  1. Nov 11, 2019 at 9:03 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Man.......why you gotta do that :p[/QUOTE]
    You know we just love to give you shit brotha :thumbsup:
    Yetimetchkangmi and Fernando like this.
  2. Nov 11, 2019 at 9:14 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    One day i just might
    Na
    ........ I wont.
  3. Nov 11, 2019 at 9:27 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    I did the Amazon pump, it was easy.
  4. Nov 12, 2019 at 4:50 AM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
  5. Nov 12, 2019 at 5:18 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Here's what I did. It's secured by two massive zip ties. No leaks and works great.
    https://www.tacomaworld.com/threads...-01-build-thread.290011/page-23#post-13792223
    Fairly sure I got the above idea from you. :p
    Robmonster117[QUOTED] likes this.
  6. Nov 12, 2019 at 5:25 AM
    JBTacoma
    Jeff
    Cullman Alabama
    Liked both
    Taco critter likes this.
  7. Nov 12, 2019 at 6:16 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Check for exhaust gasses in the coolant. The water pump does not create pressure and it is technically three pieces, pulley...shaft...pump vanes. But I've never heard it this metal style one breaking in anyway other than bearing failure and leaking.
  8. Nov 12, 2019 at 6:33 AM
    1997tacomav6
    Denver
    It has to be either a defective thermostat even tho I put two new ones in in two days or the water pump.
    The top radiator hose is at 190 degrees and the bottom hose is at 30 degrees, so there is definitely no
    water movement through the radiator after driving it for 10 miles.
    Anyways it’s at the dealership and will find out this afternoon what’s up.
    It’s under warranty if either item is defective.
    What’s the chance of me installing two defective thermostats?
    What’s the chance of the propeller breaking off a 9 month old OEM water pump?
    Both are pretty slim tho
    cruiserguy likes this.
  9. Nov 12, 2019 at 6:39 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    I had the same thought yesterday with getting pressurized through a head gasket leak or crack in the head via combustion, just seems so unlikely. But maybe not more unlikely than 2 bad thermostats in a row? But is something to check and eliminate as a possibility
  10. Nov 12, 2019 at 6:41 AM
    cruiserguy
    Elijah
    SEKS
    Yeah both slim, but at this point it's gonna be something that isn't very likely, whether that's 2 bad thermostats or something up with the head :anonymous:hopefully 2 bad thermostats:fingerscrossed:
  11. Nov 12, 2019 at 6:46 AM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    the only reason I think it’s bypassed is because I don’t get the rushing water noise after changing coolant until I turn the heat on.
    maybe the radiator is clogged somehow.
  12. Nov 12, 2019 at 6:46 AM
    1997tacomav6
    Denver
    I was going to cut the inside of one of the thermostat out and install it to see if it was moving water but with three failed thermostats 1) the motorrad 180 I put in 5 months ago 2) the super stant 170 I put in 2 days ago,3) carquest 170 I put In yesterday so I just took it
    to the dealership
    cruiserguy[QUOTED] likes this.
  13. Nov 12, 2019 at 6:47 AM
    Speedytech7
    Always a good test to perform. Not uncommon on Toyota engines, they seem to have thin HG sections between combustion and water jacket. I've killed two, and I highly doubt it'll be my last. Easy enough fix anyhow, just a bit labor intensive or cash intensive if you don't do it yourself. I'm a small sample data alone but I've only had 1 bad thermostat ever haha. Always been something else when cooling issues arise. One rad and one heater core dead from coolant going nasty after an undiagnosed HG failure, some rad caps, an upper hose, heater bypass tube (4cyl).... Never had a failed water pump, a leaky one sure, but never entirely split apart and the one bad thermo I'm driving on keeps the fucker too cold (more common failure mode than stuck shut since safety stats are a thing now)
  14. Nov 12, 2019 at 6:47 AM
    1997tacomav6
    Denver
    Impossible, it’s a new radiator and is new looking inside and zero dirt inside
  15. Nov 12, 2019 at 6:49 AM
    cruiserguy
    Elijah
    SEKS
    I'm still thinking out loud here, could this keep coolant from circulating? If it's being pressurized from a head gasket leak or similar?
  16. Nov 12, 2019 at 6:50 AM
    Speedytech7
    It'll just hyper focus heat, temp sensor is up in the head. His rad is massive and Colorado is cold, I'd expect a huge temp differential from top to bottom
  17. Nov 12, 2019 at 6:50 AM
    cruiserguy
    Elijah
    SEKS
    Yeah it really is a wild unusual situation. It's gonna be something not normal or common to fix, hopefully not head expense shiz though
  18. Nov 12, 2019 at 6:52 AM
    cruiserguy
    Elijah
    SEKS
    Crazy.... Oh could this be before the thermostat even opens because it's so cold down there and so hot up top??? Ohhhhh I'm seeing it now
  19. Nov 12, 2019 at 6:57 AM
    Shortman5
    Supercharged TRD
    Is it possible the radiator is too good? Like it’s cooling the water so much that it’s drawing too much heat away from the stat and it won’t open?
    also the top hose is supposed to be pressurized is it not? Maybe you’re just overthinking the top hose.
    cruiserguy and 1997tacomav6 like this.
  20. Nov 12, 2019 at 6:57 AM
    1997tacomav6
    Denver
    The top hose is probably pressurized because the engine temperature is 190 degrees and there is no water movement and creating pressure and the bottom hose by the thermostat is 30 degrees I Thinking
    Reh5108 and cruiserguy[QUOTED] like this.
