  1. Nov 5, 2019 at 1:45 PM
    BiNiaRiS
    BiNiaRiS Well-Known Member
    Portland, OR
    Wasn't much work on my end...but I've wanted a softopper and a hard folding tonneau cover ever since i bought my truck. Found used softopper locally 2 weeks ago and snagged a Rugged Liner folding tonneau off Amazon last week.
    Spent a few years waiting to find a deal on them and then somehow found them both for a crazy good price within a week of each other.
    Softopper should be on most summers when we're off camping often, and the tonneau should be on there the rest of the season.
    SouthernYoder likes this.
  2. Nov 5, 2019 at 2:34 PM
    kuntry09
    kuntry09 Well-Known Member
    Cam
    Douglas, Georgia
    '99 extended cab Tacoma 4x4 converted Prerunner
    Anyone running wheelers 8 pack that have had trouble with driveline vibes? I’ve had the packs on for well over 6 months now but have just felt the vibes after getting new tires. My other MTs were so worn out I couldn’t even tell the vibes were there.
  3. Nov 5, 2019 at 2:38 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Might need some shims between the leaf pack and axle to help with driveshaft angle, or maybe check your carrier bearing, spacer might help with that too.
  4. Nov 5, 2019 at 2:43 PM
    eon_blue
    Azusa, CA
    Wheelers sells axle shims that should help
  5. Nov 5, 2019 at 3:02 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    how many miles on your truck?
  6. Nov 5, 2019 at 3:06 PM
    SouthernYoder
    SouthernYoder If you skarred, say you skarred.
    Knoxvegas, TN
    01 dbl cab 4x4 3.4l SR5
    3" OME, 883 coils, Nitros, AAL, 07 FJ Trail team wheels, K&N CAI, Tundra brake upgrade.
    Quick question guys. Anyone got that link close for the silicone hose kit for the 3.4? I’ve seen it around haven’t looked hard enough yet.
  7. Nov 5, 2019 at 5:07 PM
    Pyrifera
    Pyrifera Adventureswithdog.com
    Oregon
    '04 TRD 4x4, V6, 5-speed
    All nooks & crannies now upgraded with Dog Hair!
  8. Nov 5, 2019 at 5:34 PM
    Ace115
    Ace115 Well-Known Member
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    Looking for some help;
    recently tried shifting into 4hi-4lo on a very lose and rocky hill. No dash light indicator to say t case has been engaged. Tried locking rear diff and dash light just blinks. Rear wheel kept slipping and from what I could see out the driver window the front driver side axle was not engaging.
    Climbed under truck and there is no visible problem with t case or axles or wiring/plugs going to top/side of t case.
    what should I start looking at now?
    TIA.
    GQ7227 likes this.
  9. Nov 5, 2019 at 5:36 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    It's from HPS performance, the coolant hose kit is at least, dunno about intake
    SouthernYoder[QUOTED] likes this.
  10. Nov 5, 2019 at 6:13 PM
    kuntry09
    Cam
    Douglas, Georgia
    I have a CB drop I’m going to try, and I’ve thought about shims. I’ve been looking at this thread I found in the 2nd gen forum on measuring angles to determine what size shim. https://www.tacomaworld.com/threads/drive-shaft-vibrations-solved-step-by-step.244535/page-2. Didn’t know if may be a common problem with the wheelers 8 pack. Also have gone back and made sure my U-Joints were all in the correct phase after installing a new CB and 4wd driveshaft
    cruiserguy likes this.
  11. Nov 5, 2019 at 7:03 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    need more truck details.
    do you have an auto or manual?
    J-stick transfer or 2-4 select with push button?
    Were you moving or stopped?
    Grey wire or Blue plug mods?
    ADD with auto hubs or manual swap?
    GQ7227 likes this.
  12. Nov 5, 2019 at 8:01 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    You sure the vibes you are feeling aren't the new tires?
  13. Nov 5, 2019 at 8:01 PM
    Ace115
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    3.4L
    Auto Trans
    J-stick xfer case
    Moving and stopped attempts to engage 4x
    No grey wire/blue plug(?) mod
    ADD w/auto hubs
    GQ7227 likes this.
  14. Nov 5, 2019 at 8:16 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    4hi was engaged already with a dash light? And then when you shifted to 4lo it wouldn’t engage?
  15. Nov 5, 2019 at 8:28 PM
    Reh5108
    Idaho
    I don't think the light indicates your tcase being engaged as that's all mechanical. It's either in the lo position or not. From my understanding it is signalling that the ADD has engaged the passenger axle.
    You should be able to tell if it's in low range by the slow speed. If it is indeed in low then it's almost certainly your actuator isn't in the correct position.
  16. Nov 5, 2019 at 8:33 PM
    Ace115
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    Sorry if I’m confusing. Let me try to clear up a few things.
    The dash light that I never saw was the green light lower right side of dash that looks like axles&wheels
    When I attempted to lock the rear axle with the xfer case in 4lo the red e-locker light just blinks. Again, still no green axles/wheels light.
    GQ7227 likes this.
  17. Nov 5, 2019 at 8:36 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    That light should turn on as soon as you go into 4 hi, not just 4 low.
    Sounds like your ADD actuator isn't working. Without that working and it thinking it's in 4wd, you won't be able to use the locker, unless you have the grey wire mod.
    Reh5108, JasonLee and Ace115[QUOTED] like this.
  18. Nov 5, 2019 at 8:47 PM
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    20 tons of force wouldn't separate the hub from the wheel bearing... But it did explode the bearing into two.
    OneWheelPeel, SwampYota and kuntry09 like this.
  19. Nov 5, 2019 at 8:48 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    check your 4wd relay. Mine needed cleaning and would not engage the ADD system to lock the front diff into 4wd.
    The blinking elocker light usually means its attempting to lock. THough can also mean it is locked.
    GQ7227 and Ace115[QUOTED] like this.
  20. Nov 5, 2019 at 8:48 PM
    Dan8906
    Daniel
    Concord, California
    So once you were in 4hi the green light should have shown up. I had this issue once I got some electrical connection cleaner from the part store and cleaned all the connectors on my transfer case and that fixed the issue
