  1. Oct 22, 2019 at 6:36 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    don't go highway speeds until done investigating!
  2. Oct 22, 2019 at 6:37 AM
    Phessor
    Phessor Well-Known Member
    Bob
    1998 TRD XTra Cab
    Stuff
    I fabbed in the cat back exhaust from a 2016 Tacoma into my 1998. Much quieter, thank you @0uTkAsT
    CHMM, m3bassman and Ace115 like this.
  3. Oct 22, 2019 at 6:39 AM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    yes, especially with my new painjob! Would suck to ruin it already...
    GQ7227[QUOTED] likes this.
  4. Oct 22, 2019 at 6:41 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i have not yet seen the new paintjob! i was curious about, have you posted it somewhere?
  5. Oct 22, 2019 at 6:45 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Lexus is300
  6. Oct 22, 2019 at 6:48 AM
    onakat
    Canada
    2000 indestructaco!
    no, I haven't yet. I've been busy putting it back together (had brought it stripped of a lot of things to save some time to the bodyshop guys). Don't worry, I'll let you know when I'll post pictures :)
  7. Oct 22, 2019 at 7:12 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    https://www.wheeladapter.com/product/extended-wheel-studs-for-toyotas
    These are OEM spec wheel studs, they are probably longer than you need but can easily be trimmed down to the correct length. I have bought a couple sets of these before, no issues.
    They have sets of 12 as well if you're just doing the front.
    ffirg[QUOTED] likes this.
  8. Oct 22, 2019 at 7:41 AM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Could also be your tie rods. 186k I would consider swapping all the front in components with new. Upper/lower ball joint. Possibly bushings. Inner and outer tie rods. Possibly steering rack bushings.
    onakat[QUOTED] likes this.
  9. Oct 22, 2019 at 8:07 AM
    drewmo
    drewmo Well-Known Member
    1995.5 4x4 Taco
    I appreciate it but I already picked up some replacement bolts from McMaster online. They should hold up nicely. I also won't be able to use stock anymore because the welded nuts sheared off the inside of the bed.
    CedarPark[QUOTED] likes this.
  10. Oct 22, 2019 at 9:06 AM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
  11. Oct 22, 2019 at 9:12 AM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    I have always pressed the studs out, that way you're not hammering on your wheel bearing and ball joints. You can use a ball joint-type clamp to push them out.
    You want to use a wheel stud installer tool to draw the new ones in, you can usually rent one at an auto parts store. I would use a disposable lug nut to do it as well if you're using an impact wrench.
  12. Oct 22, 2019 at 9:28 AM
    ffirg
    mike
    Anchorage, Alaska
    I just replaced the wheel bearings and ball joints so maybe a press is the way to go. Ha.
  13. Oct 22, 2019 at 1:28 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    just ordered a winch, new speedo gear and new LBJ bolts. Now I gotta put in said winch and crawlbox and then I'll be done with all the things.
    FLBAdrian likes this.
  14. Oct 22, 2019 at 1:29 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    "done"
    What is this foreign word of which you speak. It is not familiar to me.
    Pyrifera, ToyotaDriver and riskadverb like this.
  15. Oct 22, 2019 at 1:33 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    :spy:
  16. Oct 22, 2019 at 2:06 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    who says u cant put things in a taco bed
    Louie2001, FLBAdrian, Chad 22 and 2 others like this.
  17. Oct 22, 2019 at 2:06 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    What free height are your coils? 13 or 14"... If they're the factory 13" start where j con suggests at about 1.5" of thread showing above the collar
  18. Oct 22, 2019 at 2:10 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    They are 14 inch
  19. Oct 22, 2019 at 3:01 PM
    Speedytech7
    Maybe back em off to 3/4 and start there. My Icons had the 13" 650# coils so I always had a bit more showing than most
  20. Oct 22, 2019 at 5:18 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    I ordered a winch not too long ago. Wired it up, got ready to mount and test and realized the instructions said the battery needs to have 650 CCA, my battery is 530. I’ve heard rumors that another Northstar battery group buy coming up next month that should take care of that. Not sure what battery you have but throwing that out there.
