  1. Nov 23, 2019 at 10:35 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Just @ me if you need anything. I try to keep up.
  2. Nov 23, 2019 at 10:56 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Build your own. Use either mudflaps or thin abs and a hair dryer
  3. Nov 24, 2019 at 4:09 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Yup that’s actually where I put it. Mine doesn’t have ABS.
  4. Nov 24, 2019 at 7:06 AM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    Either the cable is gunked up or the bell cranks need lubing, or both
    GQ7227 and m3bassman[QUOTED] like this.
  5. Nov 24, 2019 at 7:07 AM
    Wulf
    rock raisin
    Got a little done
    chrslefty, jubei and GQ7227 like this.
  6. Nov 24, 2019 at 8:01 AM
    Santos23
    Santos23 Well-Known Member
    Jordan
    2002 Tacoma Double Cab Trd
    Nitto Ridge Grapplers
    Just realized where I put it I can’t get to the back to feed the wires in. What did you use to extend the + and - to the battery? Mine doesn’t reach from abs location
  7. Nov 24, 2019 at 8:11 AM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    At the e brake adjustments under the cab there’s a return spring that can get gunked up. I remove it and clean/lube it sometimes.
    Running Board Man likes this.
  8. Nov 24, 2019 at 8:17 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    That spring popped off on mine once. Worked better with the spring back in place. :oops: Would be a good thing to check @m3bassman
    Also, don't think anyone mentioned it, but it could just be that the adjustment on the frame is excessively loose. Pull the lever on the frame and see what happens, my guess is that it takes quite a bit of movement to get the bellcranks on the backing plates to move. Adjust it so as soon as you move that lever the bellcranks move, then see how it feels.
    FWIW, its taken lots of fine tuning to get my ebrake to work right. I made spacers on the pivot point on the rear axle, all the guides, and the bellcranks.
    cruiserguy and jubei like this.
  9. Nov 24, 2019 at 8:30 AM
    Squeaky Penguin
    Brett
    I think you need to work you way from the back forward. Your cable would be pulled back by spring tension if everything is working right, or you ebrake would be stuck on all the time. Given that's not the case, sounds like you have excessive slack somewhere.
    Are the bellcranks on the backing plate adjusted properly with the adjustment bolt flush again the backing plate? There's a service procedure for setting those adjustment bolts right. Are the springs on those functioning properly? What happens when you pull on the bellcranks themselves?
    Then move to the arm on the frame. What happens when you pull on that? You need to adjust it so the bellcranks on the drums move as soon as you pull on it.
  10. Nov 24, 2019 at 8:46 AM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    Sometimes the accordion boots on the cables tear and allow dirt and dust to get into the cable. Once that happens it takes a lot of lube and working the cable back and forth to loosen things up again
    GQ7227 likes this.
  11. Nov 24, 2019 at 9:09 AM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    This video will help. It's pretty easy actually.
  12. Nov 24, 2019 at 9:28 AM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    My build thread is kind of a mess, and the tubbing work is spread out over a bunch of early posts, starting around page 10, I think.
    Here’s a post on the new engine skirts:
    https://www.tacomaworld.com/threads...orado-gtfo-build.427567/page-26#post-14334216
    And in case you’re looking to close out where the old molded fender liners were that bridged across the outer fender to the core support bodywork, this is what I did:
    https://www.tacomaworld.com/threads...orado-gtfo-build.427567/page-28#post-14583654
    Hope that helps! Hit me up if you have any other questions.
  13. Nov 24, 2019 at 9:49 AM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    I disconnected the cables at the under cab adjustment to push/pull the cables to make sure they’re free
  14. Nov 24, 2019 at 10:12 AM
    Jonyd182
    Jonyd182 What do you mean I can't go up there...Watch this!
    Jonathan
    Columbia, SC
    '99 SR5 TRD 3.4
    Armored to the teeth, 35's, Crawlbox, Boxed Frame
    And back in it goes. With a little luck it'll go up on the first try...:muscleflexing:
    Buuuuut, I'm not usually that lucky.
    Area51Runner, jubei and cruiserguy like this.
  15. Nov 24, 2019 at 11:34 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Whoa! Thats dope! Would make cleaning mud off so much easier
    jubei[QUOTED] likes this.
  16. Nov 24, 2019 at 11:46 AM
    eon_blue
    Azusa, CA
    I ran without fender liners for a short while last year and the amount of mud, dirt and rocks that gets caked along inside the door jambs was nuts. Really made me appreciate the liners.
  17. Nov 24, 2019 at 11:48 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    It's not the most elegant fix, but it'll work.
  18. Nov 24, 2019 at 1:01 PM
    jp59inh
    jp59inh Well-Known Member
    02 Tacoma Extra cab 4x4
    None yet
    Finally a 1 piece drive shaft to eliminate those pesky vibs !
  19. Nov 24, 2019 at 2:03 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Is there a write up on this one?
  20. Nov 24, 2019 at 2:04 PM
    BlackPearl
    BlackPearl Well-Known Member
    Alex
    Toyota Tacoma TRD
    3” lift. Sway a ways 2.5 on 285 75 16 and much more
    I could be wrong but I thought that the extension part was always to be towards the rear diff?
    Yetimetchkangmi likes this.
