  1. Jan 8, 2020 at 12:15 PM
    tacojim02
    tacojim02 Well-Known Member
    Puxico, Missouri
    02 dbl cab trd
    2in suspension lift
    I think I have a set of those will have to check. one of them had the plating popping loose I was going to black them out. have steelies that were on when purchased and don't care for them. So looking for something to stay under fender well. got bfg's on them and thought I would wear them out before swapping. they throw too much crap up the side of my truck, live on gravel.
  2. Jan 8, 2020 at 12:56 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I see Andrew's trying to catch up to your tire size lol
  3. Jan 8, 2020 at 2:17 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    that is the best story of 'how did i find out about TW?'!
    Gyrkin[QUOTED] likes this.
  4. Jan 8, 2020 at 4:08 PM
    Wadar
    Wadar Not Well Know, But Shows Up From Time to Time.
    Wade
    Western Slope, Colorado
    ‘02 XC TRD-OR, & ‘20 DCSB TRD-OR
    A few.
    Good question, it’s also been 18 years and I lifted the truck in 2015 which may have something to do with it. I did replace LBJ’s and outer tie rods summer of ‘18. :notsure:
    GQ7227[QUOTED] likes this.
  5. Jan 8, 2020 at 5:46 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    16xx gallons filled the tank @ Shell ... 1st one of the '20s
    '90s
    '00s
    '10s
    '20s
    somehow i wanna say that is 4 decades but it just doesn't sound kosher :confused:
    also scrubbed the passenger window hard with the shell squeegee
    somehow my green sponge had transferred stuff from the undercarriage to the windows and smeared them bad in the sun
    bot new sponge :spending:
  6. Jan 8, 2020 at 6:03 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    tacojim02[QUOTED] likes this.
  7. Jan 9, 2020 at 6:08 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    :drool:
  8. Jan 9, 2020 at 11:38 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
  9. Jan 9, 2020 at 12:09 PM
    tacojim02
    Puxico, Missouri
    02 dbl cab trd
    2in suspension lift
    You interested?
  10. Jan 9, 2020 at 12:16 PM
    Ace115
    Ace115 Well-Known Member
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    Put it on so I can see how it looks installed!
    Area51Runner[QUOTED] likes this.
  11. Jan 9, 2020 at 12:17 PM
    Area51Runner
    I'll tag you once its installed. Probably will be a bit though. On the list but not a priority. Just want to do away with that clock really.
  12. Jan 9, 2020 at 12:23 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Nice!
    I just picked up the radio switch panel from them too.
    Threw some satin black paint on it and it looks great. Hopefully will get around to installing it after work today.
  13. Jan 9, 2020 at 12:24 PM
    Area51Runner
    Yep, that panel is nice! Blends very well.
  14. Jan 9, 2020 at 12:25 PM
    tacojim02
    Puxico, Missouri
    02 dbl cab trd
    2in suspension lift
    Replaced upper cat but used old sensor. Well sensor was changed a few months back. anyway both cats both sensors are replaced 5 days of regular driving and ck engine light come back on with a po420 code, i'm like wth is the deal. what else is there to ck? could the fact that I ran a new upper sensor for so long before I changed the upper cat might have damaged the sensor. it really started popping and jerking and running rough right before Christmas and that's when I changed the upper cat. drove it about 20 miles to get it home. limped it along.
  15. Jan 9, 2020 at 4:57 PM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    Looks like it came factory,
  16. Jan 9, 2020 at 5:24 PM
    DiverDan
    DiverDan Member
    99 Prerunner
    After previously removing all front suspension and steering parts up to and including the rag joint, installing upper ball joints, upper and lower CA bushings and front wheel bearings, today I started washing, wire brushing, wire wheeling and sanding sway bar, upper and lower CA's and knuckles to get them ready for painting. Thought about powder coating but decided to spray paint suspension parts with POR15 rust preventative and follow up with POR15 gloss black top coat (for easier cleaning). Will pressure wash frame and wheel wells this coming weekend while the truck is up on stands.
  17. Jan 9, 2020 at 5:38 PM
    betterbuckleup
    Ian
    Concord, CA
    I won't be able to either but I didn't wanna move the clock or put it anywhere else on the dash. And I don't really ever use that cubby under the radio anyways.
    I'll have Front & rear locker, compressor, & then i'll have to add some more when I get some more lights at some point.
  18. Jan 9, 2020 at 5:53 PM
    drewmo
    drewmo Well-Known Member
    1995.5 4x4 Taco
    I got my new corner lights and license plate lights. Going full legal. :D
  19. Jan 9, 2020 at 7:27 PM
    nw_chris
    nw_chris Outside Everyday
    Albany, OR
    2022 DCSB TRD-OR
    Weekend plans showed up in the mail
    SwampYota and Area51Runner like this.
  20. Jan 9, 2020 at 7:31 PM
    Hooks98tacoma
    Hooks98tacoma Well-Known Member
    Georgia
    98 Tacoma 2.4
    What’s the little digital screen in front of your cluster?
