  1. Oct 21, 2019 at 7:07 AM
    jammer
    jammer 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
    I was about 17 when I used a gravity feed sandblaster. I should have listened to my dad, and covered up / taped my sleeves, etc. I felt like a three legged cat in a sand box.
    GQ7227[QUOTED] likes this.
  2. Oct 21, 2019 at 7:15 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    this piece of rubber spray coating was on there real good, it took quite awhile to blast it off to naked steel
    i don't think the fuel tank should be difficult to remove, its just the putting it back in properly that mesmerizes me currently
    and what exactly i will find behind it
    so far nobody has been able to post a good pic of what the inner rail should look like behind there and how thick it is
    long buttoned sleeves are good!
  3. Oct 21, 2019 at 7:24 AM
    jammer
    Ben
    Bentonville, AR
    J A Y what size air compressor are you using? A larger / quieter one is on my wish list.
    GQ7227 likes this.
  4. Oct 21, 2019 at 7:32 AM
    1997tacomav6
    Denver
    Fuel tank is easy BUT if those high pressure hose nuts are seized then you have a problem.
    I COULD NOT for the life of me break the nut closest the the cab even with two large wrenches.
    If I had continued I think the whole connection would have broken in two,
    Luckily the tank side I was able to break loose and that was with the bed off being able to bear down on it. With the bed on, good luck
  5. Oct 21, 2019 at 7:35 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    the bed is definitely coming off before i even touch that tank, probably won't be until the spring unless November is really warmish 70s
    1997tacomav6[QUOTED] likes this.
  6. Oct 21, 2019 at 7:36 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Fuk'n NICE brother. Congratulations!
    I knew you weren't going anywhere, but nice to see you with a Taco again.
    We'll be expecting another build thread post haste. lol
  7. Oct 21, 2019 at 7:39 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    ^ This guy :rolleyes:
  8. Oct 21, 2019 at 7:59 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    A needle gun will make short work of stripping frame coating on large areas. Save the blast media for small,tight, inaccessible areas.
  9. Oct 21, 2019 at 8:19 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    this is the one i have been using, it had the highest SCFM i could find for less than $500
    its probably not the best of the best, it sure puts out the hugest amount of water vapor, the pebbles in the separate dryer have already turned color and need replaced after just a couple weeks of use
    CS_AR and jammer[QUOTED] like this.
  10. Oct 21, 2019 at 8:24 AM
    jammer
    Ben
    Bentonville, AR
    Dang, that's nice! I know what you mean about the water vapor. My small Sears Craftsman (5 gallon) does the same. I put a inline filter in, but it doesn't catch all of it.
    I would love to have the size you have to be able to use a spray gun. I imagine body shops invest lots of money in filters to catch all moisture.
  11. Oct 21, 2019 at 8:26 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    I know you think your garage is bad but I'm envious of the order you have going on in yours..... Motivating me to go get mine back in order
  12. Oct 21, 2019 at 8:34 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    there's not much rubber frame coating left to remove after decades of power wand washing regularly
    these spots must've popped up this past year when i became 'lazy' and just ran it through the auto wash daily (instead of getting out and hosing it down myself) after they smothered the main streets with calcium chloride to destroy the inch of ice after the blizzard (pre flood)
    you cannot even trust the machines any more!
    one dealer service dept. told me they could re-spray rubber coating on it to take care of my problem and cover it up
    CS_AR and jammer like this.
  13. Oct 21, 2019 at 8:37 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Lol, that garage has no semblance of order. All my overflow junk that was in there is now in my trailer, which is now equally as worthless as a glorified shed on wheels.
    Running Board Man likes this.
  14. Oct 21, 2019 at 8:39 AM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Painted some axles.
    8D691CC7-75B1-412E-993D-F72411E0BD67.jpg 907B9D1F-9127-4C62-ADFC-78757989E89A.jpg
  15. Oct 21, 2019 at 8:43 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    what paint did you use?
    that looks good
    jammer likes this.
  16. Oct 21, 2019 at 9:15 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    September 18, 2019.
    Too soon, we were through these distracting, colorful, Alders. Luckily it wouldn't be our last encounter with these beautiful trees, and besides, we were making our way up and around what we hoped would be another cool peak to add to our list of places we'd driven to the top of: Hahn's Peak. Visible at the top, an old lookout - no longer staffed - called to us to visit, and we made our way around the base of the mountain as we looked for a way up.
    Read all about it in Redhead Down #3: We Cross into Colorado
    catch up on the whole story
    [part 1] [part 2] [part 3]​
  17. Oct 21, 2019 at 9:37 AM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    Tree rounds cynder blocks and a lot of jacks. Thing that sucked was getting the new front diff back in with it beeing that high.
  18. Oct 21, 2019 at 9:39 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Steel It? Looks good
  19. Oct 21, 2019 at 10:12 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
  20. Oct 21, 2019 at 10:13 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Me too.
