  1. Nov 5, 2019 at 5:52 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    that is a good idea but time and weather is not kind
    exponential decay is probably right around the corner :bananadead:
  2. Nov 5, 2019 at 5:55 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Gotta use it while you can
  3. Nov 5, 2019 at 5:56 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    as long as it doesn't die before i die i will be happy :)
    but i have seen what a truck same age around here ends up like at 239k miles and i don't want none of that
  4. Nov 5, 2019 at 6:23 AM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Does anyone have the spicer part number for the oem carrier bearing
  5. Nov 5, 2019 at 6:31 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    SwampYota likes this.
  6. Nov 5, 2019 at 7:13 AM
    Rollins
    Rollins Member
    Virginia
    2003 Tacoma TRD
    I picked mine up for $3500 from a friend of a friend; way lower than any I had been seeing online or at dealers. My only complaint is that it's automatic, but that's minor. My car is manual so I'm not missing out too much.
    cruiserguy likes this.
  7. Nov 5, 2019 at 7:16 AM
    Rollins
    Rollins Member
    Virginia
    2003 Tacoma TRD
    Many thanks for the info. My mechanic is great and has been taking care of my car for the last 11 years. I'll give him a call and mention to be sure to do the cam and crank seals in addition to the timing belt and water pump. I'm all for getting the important stuff done while the mechanic is in there.
  8. Nov 5, 2019 at 7:19 AM
    Dan8906
    Daniel
    Concord, California
    Thanks man! order one up from summit racing.
  9. Nov 5, 2019 at 7:23 AM
    POSTacoMike
    POSTacoMike On the rocks, please
    Red Deer AB
    2001 Tacoma DC XPreRunner
    OME Suspension, ARB Bumper, frame swap, Rebco logger box.
    Hi!! Man, there's all sorts of people I know here!!! :thumbsup:
    m3bassman[QUOTED] likes this.
  10. Nov 5, 2019 at 7:40 AM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    Did front brakes yesterday, found a shop that cuts rotors. $5.00 each. Put on ceramic brake pads.
  11. Nov 5, 2019 at 8:19 AM
    cruiserguy
    Elijah
    SEKS
    Generally speaking I just replace the rotors because when I've had rotors turned before they seemed to be more hassle and give me more problems than just replacing with new rotors. My thought is at 30-35 bucks a rotor might as well just throw a new one on. But I'd rather not do that if I can find a shop that or place that actually takes pride in turning em and does a good job. And for 5 bucks.... That's almost a no brainer man. Nice work:D
  12. Nov 5, 2019 at 8:41 AM
    eon_blue
    Azusa, CA
    85k miles.
    When I first got the truck, the clutch pedal creaked/squeaked like a barn door opening every time I pressed it, it was awful. I sprayed it with dry lubricant and it would go away, then come back, go away, etc. Finally one time it went away and I haven't heard it for a couple years until last night.
    Just drove to work though and it's gone again, so...we'll see.
    GQ7227[QUOTED] likes this.
  13. Nov 5, 2019 at 8:43 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    mine basically only gets 'worse' with climate change, global warming, whatever it is nowdays
    its just like my door hinges except seems to trade off on opposite seasons
  14. Nov 5, 2019 at 8:43 AM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    It was an old school auto parts store, the owner took his time resurfacing the rotors, he allowed me to watch. Couple of old guys shooting the breeze while the lathe turned.
    cruiserguy[QUOTED] and GQ7227 like this.
  15. Nov 5, 2019 at 9:13 AM
    Hooks98tacoma
    Hooks98tacoma Well-Known Member
    Georgia
    98 Tacoma 2.4
    Paid $2000 for mine a year ago. Has a lot of miles tho.
  16. Nov 5, 2019 at 9:40 AM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    Mine squeaked for a few years. Tried to lube it, but nothing really worked. Then for a few years the squeak went away. At some point durring these years my cruise control stopped working. I didn't realize it was related at the time. Then the pedal got to where it wouldn't always come back up, just stayed on the floor. If I pulled it up a little it would pop the rest of the way up. Wasted money on a new master and slave cylinder. Then found the thread about the linear spring mod. Bought a brake pedal return spring. Used a screw driver to pop out the coil spring, and installed the brake pedal spring. Took all of three minutes. No squeak, pedal comes all the way up, and now my cruise control works.
  17. Nov 5, 2019 at 10:25 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    I cut my rotors.
    Because I have a brake lathe
  18. Nov 5, 2019 at 11:29 AM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    Well la di da!!
    Robmonster117 and Pyrifera like this.
  19. Nov 5, 2019 at 11:56 AM
    Empty_Lord
    Dan
    Lol.
    Perks of working for a Toyota dealer!:D
    Lol
    GQ7227 likes this.
  20. Nov 5, 2019 at 1:31 PM
    Rollins
    Rollins Member
    Virginia
    2003 Tacoma TRD
    Well, this is a bigger job than I had anticipated, but after the valve cover gaskets, cam and crank seals, the 02 sensor, the spark plugs and wires, the timing belt and the water pump, I'll have a truck that will last a loooong time...right? Please tell me I did okay buying this truck! I'll just have to make it work for me with lots of gardening jobs. Or I could sell it and break even (but then I'd be without a truck, and what's the fun in that?)
    OneWheelPeel and GQ7227 like this.
