Oct 19, 2019 at 6:44 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Made a bit more progress on the On Board Air today.
    Made a braket to mount it in one of my side boxes.
    Plumbed all of the air (Disconnect and pressure switch)
    Tomorrow to wire it up and it should be good to go.
  7. Oct 19, 2019 at 6:53 PM
    1997tacomav6
    Denver
    Anyone know what year they started making the gas cap with plastic line attached to the gas door?
    Mine doesn’t have it
    GQ7227 likes this.
  8. Oct 19, 2019 at 7:12 PM
    Empty_Lord
    Dan
    01 for sure has it.. pretty sure the 98 at work has it too.
    GQ7227 and 1997tacomav6[QUOTED] like this.
  9. Oct 19, 2019 at 7:12 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    My 95 and 96 had it
  10. Oct 19, 2019 at 7:13 PM
    1997tacomav6
    Denver
    Interesting, my 97 didn’t, maybe it was an option
    GQ7227 likes this.
  11. Oct 19, 2019 at 7:14 PM
    Speedytech7
    I haven't had to put a tank in my new 96 though, maybe it doesn't....
  12. Oct 19, 2019 at 7:15 PM
    CedarPark
    CedarPark Master of Destroying CVs
    Dylan
    Cedar Park, TX
    '04 TRD V6 Taco, '11 2WD 5.7 Tundy
    Lights & Lockers & Duals
    +1, it’s nice having the outter bucket to keep the hub in place to help limp it around if you blew up a front diff
  13. Oct 19, 2019 at 11:27 PM
    drewmo
    drewmo Well-Known Member
    1995.5 4x4 Taco
    Finally cut the bolts holding my bed on the truck. Got the new ones from McMaster but need bigger washers for them.
    I thought I would have been able to prep it for POR15 quickly but it ended up taking all day. Also needed to remove the rear bumper and ended up snapping a bolt off. There was flaky rust on all the usual spots, I wish they made the frame re-enforcements better so the water drained instead of pooling inside.
    Then I needed to replace the lower ball joints as the boots were leaking.
    Old vs new side by side to see the difference.
    And all installed.
    After removing the LBJ I checked one side and didn't feel any play in it, but I wanted to have the peace of mind that it was good for another 100k miles or so. I bought some outer tie rods to do as well but didn't have a large enough box end wrench to replace it. I'll have to order a 27? and 28? Not sure of the exact size yet.
    Also realized I will still need to spray fluid film as I can't POR15 inside the frame, so that's on its way to me as well. So far this is the most progress I've made in one day.
  14. Oct 19, 2019 at 11:28 PM
    Empty_Lord
    Dan
    the jam nut should be a 27mm
    CS_AR, eon_blue and drewmo[QUOTED] like this.
  15. Oct 20, 2019 at 6:35 AM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Removed the tire carrier and cut the mount off the bumper yesterday so I can start putting a new one together. Wasn't happy with the heim joints for the pivot, they allowed the tire carier to lean away from the tailgate too much, regardless of how I adjusted them. Got a nice double shear spindle type mount from 4xInnovations that is going on instead.
  16. Oct 20, 2019 at 7:07 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    That style spindle you mention is how we've rocked our 35"E rated spare on a bumper/carrier. Spindle is stout. Slee and 4x4Labs, etc.and other big boy bumper makers use those too:cool:
  17. Oct 20, 2019 at 7:14 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i don't think this locks from the outside :notsure: the fuel door
    i just throw the cap on the top of wheel well in the bed during fillup, even on top of ice and snow piles in the winter
  18. Oct 20, 2019 at 7:16 AM
    Hooks98tacoma
    Hooks98tacoma Well-Known Member
    Georgia
    98 Tacoma 2.4
    My 98 2wd doesn’t have it. Idk if it was broke before I got it
  19. Oct 20, 2019 at 7:16 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    I sprayed Corroseal inside frame before FF using the same wand just because, RUST.IMG_20191008_145233266.jpg
    GQ7227 likes this.
  20. Oct 20, 2019 at 7:17 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    @drewmo
    what the heck?
    a CA truck? i thought frames were bulletproof in California!
