  1. Nov 13, 2019 at 5:11 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    If you hadn’t landed wrong you’d feel differently. Dude you were living, something happened. You’ll be alright.
    CHMM[QUOTED] likes this.
  2. Nov 13, 2019 at 5:11 PM
    CHMM
    CHMM GTO
    Gabe
    Castle Rock, Colorado
    2001 TRD Xtra Cab 4x4 Supercharged
    5100s SPC UCAs Energy bushings #70 spring clutch mod Supercharged
    Done it a million times. This time with damn flip flops.
    cruiserguy likes this.
  3. Nov 13, 2019 at 5:21 PM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    I think the most difficult part is over.
    RonJon31, jonesbt, fiziks and 27 others like this.
  4. Nov 13, 2019 at 5:56 PM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    Aww shit!!
  5. Nov 13, 2019 at 6:11 PM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    can you make me a set??
    JK. Unless you want to....
    but seriously, there needs to be an alternative to the CX racing manifolds.
    Jon64l[QUOTED] and cruiserguy like this.
  6. Nov 13, 2019 at 6:19 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    :drool:very nice
  7. Nov 13, 2019 at 6:24 PM
    1997tacomav6
    Denver
    Beautiful welds !!! That’s an art
    Thumper Daze and Jon64l[QUOTED] like this.
  8. Nov 13, 2019 at 6:44 PM
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    1997tacomav6 likes this.
  9. Nov 13, 2019 at 7:22 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Not entirely sure how I feel about this mod, considering exactly zero of the ring terminals fit and I had to drill them out.
    Also the boot didn't work at all so I had to hack it up too. Lots of hacking going on here.
  10. Nov 13, 2019 at 7:23 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Yeah they always use 3/8 bolts on those. I crimped on fressh 3/8 terminals to everything. Hydraulic crimper makes that a breeze
    ThunderOne[QUOTED] likes this.
  11. Nov 13, 2019 at 7:35 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Looks like it's the ARB.
  12. Nov 13, 2019 at 8:08 PM
    00_5VZ
    00_5VZ Dumbest smart guy you’ll ever meet
    Rob
    Thornton, CO
    2004 DC TRD, S/C, Impulse Red Pearl
    TRD S/C, URD 7th injector, Deck plate mod, gray wire mod, 2 low mod, magnaflow cat back exhaust
    Out of curiosity, what dealer are you taking it to?
  13. Nov 13, 2019 at 8:24 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Sounds like the side gears are out of alignment with the "pinion gears". Is the cross pin still in place, set screw tight, all that?
    nagorb[QUOTED] likes this.
  14. Nov 13, 2019 at 8:34 PM
    1997tacomav6
    Denver
    They still are not sure today
    Autonation, usually they are excellent,
    I told them this evening to do a
    1)radiator flow test
    2)Check both radiator hoses for collapse issues
    3)remove the thermostat to eliminate that item from the equation putting in a gasket only.
    4)if these items are all working correctly them replace the water pump with a new one.
    All these items are less than a year old so there has to be a defective part.
    Thats the plan for tomorrow
  15. Nov 13, 2019 at 8:35 PM
    Shortman5
    Supercharged TRD
    I believe he’s saying the hose separated and inner line collapsed. So from the outside it appeared to be fine.
  16. Nov 13, 2019 at 8:38 PM
    Speedytech7
    I had that happen to a brake hose once, stayed half pumped cause it collapsed under auction when the brake pedal was released. Acted like a check valve
  17. Nov 13, 2019 at 8:40 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    Pins and set screws seem fine. Side great has play between it and the thrust washer. I can feel a bit of interference between the side gear and the pinion when I turn with my fingers. But I'm not sure what sort of tolerance they're supposed to have
  18. Nov 13, 2019 at 8:47 PM
    Shortman5
    Supercharged TRD
    Damnit that reminds me, I need to change my brake fluid. It’s original with too many miles. Gotta stop being lazy and only working on the fun stuff.
    Speedytech7[QUOTED] likes this.
  19. Nov 13, 2019 at 9:23 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I fit a 295/85/16 in the stock location. Rubbed the diff slightly under compression but still had space between the springs. Not saying you should do it but it's likely doable.
    I messaged arb about the bushings and they sent me a free set. They are kind of a pita to remove and you'll probably want a press to install.
    Mine have slashes everywhere. Some deep enough to hit the cords. I did have one that had a tiny puncture in it. It would take a week before I noticed it was low on air.
    Nice work!
    95 taco[QUOTED] likes this.
  20. Nov 13, 2019 at 9:26 PM
    Reh5108
    Idaho
    Just because everything is new doesn't mean something hasn't failed. Manufacturers aren't perfect. Did you remove the Tstat and see if things flow?
