  1. Dec 3, 2019 at 11:23 AM
    MattJakobs
    MattJakobs Everything but a Tacoma
    Matthew
    NorCal
    1985 4Runner w/ FlipPac
    A difference in this height could cause the problems that @Blackdawg is experiencing. Even still, I don’t think the heights would be that much of a difference to where he is bottoming out on the threads and needs to use washers and spacers.
    Based on this picture, I think Solo made a mistake
  2. Dec 3, 2019 at 11:34 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    The length and size of the studs on the 4Runner and Tacoma LBJ are the same. 4Runner just looks a little longer b/c the boot is compressed from use. Having been there with Monte when we figured out how to solve his issue with the SOLO LCA, I'd say that it's for sure that the set he got are not right (unless he somehow has horked his LBJs...which well...it is Monte :p). Assuming he didn't though, it's just a question of whether he got the only set, or if there are others.
  3. Dec 3, 2019 at 11:39 AM
    BlackPearl
    BlackPearl Well-Known Member
    Alex
    Toyota Tacoma TRD
    3” lift. Sway a ways 2.5 on 285 75 16 and much more
    I tired using my bros 4runner LBJ and tie rods on my Tacoma and his parts where smaller and didn't work. Looks like the 4runner used different parts.
    Running Board Man likes this.
  4. Dec 3, 2019 at 12:01 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Nope, decided the taco needed them more and 35s and LT is the sweet spot anyway :p
  5. Dec 3, 2019 at 1:29 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    That's the whole convo we've been having, hahahaha. You replied to a post where I had a pic of how they are different. :p :rofl:
    You can use Taco stuff on a 4Runner, but only if you swap out the LBJ and OTRE. Never thought about swapping the other way - no reason to really.
  6. Dec 3, 2019 at 3:24 PM
    jp59inh
    jp59inh Well-Known Member
    02 Tacoma Extra cab 4x4
    None yet
    Finally installed my Apex bumper , wheels and tires. Now for an alignment to push my wheels forward to alleviate rubbing.
  7. Dec 3, 2019 at 4:21 PM
    1997tacomav6
    Denver
    FedEx stop by the house after the Black Friday sale,
    Damn they were fast
  8. Dec 3, 2019 at 4:22 PM
    eon_blue
    Azusa, CA
    Looks good, I have that same bumper I'm picking up in a couple days. Pretty easy to install on your own with a floor jack or did you need an extra set of hands to do it?
    On the subject of alignment, I got my 33s to stop rubbing when I asked the alignment shop to put my caster at 3˚
    Silver02Taco and 1997tacomav6 like this.
  9. Dec 3, 2019 at 5:21 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
  10. Dec 3, 2019 at 6:04 PM
    kuntry09
    kuntry09 Well-Known Member
    Cam
    Douglas, Georgia
    '99 extended cab Tacoma 4x4 converted Prerunner
    Working on replacing U joints, carrier bearing and transmission mount. I noticed in the double cardan there’s a slight catch in it, but only when it’s at the furthest point in the motion on one side. I plan on swapping it with my old pre-4wd conversion shaft, but even that one has a small catch in the farthest point in its range of motion on one side, but it’s feels better than what’s currently on the truck. Is it normal for it to have a slight catch or should it be perfectly smooth in all directions? Just seems odd both would do it.
  11. Dec 3, 2019 at 6:57 PM
    Speedytech7
    It is
    At least that's what's written down in my personal notes from years past
  12. Dec 3, 2019 at 7:06 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Thank you! Correct me if I'm wrong... I don't think it matters between ADD and manual.
  13. Dec 3, 2019 at 7:07 PM
    Speedytech7
    I'm fairly sure it doesn't. It's just the presence of a retaining nut deal to grapple the manual hub base vs a CV axle nut holding the whole shebang laterally.
  14. Dec 3, 2019 at 7:08 PM
    Speedytech7
    @Dirty Pool has a writeup on here that is majorly in depth, search
  15. Dec 3, 2019 at 7:09 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Did you see the service manual Dirty Pool wrote for that job?
  16. Dec 3, 2019 at 7:13 PM
    Speedytech7
    Hey I only ruined one Tacoma, the other got a chance it would have never otherwise gotten.
  17. Dec 3, 2019 at 7:25 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Most vehicles don’t experience rollovers. So you have a point
  18. Dec 3, 2019 at 7:28 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    So it takes three to get it right? Shit
  19. Dec 3, 2019 at 7:31 PM
    Speedytech7
    That poor truck...
    Literally one day later....
    Silver02Taco and BYJOSHCOOK like this.
  20. Dec 3, 2019 at 7:31 PM
    1997tacomav6
    Denver
    Ouch
