  1. Dec 1, 2019 at 4:10 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Waits for 555 = OEM kid*
    Blue92 and JBTacoma like this.
  2. Dec 1, 2019 at 4:36 PM
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
    Well that sucks. I was hoping it was attributed to a manufacturing defect on the lower ball joints. Apparently, that ball joint mount is used on all of Solo’s kits.
  3. Dec 1, 2019 at 4:52 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    well idk. Can't say i've seen the issue surface from others who have their LT kits.
    Going to replace the LBJs soon and see if it was the LBJ or the arms.
  4. Dec 1, 2019 at 5:21 PM
    ChargedSHOTaco
    Hope that fixes it for you. Keep us updated. I ordered a pair of those LCA this Black Friday.
    Blackdawg[QUOTED] likes this.
  5. Dec 1, 2019 at 6:03 PM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    That place is there because the 4-bangers have a linear spring.
    CHMM[QUOTED] and xtremewlr like this.
  6. Dec 1, 2019 at 6:08 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    A lot of progress this weekend. First start.
  7. Dec 1, 2019 at 6:22 PM
    Joey_Bada_Bing
    Joey_Bada_Bing Well-Known Member
    North Carolina
    1st Gen DC 4WD
    A bunch of the same stuff everybody else has already done.
    Well, I finally got this baby all set up! Full OME lift. 883’s and nitrochargers up front, SPC light racing UCA’s, Dakar’s w/AAL and nitrochargers in the rear. Used the Sky’s off road design axel relocation bracket, 3/4” rear biased. Total Chaos diff drop as well. Desperately needs alignment and extended rear brake line. Method NV302 16x8 wheels with Spidertrax 1.25 spacers, and 285/75/R16 BFG KO2 meats.
    Before/after:
  8. Dec 1, 2019 at 6:22 PM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Does anyone know if a larger fuel pump (DW200) runs at different Amperage for proper fuel line pressure?
  9. Dec 1, 2019 at 6:32 PM
    Joey_Bada_Bing
    North Carolina
    1st Gen DC 4WD
    It should operate at 13.5 volts regardless of pressure ?
  10. Dec 1, 2019 at 6:41 PM
    Shortman5
    Supercharged TRD
    Sorry, I meant Amps. IDK. I’m trying to figure out why my fuel trims are a bit high. No vac leaks. I checked everywhere for Vac leaks with propane watching trims and I can’t find any. So I’m looking at fuel delivery now. Before I send my injectors off to be cleaned I wanted to know if it’s a fuel pressure thing.
  11. Dec 1, 2019 at 6:57 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Love the puff of dust on startup! :rofl:
  12. Dec 1, 2019 at 7:52 PM
    Ace115
    Ace115 Well-Known Member
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    Anyone running 18” wheels? Any drawback to going with a larger wheel? I’m putting together my parts pile for the Tundra brake upgrade and assume I need to move up from 16s which is fine by me since mine are pretty thrashed.
    EZ Harley likes this.
  13. Dec 1, 2019 at 7:57 PM
    Shortman5
    Supercharged TRD
    Less sidewall. And the tires are more expensive.
    Pyrifera and Ace115[QUOTED] like this.
  14. Dec 1, 2019 at 7:58 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    You know what the actual reason it's there for is right?
  15. Dec 1, 2019 at 7:59 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Most 16's clear Tundra brakes just fine. I would look for the size tires you want and see what the availability is for 17" or 18" wheels. I'm guessing there will be more tire selection and better prices for 17" wheels.
  16. Dec 1, 2019 at 8:09 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    What bed cover are you running? Do you like it?
  17. Dec 1, 2019 at 8:18 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    To apply pressure to help pedal return to position?
  18. Dec 1, 2019 at 8:19 PM
    CHMM
    CHMM GTO
    Gabe
    Castle Rock, Colorado
    2001 TRD Xtra Cab 4x4 Supercharged
    5100s SPC UCAs Energy bushings #70 spring clutch mod Supercharged
    Ok. Right on. Never had one. I driven one but it was a short trip.
  19. Dec 1, 2019 at 8:30 PM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    Sorry if I missed it.
    Did you contact solo about it, if so what was there solution? More washers?
  20. Dec 1, 2019 at 9:01 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    nice! Same setup I have. You’ll love it.
