  1. Nov 4, 2019 at 8:42 AM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    I do find it annoying that 1st gen Tacos are pulling more $$ than my 2004 ram can on Craigslist. I love the Ram, I've had it about 12 years and have done a ton of shit to it. It drives super nice on the highway, it's extremely comfortable for long drives, has zero mechanical issues, even at 216k miles. And it's the Hemi engine with some basic mods done (tuner, headers and some other things) that make it even better all around. And I have about 90% of the parts needed for a good engine refresh. But I know that I'll be lucky if I can sell it for $5k, even with all that stuff. Not enough to buy another 1st gen so I might also have to sell my track bike. But I haven't ridden that in a year anyhow.
    OneWheelPeel likes this.
  2. Nov 4, 2019 at 8:52 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Eh there are 1st gens around me for 5k all the time. They are getting cheaper and cheaper. Especially as 2nd gens get older and older.
    And shoulda bought a cummins :p
    Adude and ToyotaDriver like this.
  3. Nov 4, 2019 at 9:01 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Brice, POSTacoMike and xtremewlr like this.
  4. Nov 4, 2019 at 9:19 AM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Had no need of the cummins at the time. But yeah, it would have retained it's value much better.
  5. Nov 4, 2019 at 9:25 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Wat.
  6. Nov 4, 2019 at 9:38 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    As someone who got a beat up Tacoma, I'd recommend starting to plan for a LS swap now. If I had a garage and time, I would have rebuilt my engine myself. But I did not, so I paid someone build up a 5VZ from a core and swapped it in and had a 2 year warranty against any leaks or problems. Now I wish I had just paid someone to drop an LS with a turbo in it with a 5 speed auto.
    The right time to get a 2nd taco is when you still have a functioning one. That way you can get one of these cheap broken ones and build it up right.
    Rollins[QUOTED] likes this.
  7. Nov 4, 2019 at 11:36 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I've used zip ties instead of that clamp and have had no issue with contaminants getting in.
    Running Board Man likes this.
  8. Nov 4, 2019 at 11:37 AM
    Reh5108
    Idaho
    LS is going to be a lot more time consuming and likely more expensive with needing a new axle.
    Just slap a turbo on the 3.4 and enjoy it being able to breathe at elevation.
  9. Nov 4, 2019 at 11:38 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    The beck and arnley boots actually came with heavy duty zip ties instead of clamps but I wanted to be difficult.
  10. Nov 4, 2019 at 11:39 AM
    JasonLee
    15 TRD OffRoad
    I can't turbo in a CO smog county, can I?
    In the sense that the stock ECU is not flashable (...yet, maybe never), so I'd have to run a piggyback or a replacement ECU.
  11. Nov 4, 2019 at 12:30 PM
    POSTacoMike
    POSTacoMike On the rocks, please
    Red Deer AB
    2001 Tacoma DC XPreRunner
    OME Suspension, ARB Bumper, frame swap, Rebco logger box.
    Took it for a drive
  12. Nov 4, 2019 at 12:34 PM
    Reh5108
    Idaho
    Idk, haven't lived in a place where I need to deal with any of that.
  13. Nov 4, 2019 at 1:05 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    I thought so!!
  14. Nov 4, 2019 at 2:12 PM
    Shape-Shifter
    Shape-Shifter Well-Known Member
    Todd
    Elizabeth, CO
    Put a covert winch on it.
  15. Nov 4, 2019 at 2:18 PM
    Captain Magma
    Captain Magma Well-Known Member
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    Kings and desert pinstripes
    i’ve been lookin out for 5lugs as a possible daily. See them pop up at or below 5k fairly often. Would love to have a little regular cab 5spd as a daily
  16. Nov 4, 2019 at 2:43 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    I wouldn't be too concerned with a bit of oil seep on the motor at 246,000 miles. Mine was leaking pretty good from the valve cover gaskets at about that mileage. Having the valve covers done wont fix that, but if whoever is doing the water pump/timing belt is any good they'll be in there far enough to be able to tell you where the oil is most likely coming from. The only things that are you get to, during the timing belt/water pump replace, that would effect oil would be the cam seals and the front crank seal and if those are leaking, you wouldn't even be able to see it because it's behind the front plastic cover.
  17. Nov 4, 2019 at 3:46 PM
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    I would recommend doing the cam seals at a minimum. It's only a few extra bolts for a boat load of security. Many of the kits come with the seals too. Would hate to do the job and have the seals leak a few months later.
    Rollins, Jon64l, Adude and 1 other person like this.
  18. Nov 4, 2019 at 3:57 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Totally agree... and I would also recommend doing the crank seal as well.
    The point I was making is if you can see oil, it's not from anything that will be fixed or replaced as part of doing the timing belt/water pump.
    Rollins and Gen1FTMFW[QUOTED] like this.
  19. Nov 4, 2019 at 4:37 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    blew through another 20 pounds of glass bead abrasive blast media before it got too cold out and body started aching bad from neck and shoulder deep up under there
    still looking for a safer way to complete project in a much more efficient way
    availability of reasonable priced proper equipment for safety sake continues to elude me :(
  20. Nov 4, 2019 at 5:42 PM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    Nothing to my Taco, but a co-worker brought his Taco to my house and I changed Motor oil, removed and cleaned the throttle body and maf.
    I enjoy working on Tacoma’s.
    cruiserguy and GQ7227 like this.
