  1. Nov 23, 2019 at 10:01 AM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Got my oem steering rack for for $500. Well worth not having to change for another 10 years or so.
    CS_AR and cruiserguy like this.
  2. Nov 23, 2019 at 10:08 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Might be a reboxed true OEM at that price. Hope that's not a new garbage one at that price
    CS_AR[QUOTED] likes this.
  3. Nov 23, 2019 at 10:09 AM
    cruiserguy
    Elijah
    SEKS
    I agree, this is one of those types of repairs that it really does make sense to go OEM
    nagorb[QUOTED] likes this.
  4. Nov 23, 2019 at 10:09 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    And the OEM racks come with new inner tie rods and bellows. I think I paid $550 shipped from Camelback toyota.
    CS_AR likes this.
  5. Nov 23, 2019 at 10:22 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    honestly should have pulled mine when installing turbo manifolds. snapped 5 studs off and had to raise engine anyways to drill a couple of em out. was a terrible job on my crusty 95.5
  6. Nov 23, 2019 at 10:23 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    I see the RackDoctor is selling racks starting at $349. I've read good things about the Dr with other cars. Not sure about Tacoma.
    If I had to buy a new Rack tomorrow, I would bite the bullett and get a new OEM for $498. Some of this just isn't worth the headaches on a part that can be a PITA to change.
    https://shop.rackdoctor.net/1995-2004-Toyota-Tacoma-4X4-Rack-and-Pinion-34995-RD19549.htm
    Oh.. On a different car, I had a small rack seal leak. So I would lose a certain amount of PS fluid between oil changes. This is a Dexron III Japanese car like the Tacoma.
    Anyway I started using Valvoline Max Life ATF (Red Bottle) like I see recommended on here for PS fluid. The seal conditioner must have worked on the leak because it stopped. I'm not complaining.
    I just put in new OEM inner tie rods and rack bushings.. I'm down for trying the Lucas PS conditioner that someone on here mentioned yesterday.
    This is the best price that I've been able to find for a new OEM. Though I wouldn't want to see the part discontinued and not have it as an option.
    cruiserguy likes this.
  7. Nov 23, 2019 at 10:25 AM
    devinzz1
    devin
    2023 aclb trd or mt
    i made my truck true dual and had the 02 sensor mounted on one side without issues. i later added an x pipe and put the sensor in the centee of it.
  8. Nov 23, 2019 at 10:27 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    My Rack Dr. rack was junk.
    It started leaking pretty quick, and had poor quality ITRE that developed play right away.
    cruiserguy and CS_AR like this.
  9. Nov 23, 2019 at 10:31 AM
    CS_AR
    I'm not sure I would would completely trust it.. I've had good luck with Cardone rebuilt PS pumps over the years when I didn't want to mess with trying to reseal one on my own. But a PS pump is a very simple thing compared to a Rack that is most likely made in China.
    ROlla-Xrs and cruiserguy[QUOTED] like this.
  10. Nov 23, 2019 at 10:32 AM
    CS_AR
    The rack pictures look like they are remarketing some new stuff as their brand..
  11. Nov 23, 2019 at 10:37 AM
    cruiserguy
    Elijah
    SEKS
    This is good to know type info
  12. Nov 23, 2019 at 10:38 AM
    cruiserguy
    Elijah
    SEKS
    Good to hear on that seal sweller stuff with the max life fluid. Decent options to buy time are a good thing
  13. Nov 23, 2019 at 10:43 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Not today (last week) I parked in the last spot available at the mall.
    CHMM, Silver02Taco, Winkle99 and 7 others like this.
  14. Nov 23, 2019 at 10:43 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    I guess there’s not big harm in it. But if the bank you had nothing on did have an issue you’d be unaware. But to have one bank go bad typically means your screwed anyway
  15. Nov 23, 2019 at 10:44 AM
    cruiserguy
    Elijah
    SEKS
    That would suck. Are there any good remanufacturer of steering racks?
    Over the years something I've noticed with Toyota and Japanese brands is that the companies that do the rebuilds of the more complicated components like auto transmissions, steering racks, the companies that rebuild them suck. One person may get lucky with it, but by far the majority of folks that buy a remanned rack or rebuilt transmission are not happy with it a year or two down the road. A nice niche market opportunity for someone
  16. Nov 23, 2019 at 10:49 AM
    CS_AR
    Speaking of parts, I'll go outside here in a few minutes and jack up a couple of my cars and check on my CV axle experiment. In one of my other clubs, we found a particular type of aftermarket axle was mechanically sound but the grease and outer boots were very low quality and would only last for 3 to 5 years. So I bought a new CV axle, then took it apart, replaced the grease, and installed a new OEM outer boot to create a hybrid aftermarket/OEM axle. I'm about 4 years into that test. I'll take it apart after 5 years (next year) to see how its doing. These are lowered cars that are known to chew up CV axles like our lifted trucks. A new OEM CV axle is way over $500 and the factory rebuilt units are not so good.
    cruiserguy[QUOTED] likes this.
  17. Nov 23, 2019 at 10:57 AM
    1997tacomav6
    Denver
    So you take the driveshaft off them or loosen it anyway?
  18. Nov 23, 2019 at 11:01 AM
    eon_blue
    Azusa, CA
    My mind can't wrap itself around a CV axle being compromised from too little lift....it goes against everything we're told lol. Makes sense though
  19. Nov 23, 2019 at 11:23 AM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    yeah, I was thinking of doing this way. But getting an extra wideband to monitor both sides.
    I’d keep the factory AFR as close to the head as possible though. The further away it gets the longer it takes for your computer to adjust and switch from closed to open loop etc.
    But I’m reality I’m only overthinking this. I’ll never have the time or place to do a custom exhaust with custom headers.
  20. Nov 23, 2019 at 11:24 AM
    Shortman5
    Supercharged TRD
    Damn. Post some pics.
