  1. Nov 20, 2019 at 3:09 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Think it's an important mod to do? I just installed my NorthStar AGM last week.
  2. Nov 20, 2019 at 3:11 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I mean Id upgrade the alternator before I upgraded the battery..that's just me.
    Gen1FTMFW, Jiveydude and SwampYota like this.
  3. Nov 20, 2019 at 3:26 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Fair. I swapped my battery because it was starting to off gas and form corrosion around the electrolyte caps. Got tired of cleaning it.
  4. Nov 20, 2019 at 4:19 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    Yeah, I bought the winch then installing it realized I didn’t have enough CCAs in the battery. I bought the battery then realized I don’t have the voltage to properly charge it. I might as well get the higher voltage alternator rather than forcing voltage out of the stock one. Going down the proverbial rabbit hole here.
  5. Nov 20, 2019 at 4:52 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    it never ends...
  6. Nov 20, 2019 at 5:01 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I'm on my factory alternator, with an AGM battery, and have been winching hard for years. :tinfoilhat:
    Would it be better to have higher output/higher voltage/whatever - maybe, but you don't need it.
    Reh5108, GQ7227, jubei and 3 others like this.
  7. Nov 20, 2019 at 5:03 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    1st gens aren't as bad as 2nd and 3rd gens for charging voltage. I'm constantly sitting at 14.4-14.8 with a stock alt.
  8. Nov 20, 2019 at 5:06 PM
    blind cowboy
    blind cowboy Well-Known Member
    Don
    Auburn CA
    2002 TRD XC 5sp
    A new gizmo
    Area51Runner and SwampYota like this.
  9. Nov 20, 2019 at 5:33 PM
    SwampYota
    Jon
    Floor mats
    Think I’m gonna throw it all in and keep an eye on the ScanGauge for a week. If I’m low I’ll get the alternator. Hopefully I’m seeing numbers like yours @Speedytech7. I seem to remember mine hovering around 14.1 when I had it on.
    Area51Runner likes this.
  10. Nov 20, 2019 at 5:34 PM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    Its starting to look like something!
    Brice, chrslefty, Reh5108 and 23 others like this.
  11. Nov 20, 2019 at 5:42 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    My agm battery has been going strong since 2012 with no signs of problems and no booster
  12. Nov 20, 2019 at 6:06 PM
    CHMM
    CHMM GTO
    Gabe
    Castle Rock, Colorado
    2001 TRD Xtra Cab 4x4 Supercharged
    5100s SPC UCAs Energy bushings #70 spring clutch mod Supercharged
    Training someone that doesn’t care did it. I had to redo 4 hours and 60 miles. I peeled out all day. I’m over it now. Time to rotate the tires.
  13. Nov 20, 2019 at 6:19 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    The voltmeter I added to the aux fuse box is typically reading 14.23 - 14.25 @ idle. Going to keep an eye on it but so far I'm happy with the Northstar 24F and my stock alternator.
    What I might do is refresh the aging cables for the alternator. Might as well with all the electrical I've been doing. Have already replaced that pissy little ground wire coming off the battery to the chassis.
    cruiserguy and SwampYota like this.
  14. Nov 20, 2019 at 6:21 PM
    Empty_Lord
    Dan
    Upping the gauge of the wire to the battery (big 3) will do wonders for voltage stability
  15. Nov 20, 2019 at 6:21 PM
    Area51Runner
    My thought as well. :thumbsup:
    cruiserguy likes this.
  16. Nov 20, 2019 at 6:53 PM
    Speedytech7
    I run 2ga to everything, alt to batt, engine ground to batt, batt to fender ground, firewall ground to engine ground... And an extra frame to engine. Oh and an 8ga to the stock fuse box and delete all the stock fusebox wiring that's inline with the alt and batt because it's moronic
  17. Nov 20, 2019 at 6:54 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Nothing wrong with the stock alt really. But the likelyhood of the deep cycle being 100% is not very likely.
    Running Board Man likes this.
  18. Nov 20, 2019 at 7:02 PM
    CHMM
    CHMM GTO
    Gabe
    Sorry. I can’t make out the photo. What is it if? Looks cool.
  19. Nov 20, 2019 at 7:04 PM
    Area51Runner
    Aux fuse box enclosure in the bed of the truck. Blue Sea fuse block, switch panel, relays, USB charge ports, voltmeter, etc. Phone camera, pic uploaded from phone without any editing/cropping :notsure:
  20. Nov 20, 2019 at 7:06 PM
    Empty_Lord
    Dan
    I’ve found 4 gauge to work perfectly fine if it’s of good quality. No voltage fluctuations like stock. Easier to manage
