  1. Jan 1, 2020 at 2:17 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Must be a weak impact.
  2. Jan 1, 2020 at 3:52 PM
    Robmonster117
    Robmonster117 Well-Known Member
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    My thoughts exactly. I opted to go slightly below factory torque with some blue locker because the old bolt was stretch a good bit and I didn’t feel like snapping another one.
    Area51Runner likes this.
  3. Jan 1, 2020 at 3:53 PM
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Shes all back together now and the shakedown went well.
    Unfortunately the oil pan reseal did not solve my problems and its still leaking a lot of oil out what I’m now sure is the rear main seal.
    So the engine will be pulled this spring and replaced with a lower milage one since Im going through all the trouble of removing it anyway.
  4. Jan 1, 2020 at 4:00 PM
    Empty_Lord
    Dan
    Fair warning. Replace the seals on the new engine. Those low mile ones leak like no other once they start getting driven
    Robmonster117[QUOTED] and GQ7227 like this.
  5. Jan 1, 2020 at 4:06 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Get some ATP 205 and dump it in on your next oil change. That will slow down, if not completely stop, the rear main leak.
  6. Jan 1, 2020 at 4:35 PM
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Oh yea definitely I will. I'm super picky with any used engine. If I cant find one worth taking and resealing then I can always opt for the money route and get a reman with a warranty also.
    Empty_Lord[QUOTED] likes this.
  7. Jan 1, 2020 at 4:37 PM
    Empty_Lord
    Dan
    my experience with reman has been.. eh pretty bad! lol oem used is best bet as long as its checked out and looks good.
    put a jasper reman in a customers camry... 3 engines later we finally got one that made it to 5k miles. first 2 popped headgaskets
  8. Jan 1, 2020 at 4:42 PM
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    yikes... that is not ideal. there are a couple Toyota specific engine rebuilders around me that have a pretty good reputation for quality work. It does pay to be a skeptic though. I haven't been satisfied with any shops I've had do work for me in a long time.
  9. Jan 1, 2020 at 4:45 PM
    Kevins60
    Kevins60 axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
    Finally got around to replacing my 15 year old coilovers with Monroe Quick Struts.
    Speed bumps don’t knock my fillings loose now.
  10. Jan 1, 2020 at 4:45 PM
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Too many horror stories. that stuff essentially "bloats" all your rubber seals and can cause more damage than it solves. Not a risk I want to take.
  11. Jan 1, 2020 at 5:10 PM
    Mojave4x
    Mojave4x Active Member
    98 SR5 4x4 extended cab 3.4 5speed & 08 limited 4Runner 4x4 4.0
    Detroit TrueTrac both diffs, re-gear 4:30, Wheeler's 8 leaf, OME 881, JBA UCAs, Bilstein 5100 all 4 corners, All new u-joints & ball joints, new LCA bushings
    Added 255/75/17 on Sequoia wheels
    ireymon, chrslefty, JPinFL and 11 others like this.
  12. Jan 1, 2020 at 5:11 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    I can attest to this.
    CS_AR likes this.
  13. Jan 1, 2020 at 5:24 PM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    Went out and bought some Red N' Tacky for the drive shaft and some Super Lube for my TC UCA's. It was my first time greasing the UCA's. Took me a little bit to figure out it was easier re-torquing them from the engine bay than from within the wheel well. :facepalm:
    Area51Runner and cruiserguy like this.
  14. Jan 1, 2020 at 6:07 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    polished some chrome, total badassery :cool: it is
    no pics. overcast, hazy, gettin dark and cold out
    #hardcoretacolife
  15. Jan 1, 2020 at 9:24 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Yep
    Phessor and cruiserguy[QUOTED] like this.
  16. Jan 1, 2020 at 9:27 PM
    Ace115
    Ace115 Well-Known Member
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    Installed some gear tie downs towards the end of the bed. Getting ready for the next upgrade
    chrslefty, JPinFL, Phessor and 6 others like this.
  17. Jan 1, 2020 at 10:49 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    If you're running straight synthetic oil it will cause weak seals leak.
    Ask me how i know.
  18. Jan 1, 2020 at 10:50 PM
    Empty_Lord
    Dan
    i wonder if it has something to do with being a mechanic.
  19. Jan 2, 2020 at 4:59 AM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Got the Taco a slightly younger sibling. 2003 4Runner V8 Limited.
    Kwikvette, chrslefty, JPinFL and 11 others like this.
  20. Jan 2, 2020 at 6:48 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    That bolt like @nagorb said looks tapered in the center where it sheared. Also that bolt is different than the ones I received from Toyota.
    nagorb likes this.
