  1. Nov 15, 2019 at 6:48 AM
    1997tacomav6
    Denver
    Yea but that was 20,000 miles ago, didn’t know this so will look at this too
    GQ7227 likes this.
  2. Nov 15, 2019 at 6:49 AM
    1997tacomav6
    Denver
    Scanguage
  3. Nov 15, 2019 at 7:05 AM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    He’s using a OBD2 device. @1997tacomav6 maybe change the water temp sensor.
  4. Nov 15, 2019 at 7:08 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    that must've been a monster hail storm that probably killed or seriously injured anybody caught unprotected outside
    i envision bowling ball sized chunks of ice?
  5. Nov 15, 2019 at 7:10 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    you do not want that engine to overheat!
  6. Nov 15, 2019 at 7:14 AM
    1997tacomav6
    Denver
    With the thermostat out the engine would not warm up and gauge said 130 or something, so that’s correct info tho
  7. Nov 15, 2019 at 7:15 AM
    1997tacomav6
    Denver
    Of course not, it’s not leaving the dealership till it’s fixed, it’s been there 4 days now
    GQ7227[QUOTED] likes this.
  8. Nov 15, 2019 at 7:17 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Excuse my ignorance because I have only run stock UCA's so far. Can any uniball UCA be adjusted for alignment purposes? Or only SPC since the ball joint can be moved into different positions on SPC's? From what I can tell from my Icon UCA's is that I can't make any adjustment on them for alignment purposes.
    I've seen this too that I feel does the same job we want to do and thensome.
    https://www.chaosfab.com/accessories/1996-2004-Tacoma-Dual-Shock-Hoop-Kit-96602
    It pushes downwards on the coilbucket while allowing the use of a secondary shock even for those of us sticking to stock width. It was something I considered for a hot second before I realized I was already blowing my budget on this current project.
    I'll be interested to see how my truck holds up after I do all these gussets. Really it's just where the crack will go next right? I have always been limited by my front shocks, but with all the gussets and nice shocks all around I'll finally be able to beat on the truck like I've always wanted to. It can be a good case study for how it holds up with good gusseting from the jump. 3 year old frame combined with TC and Eimkeith gussets, and limit straps eventually.
    Anywho, got one side all fitted up. Took a ton of grinding and fitting to get these tower supports where I wanted them to be. Will work on passenger side tonight after work.
    [​IMG]Untitled by Michael Halat, on Flickr
    I'm going to use fender washers on each end of the UCA to add a little spacer when I tack it all up based on @Squeaky Penguin's recommendations so that I am not fighting to get the UCA out when I need to.
  9. Nov 15, 2019 at 7:23 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Obviously the pump works otherwise no coolant would flow and tempts would sky rocket with no thermostat in place.
    So it's the thermostat again.
    Just put an oem normal one in. The motor was designed to run at 185 anyways.
    Duh.
    Twist would be eliminated with coil bucket gussets really though. Which if you're running a cross brace..you're going to have those too.
    That would be bad ass. Camburg is the only company I know of that makes lcas with bearings in the lcas. But that's a long travel kit.
  10. Nov 15, 2019 at 7:38 AM
    1997tacomav6
    Denver
    "Blackdawg, post: 22022020, member: 48500"]Obviously the pump works otherwise no coolant would flow and tempts would sky rocket with no thermostat in place.
    Just put an oem normal one in. The motor was designed to run at 185 anyway,,
    That’s the plan for today to install an OEM thermostat and see what happens.
    Will be thermostat number 4 in the last week tho,
    If it’s running hot after this then it’s time to check water pump and or timing belt situation.
    Not sure if a loose timing belt would cause the water pump to slip? Maybe the timing belt tensioner?
    Just running out of ideas.
    I tested the other two thermostats and they were working correctly opening at 170-175 degrees
    and before last week have had zero issues with running over 180-185 degrees when it’s 100 degrees outside outside.
    Having the engine at 195 degrees when it’s 20 degrees outside at idle or highway and 100 degrees
    difference from the top to bottom radiator hose has to say water pump or thermostat.[/QUOTE]
    GQ7227 likes this.
  11. Nov 15, 2019 at 7:41 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Love the comment. Can I put this in my signature line?
  12. Nov 15, 2019 at 7:54 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    you can probably tell from my ramblings that i am sometimes a retard and not very mechanically inclined as most on TW seem to be ... don't know nuts about bolts at times
    so I'm just brainstorming the situation from afar and the flow chart points to one item that has changed in your system recently,
    that custom built radiator
    perhaps its not within OEM exact engineered specs?
    please don't hate on me if this is the stupidest idea going... :anonymous:
    riskadverb likes this.
  13. Nov 15, 2019 at 7:57 AM
    1997tacomav6
    Denver
    No, with the thermostat out the radiator kept the temperature at 130 degrees or something so that’s not the issue
  14. Nov 15, 2019 at 8:24 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i am happy to report my 'summer gremlin' vibrations at certain RPMs (2.1k) finally seemed to go away or at least not noticeable (it was bad at times!), because i have not had to operate the A/C in hot temps
    it most likely will return sometime next year...
  15. Nov 15, 2019 at 9:03 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Yeah, that would be nice. My 2nd set of whitelines are shot because they only really contact on one edge with my crossed up cams.
    SPCs adjust from the balljoint. Yours have no adjustment.
    You could have got heimed UCA too like I recommended. :boink: I would like a set because they would fix my aforementioned LCA bushing issue by aligning it without the cams crossed. Of course that would also mean I would loose caster at the LCA and loose tire clearance to the firewall as well.
    Was also pondering if it would be possible to move the LCA forward somehow, but that's probably above my skill level.
    Go for it.
  16. Nov 15, 2019 at 9:14 AM
    CHMM
    CHMM GTO
    Gabe
    Castle Rock, Colorado
    2001 TRD Xtra Cab 4x4 Supercharged
    5100s SPC UCAs Energy bushings #70 spring clutch mod Supercharged
    I hope the OEM fixes it.
  17. Nov 15, 2019 at 11:12 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Heimed UCA was out of the question as I was already all set on the Delta's setup (in my hands under the work bench) especially for the price I was getting it for. I was merely asking because I didn't see any way to adjust mine, and wanted to make sure if there was supposed to be a way to adjust it, I wouldn't some how fuck it up with the way I position the tower gussets. I don't mind adjusting at the LCA's TBH. Now that I have all of it out and it came out with no issues, I can liberally anti seize the fuck out of it all and hope it never gets seized up. Speaking of LCA's and locking alignment there has been some interesting mentions of ways to lock your bottom alignment in place with cam eliminator setups people have been making on IFR.
  18. Nov 15, 2019 at 11:39 AM
    1997tacomav6
    Denver
    They put in a New OEM thermostat and told me to see how things go in real life driving conditions.
    Tech said the OEM is holding at 185 at idle which is good news for now, will see how this coming week goes, the other 2 thermostat were not OEM that I put in, will be shocked if
    the OEM was the fix
    GQ7227, sandsloth and CHMM like this.
  19. Nov 15, 2019 at 11:44 AM
    Squeaky Penguin
    Brett
    You need another way to adjust alignment if you solid mount the lowers. Hence heimed uppers or SPCs.
    Also, I wouldn't want to solid mount my lowers how they are positioned now. I'm trying to get away from my LCAs sitting all crooked in the mounts.
    Reh5108 likes this.
  20. Nov 15, 2019 at 11:44 AM
    CHMM
    CHMM GTO
    Gabe
    Good luck man. OEM stat should do it. 97 needs back in action.
    GQ7227 and 1997tacomav6[QUOTED] like this.
