  1. Nov 4, 2019 at 5:46 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i loathe working on mine anymore!
    chrslefty likes this.
  2. Nov 4, 2019 at 6:01 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    I’ll give ya 2500
  3. Nov 4, 2019 at 6:05 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    YOU give me 2500 to work on it? that seems high
    i would give YOU almost 2500 to work on it!
    and i need a :homer:taco job
  4. Nov 4, 2019 at 6:07 PM
    Empty_Lord
    Dan
    Lol, I’m broke. Tundra sapped my mad money for a few months...
    But I do take donations in the form of 97 tacomas
    GQ7227[QUOTED] likes this.
  5. Nov 4, 2019 at 6:10 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    do you have a good setup for blasting? it just peels right off fairly easily
    have a few tough little spots still trying to figure what to do with
  6. Nov 4, 2019 at 6:10 PM
    Empty_Lord
    Dan
    My little ol craftsman can’t keep up. The air compressor at work could, but good luck using it around there
  7. Nov 4, 2019 at 6:13 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i have a fairly decent electric compressor from HF, other than the amount of moisture it spews out sometimes when its humid, it holds up well so far for the little blast gun that could
  8. Nov 4, 2019 at 6:14 PM
    Empty_Lord
    Dan
    Is your grams scalesds a needle gun may make it a little quicker to clean up by getting the flaking stuff off
  9. Nov 4, 2019 at 6:17 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    oops, i think we are in the wrong thread, should go to lunch table!
    :sorry:
  10. Nov 4, 2019 at 7:23 PM
    david9kelsey
    david9kelsey Well-Known Member
    David
    Murrieta Ca
    00' Tacoma PreRunner
    My 2000 prerunner has a locking door
  11. Nov 4, 2019 at 7:55 PM
    eon_blue
    Azusa, CA
    Anyone here with the 5 speed get a popping feel in clutch pedal? Mine did it a few years ago, went away on its own and now it's back with a vengeance. Creaks and has this metallic 'POP' when it comes back up. Still works fine but is kind of unsettling...don't want to lose the ability to work the clutch suddenly while driving.
    Is it an issue with the spring, or needing some grease? I seem to remember a few years ago I sprayed some PTFE dry lube on it and that might have helped. Gonna try that again tomorrow.
    GQ7227 likes this.
  12. Nov 4, 2019 at 8:03 PM
    1997tacomav6
    Denver
    Probably the spring clutch issue, there is a mod for that part, or the brass bushing I think is there too
    Clutch return spring mod
  13. Nov 4, 2019 at 8:05 PM
    eon_blue
    Azusa, CA
    I'll check it out thanks, wouldn't be surprised if that's it given its age at this point.
    GQ7227 and 1997tacomav6[QUOTED] like this.
  14. Nov 4, 2019 at 8:06 PM
    1997tacomav6
    Denver
    GQ7227 and eon_blue[QUOTED] like this.
  15. Nov 4, 2019 at 8:26 PM
    eon_blue
    Azusa, CA
    I've never changed it out so its gotta still be the oem setup
    GQ7227 and m3bassman[QUOTED] like this.
  16. Nov 4, 2019 at 8:27 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    I’m getting axle wrap again. My Alcan springs should be fine. I’m wondering if I need to adjust my rear drums? I pulled the plug to check the pads and they look the same as a yearish ago when I checked them last(about a 1/4”). Is adjusting them easy?
  17. Nov 4, 2019 at 8:30 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I don't see the correlation of axle wrap with drum brakes...
    Speedytech7 likes this.
  18. Nov 4, 2019 at 8:34 PM
    eon_blue
    Azusa, CA
    Haven't had axle wrap on my 04 but back when I had my 99 Prerunner I remember greasing the driveline zerks helped lessen it considerably.
  19. Nov 4, 2019 at 8:34 PM
    Dan8906
    Daniel
    Concord, California
    Tried that and didn’t help much.
  20. Nov 4, 2019 at 8:36 PM
    eon_blue
    Azusa, CA
    Weird you're experiencing it with the Alcans, usually a quality leaf spring pack isn't as susceptible to the binding that leads to axle wrap as the stock leafs are.
    What's also interesting is that I've never once had it on my 04, but my 99 had it bad.
