  1. Dec 5, 2019 at 7:37 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Umm, not usually, unless it's to replace fluid for maintenance or to bleed the air out of fluid, from being opened up for repair.
    The new clutch is good info though. Might just need to check the adjustment at the pedal.
    If the additional pedal pumps didn't help the shift then likely the hydraulic fluid side is okay, likely.
    There's a decent chance it's the original gear oil in the transmission. Might not hurt to change it out. You already replaced the shifter bushing?
  2. Dec 5, 2019 at 7:42 AM
    Madjik_Man
    Colorado Front Range
    Trying to find that TW member that makes the 1st gen aluminum battery tie downs.
    Having no luck in this forum or the B/T/S ones.
    Can someone link me up? Thanks.
  3. Dec 5, 2019 at 7:47 AM
    cruiserguy
    Elijah
    SEKS
    Dunno who it is but I did see @Speedytech7 just posted up a pic of one he ordered. So he might be able to fill us in here
  4. Dec 5, 2019 at 8:05 AM
    Madjik_Man
    cruiserguy[QUOTED] likes this.
  5. Dec 5, 2019 at 9:25 AM
    eon_blue
    Azusa, CA
    Honestly that's how my 04 has always been...first and second go in more smoothly if I shift them above 3k, anything below that and the shift is more rough. I just attribute it to the nature of the truck. It's definitely not as buttery smooth shifting as my manual trans Scion I had before but it's also a RWD/4wd truck and not a FWD coupe, it did take me some time to accept it as being normal.
    Unless it's not normal and I've just accepted it either way....could be possible
  6. Dec 5, 2019 at 9:28 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    Ya I always thought the general consensus is that MT are not buttery on 1st gens. In order for me to go into first while coasting I have to get it down to like 5 mph. and even then I have to give it a good push for it to slap into gear. If I try to go into second the truck nearly bogs out at the speed. My only gripe but like @eon_blue said above, should be normal
  7. Dec 5, 2019 at 9:29 AM
    eon_blue
    Azusa, CA
    Oh yeah for downshifting into 1st you have to nearly be at a stop, unless you really force it in which you don't want to do. But yeah that's normal though for 1st gear
    Das it mang[QUOTED] likes this.
  8. Dec 5, 2019 at 9:30 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I rarely downshift into first. Second is as low as I will go if I'm still moving.
  9. Dec 5, 2019 at 9:32 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    Thought it was bad to bog out the truck tho? is it worse to "get it" into first? for me when I dump into neutral going over speed bumps I try to go back into first because with going into second I can feel the whole truck bogging lolol
  10. Dec 5, 2019 at 9:34 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    @Coupe
  11. Dec 5, 2019 at 9:34 AM
    eon_blue
    Azusa, CA
    He means with downshifting, so like if you're coming to a stop. Some people put it in neutral and come to a stop, some people like to downshift and save the brakes. If I downshift I'll go down to 2nd gear and then put it in neutral and use the brakes until I come to a complete stop.
    When you're upshifting you don't want to bog it down by being in a high gear/low RPM scenario
  12. Dec 5, 2019 at 9:35 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    Oh and sometimes when I park on a slope I have to pull e brake and let the truck roll a bit to go into R. Sure that's normal but this is my first MT
  13. Dec 5, 2019 at 9:36 AM
    Madjik_Man
    Yup, already in touch with him via PMs
  14. Dec 5, 2019 at 9:36 AM
    eon_blue
    Azusa, CA
    Reverse can be finicky on these trucks...I sometimes have to clutch it 2 or 3 times from a stop to get it to grab reverse.
  15. Dec 5, 2019 at 9:41 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    OHHH.. My bad still drinking my coffee I'm dumb lol. Ya I havent even tried going to 2nd for engine braking, I've only gone to third. Might try second now if it aint too bad then, thanks! So then in my circumstance I was describing , I really am not doing something dumb right? always feel so weird having to give it a go to go into first, and the RPMS it hits at like 5 mph are actually good, vs second like I said.
    And I just saw the response about Reverse, thank you for the reassurance! I have to do that as well, glad to know it's fine. This forum can be a savior for people who worry
  16. Dec 5, 2019 at 9:47 AM
    eon_blue
    Azusa, CA
    yeah 1st gear is pretty low, by the time I'm at 3500 rpms I'm probably doing like 18mph or something like that, I can't say I've ever really paid attention to the exact speed but I have to go into 2nd pretty quickly to really get the truck going.
    The one thing I have going on that bothers me from time to time is I will on occasion get a pretty big 'jolt' coming from right under me where the trans is if I do a normal/quick shift. Only way to avoid this from happening is to constantly slowly let off the clutch which isn't always possible. I think a couple years ago I got it to go away by tightening the trans mount bolt, I'll have to see if that is loose again. Or maybe it's the mount itself.
  17. Dec 5, 2019 at 10:43 AM
    Panchovilla6192002
    Panchovilla6192002 Well-Known Member
    Arizona
    2019 Cavalry Blue TRD SPORT 4X4 DCSB MT 2003 Red ExtraCab MT 5 lug
    Shifter bushing replaced. It helped a lot when the truck is moving. Not when at a stop.
    I’ll try changing the fluids. Thanks. I’ll keep you guys posted.
    My dad has a 95 pickup. It shifts a lot smoother.
  18. Dec 5, 2019 at 10:48 AM
    eon_blue
    Azusa, CA
    Sounds like there might be an issue with yours then, the hard thing about diagnosing this stuff online is that one person's idea of rough shifting might be another person's idea of normal. But if it's a lot rougher than your dad's truck of a similar year then there's no denying something might be up.
    Since you replaced the bushing the next clear step would be to change out the fluid. I would get your hands on some Redline MT90 gear oil for the manual trans, it makes a big difference in shifting feel and there are a lot of good reviews about it on this site alone. Its the only stuff I use now
    xtremewlr likes this.
  19. Dec 5, 2019 at 12:45 PM
    Panchovilla6192002
    Arizona
    I’ll try that. Thanks.
    eon_blue[QUOTED] likes this.
  20. Dec 5, 2019 at 2:37 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Trip to Trail Gear = Successful :thumbsup:
    CS_AR, BYJOSHCOOK, Phessor and 6 others like this.
