  1. Nov 14, 2019 at 7:50 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
  2. Nov 14, 2019 at 7:52 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    :rofl:got me again:rofl:
  3. Nov 14, 2019 at 7:54 PM
    cruiserguy
    Elijah
    SEKS
    I'm gonna be careful over here though in this thread, apparently y'all don't like to laugh oe something....is what some dude was saying:D
  4. Nov 14, 2019 at 8:24 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I see those causing problems if your cams are maxed for caster, like mine are. All the binding and tearing of bushings.
    Yep, we've talked about those in the cracking thread, and I already have something similar.
    Still pursuing a better setup that goes around the sides of the bucket, and like @cynicalrider said, a crossbrace.
  5. Nov 14, 2019 at 8:29 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    We took a close look at these. If they wrapped down the sides a bit, would be better. We are going to fab something that reinforces the top and sides where mine tore.
    You make it sound so simple. It is not.
    To remove the stock towers means removing the motor mounts perches too. This makes it a major event. Besides, I could not locate an aftermarket tower designed for stock IFS geometry.
    drr and Running Board Man like this.
  6. Nov 14, 2019 at 8:39 PM
    JasonLee
    15 TRD OffRoad
    You're right. I wish it were simple. I guess I was being overly optimistic and thinking in the mindset if I had a full shop, engine hoist, welder(s), CNC/plasma/waterjet tables, etc...
  7. Nov 14, 2019 at 9:11 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    If your bushings are fine you can absolutely align your truck with just the SPCs. You won't be able to dial in the castor but you'll be able to jump in increments of the what the spc are. You'll likely want a competent alignment tech if you don't plan on doing it yourself.
    The alignment cams adjust both camber and castor. SPCs also adjust both camber and castor. The biggest benefit to them is the camber adjustment so you can max your castor at the LCAs giving you more tire to firewall clearance. Using UCAs to gain castor decreases the distance of tire to firewall.
  8. Nov 14, 2019 at 9:31 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yes.
    If only someone made that..
    Except he didn't, he just replaced them with OEM ones.
    hmm in retro spec, should have done that before installing them. Be easier to mock up.
  9. Nov 14, 2019 at 9:32 PM
    Reh5108
    Idaho
    Depending on where they are seized it doesn't matter. I've considered tac welding mine in place since I have no reason to adjust them after maxing them for castor.
  10. Nov 14, 2019 at 9:38 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Not exactly sure what it is you are implying here. As near as I could determine, the only choice was OEM. If you know of any aftermarket options, post up some links.
    We'll see how it goes. I believe adding them now wont be a problem.
  11. Nov 14, 2019 at 9:57 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    no im just saying the conversation to just upgrade whole coil buckets which requires a ton of cutting and welding doesn't make it worth it is moot since...you have to do that if you have to replace it anyways. Which you had to, so you had to do all that work regardless so it would be nice if there was an upgrade available.
  12. Nov 14, 2019 at 10:01 PM
    Squeaky Penguin
    Brett
    I think the whole coilbucket discussion is more or less a moot point to begin with.
    A) almost no one on here needs to worry about it
    B) if you're at the point in your build where that's an issue, you probably have the knowledge and resources to fix it.
    03_taco_IN, m3bassman, CS_AR and 2 others like this.
  13. Nov 15, 2019 at 12:04 AM
    1997tacomav6
    Denver
    So the radiator checks out ok
    The top and bottom hoses check out ok
    The thermostat was removed and just the gasket was installed
    and the results were the engine did not warm up past 130 degrees and
    antifreeze movement is seen.
    So the radiator and hoes are out of the equation.
    That leaves the water pump or thermostat.
    So Water pump has to be doing something.
    I’ve replaced the thermostat twice plus the original one and all three thermostats
    show the engine running 20 degrees hotter than what it normally runs at idle in cold weather.
    So do I replace the water pump? Could the water pump be working just part of the time?
    Or replace the thermostat a 4th time and see what happens?
    When I took it in to the dealer it was 20 degrees out side and my engine temperature was at 195
    with the top radiator hose at 190 and the bottom hose at 40-50 degrees and didn’t see any water movement.
    I run a 170 stat and my normal temperature is 175-180 max.
  14. Nov 15, 2019 at 1:30 AM
    CHMM
    CHMM GTO
    Gabe
    Castle Rock, Colorado
    2001 TRD Xtra Cab 4x4 Supercharged
    5100s SPC UCAs Energy bushings #70 spring clutch mod Supercharged
    Bushings are no good. I called Toytec and they are advising against UCAs. They are recommending new bushings.
    GQ7227 likes this.
  15. Nov 15, 2019 at 1:38 AM
    CHMM
    CHMM GTO
    Gabe
    I was reading it could be a timing belt issue where it’s too tight or not aligned properly causing water pump issues. I would have them check the timing belt to make sure it’s not misaligned or too tight. Then i would ask them to redo both the timing belt and water pump. You paid Toyota a lot. So it should be perfect. It’s not the radiator or hoses or anything else. It’s sounding like an install error. That's what I would bet on. It sucks. If you need a ride there, shoot me a text.
    GQ7227 and 1997tacomav6[QUOTED] like this.
  16. Nov 15, 2019 at 2:34 AM
    CHMM
    CHMM GTO
    Gabe
    That sucks man.
  17. Nov 15, 2019 at 2:34 AM
    Trim taco
    Trim taco Just one more stupid question
    Bourbon capital of the world
    Was: 96 SR5 5MT Is: 19 OR 6MT
    Bunch 'o random stuff
    Ah, yes. I remember doing this. It was actually a fun job, except for removing all the factory deadening material. Some of it came up nice and easy but some of it just didn't want to let go.
    BYJOSHCOOK[QUOTED] likes this.
  18. Nov 15, 2019 at 3:06 AM
    CHMM
    CHMM GTO
    Gabe
    Here some of what we did to my son's truck since we got it two years ago. It's our project. Then we had a hail storm that totaled it. So I worked out a deal with the insurance company and took $50 less and paid a few bucks out of pocket to get it to stay alive. Just need lower control arms and inner tie rods and it's done. 2017-11-02 15.52.02-1.jpg2017-11-09 17.04.27.jpg 2017-11-09 17.03.54.jpg 2017-11-15 18.35.03.jpg 2017-11-15 18.34.51.jpg2017-11-07 13.24.48.jpg2017-12-15 09.27.01.jpg
    chrslefty, sandsloth, GQ7227 and 2 others like this.
  19. Nov 15, 2019 at 4:51 AM
    eimkeith
    eimkeith Well-Known Member
    J Keith
    '96 4Runner, '03 Taco
    I agree. I'm working with my '03 taco and '96 4Runner to route an over-engine (well, more in front but overish) strut tower brace that would interface with the top plates. My concern is that once the coilover buckets are made impenetrable, the towers themselves would likely crack nearer the frame (or twist, possibly?) Plus, something overhead could double as an upper bump mount for the crazy desert guys who might run a fabricated UCA (just spitballing here)
    Something to consider is that I ran my top plate back into the engine side of the coil tower as far as I could to get that extra leverage. A simple circle above the coilover certainly will just move the cracks to the edge as you guys stated. Wings would be a simple addition to the top plate, but not the best solution either, IMO (which is why I didn't add them, but I certainly could if my strut tower brace doesn't work out.)
    Being self-locating is a major consideration with this stuff, I agree.
  20. Nov 15, 2019 at 4:57 AM
    eimkeith
    J Keith
    I don't understand why no one makes a slip-in spherical solution for our LCAs - like the SPC Axxis joints or similar. If the eccentrics aren't in perfect alignment, the bushings are fighting the axis of rotation to some extent?
