  1. Nov 20, 2019 at 7:07 PM
    CHMM
    CHMM GTO
    Gabe
    Castle Rock, Colorado
    2001 TRD Xtra Cab 4x4 Supercharged
    5100s SPC UCAs Energy bushings #70 spring clutch mod Supercharged
    Wow. Cool. Never seen it in person.
    Area51Runner[QUOTED] likes this.
  2. Nov 20, 2019 at 7:07 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I'm sure it would be fine. I have three unused spools of Temco EasyFlex OFC 2ga welding cable, so I kinda wanted to use all that and it flexes really nice.
  3. Nov 20, 2019 at 7:30 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Both of mine hover around 14.1-14.3.
    My aux battery is normally .1 less than my main.
    That's with stock alt... I think I'm going to do a Grand Vitara alt this winter.
  4. Nov 20, 2019 at 7:39 PM
    Phessor
    Phessor Well-Known Member
    I adjust my e-brake with the adjustment under the cab.
    Reh5108 and eon_blue like this.
  5. Nov 20, 2019 at 7:41 PM
    eon_blue
    Azusa, CA
    I do that too but I've about maxed it out doing it that way (can hardly reach the adjustment nut with my wrench). Either the cable is too stretched out or I need to adjust it via the drums which I'm not sure how to do
    Running Board Man likes this.
  6. Nov 20, 2019 at 8:59 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Unless your battery is very depleted, say from running a fridge over night while camping, you won't see voltage higher that 14.4 for very long. Voltage readings are an indicator of the rate at which the battery is accepting the charge from the system. After starting up and running for a while those voltage reading will reduce from 14.4+ down to 14.0 to 14.2, depending on the voltage drop in your system.
    Is that part of a dual battery system?
  7. Nov 20, 2019 at 8:59 PM
    FatBilliam
    FatBilliam Well-Known Member
    East TX
    '97 3.4l 5spd Ext. Cab
    Sorry if somebody else already asked, but how did you go about screwing those quickfists to the wheel well? Did you do self-tapping or did you take the fender lining out, drill a hole, and do a bolt/washer/nut?
    GQ7227 likes this.
  8. Nov 20, 2019 at 9:47 PM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    Rivnuts work well for that application
  9. Nov 20, 2019 at 10:12 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Not yet... still in the planning stage. Also want to take another look into solar. Like the look of those Renogy Flexible 100w panels.
    riskadverb likes this.
  10. Nov 20, 2019 at 11:40 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    approx how much length in cable would you guesstimate you used when you did all that?
  11. Nov 21, 2019 at 2:07 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Did anyone make up and offer a group buy for "grounding kits"? Once of my other clubs had a guy that made and sold some some nice 5-wire kits.
    Hint, hint, @BartMaster1234
    Prayn4surf likes this.
  12. Nov 21, 2019 at 6:31 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I think there was. There was also a now banned member that was selling a “big three” wiring kit upgrade.
    CS_AR[QUOTED] likes this.
  13. Nov 21, 2019 at 8:45 AM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    @Prayn4surf got it. I used rivnuts. So they are bolted to the wheel well and riveted. As are the Quickfists on the rail and actually the whole rack for the tent. Rivnuts are awesome.
    Prayn4surf[QUOTED] likes this.
  14. Nov 21, 2019 at 9:06 AM
    bowyer2002
    bowyer2002 always tinkering
    NE Missouri
    01 Taco SR5 D-cab 4WD
    OME 882s, OME shocks all around and OME Dakar spring packs, ARB, Warn 8000, ARE shell, Custom rear bumper w/ reciever, 5-235/80R17 Cooper Discoverer ST MAXX on FJ wheels, grey wire mod, Hi-Lift, Hellas, Red-Line hood lifters, Scion radio, sliders, Safari snorkel & LED Ditch lights on CBI mounts.
    Got my frame (rear only so far) POR15 applied, bed rust holes fiberglassed and hope to re-assemble soon. I still need to replace & replumb the BPV, those parts should arrive tomorrow.
    nagorb, SwampYota, cruiserguy and 6 others like this.
  15. Nov 21, 2019 at 9:17 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    are those some type of frame reinforcement plates with the big circles?
  16. Nov 21, 2019 at 9:26 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I use a nut and bolt and fender washer from the underside but a riv nut is def a cleaner solution.
  17. Nov 21, 2019 at 9:27 AM
    bowyer2002
    NE Missouri
    cruiserguy and GQ7227[QUOTED] like this.
  18. Nov 21, 2019 at 9:28 AM
    bowyer2002
    NE Missouri
    I fastened mine to the inside of the bed with self-tapping screws, it's held just fine for 3 years now.
  19. Nov 21, 2019 at 9:57 AM
    Prayn4surf
    Socal
    I did the same with my quickfists. Rivnuts are awesome
    :fistbump:
    xtremewlr[QUOTED] likes this.
  20. Nov 21, 2019 at 11:05 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
