  1. Nov 18, 2019 at 9:58 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    yes, that and a bad experience from a local top body shop guy,
    lots of prep work is a must for UV protection
    one other one i cannot remember
    3 bad reviews is enough for me to stay far away from it
  2. Nov 18, 2019 at 9:58 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    are you close to the Iowa border?
    while you have that bed off it be very easy to blast all that off to the pure metal and etch it good
    or were you already doing that?
    you should get a more than a few more good years!
  3. Nov 18, 2019 at 10:29 AM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Frame generally isn't exposed to UV. They do make a top coat or you can use any other kind of spray paint to cover it. POR15 is pretty decent, when the right prep work is done. Just like any other surface finish out there.
    GQ7227[QUOTED] likes this.
  4. Nov 18, 2019 at 10:31 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i suppose you would need something like this too?
    bowyer2002 likes this.
  5. Nov 18, 2019 at 11:32 AM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Alright, so 4xinnovation started their sale this morning and I pulled the trigger on their swing out to weld on to my bumper only 5% off but whatever, saved money is saved money. It says 6-8 lead time. Im hoping I can find time between now and then to weld on my frame CBI reinforcements. Im wondering if a Lincoln 140 mig welder is enough power for both projects, anyone got any feed back from putting theirs frame reinforcements on? or with better welding knowledge
  6. Nov 18, 2019 at 11:47 AM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    Dry drive shaft splines.
    GQ7227 likes this.
  7. Nov 18, 2019 at 12:01 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    I did my frame reinforcements, built both bumpers and rach and rebuilt my swingout using my Hobart 140. I think it's comparable to the Lincoln 140. Get gas now if you don'e have it setup yet. Makes it all SO much easier and your welding will be better.
    jubei, Dan8906[QUOTED] and Wulf like this.
  8. Nov 18, 2019 at 1:22 PM
    tntacomaguy
    tntacomaguy Well-Known Member
    Someone else asked when I’d greased it last. Which was just 3-4 months ago at most. I’ll maybe shoot some more grease in there and try it
    GQ7227 likes this.
  9. Nov 18, 2019 at 1:38 PM
    Dan8906
    Daniel
    Concord, California
    Any tips on doing a Center support bearing? do I actually need to drop the whole drive shaft out?
  10. Nov 18, 2019 at 1:40 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I didn’t, just took em apart at the bearing and did it under the truck.
    GQ7227 and Dan8906[QUOTED] like this.
  11. Nov 18, 2019 at 1:43 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Dan8906[QUOTED] likes this.
  12. Nov 18, 2019 at 1:57 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    nasty stuff is not for me, do you mean the smell?
    the primer and stuff i am using does not have a weird smell just a solvent and drips stay on my skin for many many days
    that FF is icky nasty stuff, and looking for something better already :bananadead:
  13. Nov 18, 2019 at 1:59 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    It should take you 5 minutes to take the driveshaft off, and will make the job much easier.
    Also, I'd recommend getting a new stake nut too.
    Dan8906[QUOTED] and GQ7227 like this.
  14. Nov 18, 2019 at 2:00 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    how do i know if that center bearing is going out or not?
  15. Nov 18, 2019 at 2:04 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    That was me. You'll likely have to do more than just shoot it with grease into the zerk. Taking it apart and lubing the splines is probably what needs to be done. I'm due for the same.
  16. Nov 18, 2019 at 2:10 PM
    Dan8906
    Daniel
    Concord, California
    Do you have a part number I’m not finding it
  17. Nov 18, 2019 at 2:15 PM
    JasonLee
    15 TRD OffRoad
    xtremewlr, GQ7227 and cruiserguy like this.
  18. Nov 18, 2019 at 2:23 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    GQ7227 likes this.
  19. Nov 18, 2019 at 2:23 PM
    tntacomaguy
    Guess I need to check into it. Probably be like my leaking valve covers, due timing belt, busted cv and a bunch of other stuff and keep putting it off since I never have time to do anything to the truck.
  20. Nov 18, 2019 at 2:30 PM
    JasonLee
    15 TRD OffRoad
    I'm in the same position, with no garage to work in and snow is coming... CV boots, driveshaft slip joint, boxing frame, suspension upgrade, modifying hitch so 32" fits under the bed, bleed brakes, new plugs, air filter, rad cap .... the list goes on. At this point I just do what is most important until a trip is coming, then it becomes a priority to catch up.
