  1. Jan 13, 2020 at 7:25 PM
    kuntry09
    kuntry09 Well-Known Member
    Cam
    Douglas, Georgia
    '99 extended cab Tacoma 4x4 converted Prerunner
    For the record and future reference, PN 90311-35047 is the INCORRECT PN for the front pump seal on a 3.4 auto trans. Toyotaparts deal has it completely wrong and that PN is not even associated with a Tacoma according to other parts sites. Part Number 90311-38020 is the CORRECT PN for the front pump seal, confirmed by multiple sites and a local dealer. Jokes on me, should have checked...will double check anything else ordered from toyotapartsdeal from now on.
  2. Jan 13, 2020 at 7:25 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Not bad at all
    1997tacomav6 likes this.
  3. Jan 13, 2020 at 7:30 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Man! For real! That came out great!
    Bonus points for originality :thumbsup:
  4. Jan 13, 2020 at 8:37 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Do you have a photo of how you mounted the 3rd gen grill to the back of the 1st gen grill?
    CrustyTaco likes this.
  5. Jan 13, 2020 at 8:46 PM
    Captain Magma
    Captain Magma Well-Known Member
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    Kings and desert pinstripes
    I did all 4, tore up the boot on the underside trying to get the "lower" 2. I'll play around with the linkage this weekend to try and snug it up a little. Maybe make a makeshift boot for the underside while I'm in there
  6. Jan 13, 2020 at 8:47 PM
    tsab916
    tsab916 Well-Known Member
    Sacramento
    02 DC 4x4
    I don't, I can take one for you if you want it, just message me, but all I did was make a cardboard templet of the inside of the 1st gen grill and kept trimming and test fitting the 3rd gen grill until it fit inside of the 1st gen grill, then I just hot glued it in. Well see how the hot glue holds up, if it doesn't I'll epoxy it in.
  7. Jan 14, 2020 at 4:38 AM
    Ace115
    Ace115 Well-Known Member
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    I’m noticing a lot more slop in my shifter lately and feel like I need to get this done. @Captain Magma wanna help?
    Who did you order the parts from?
  8. Jan 14, 2020 at 5:33 AM
    Captain Magma
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    @Brice, I'd be down depending on when you wanna do it
    Brice likes this.
  9. Jan 14, 2020 at 6:36 AM
    1997tacomav6
    Denver
    Thanks, so how do these struts work for adjustments.
    I want to keep my truck at stock height.
    I believe they come with a preset 2” setting adjustment from the factory.
    So what do I need to do for adjustments or preload if anything on these struts to keep my stock height?
    GQ7227 likes this.
  10. Jan 14, 2020 at 6:43 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Just buy a coilover spanner wrench. The only other thing they need is an allen key for the set screw on the adjuster. If you order Kings make sure to get some weaker springs. Like 550 or maybe 600. The stock 650s are way too much for your light little truck.
    1997tacomav6[QUOTED] likes this.
  11. Jan 14, 2020 at 6:47 AM
    1997tacomav6
    Denver
    Ok, so do I have to adjusted them to zero setting? Instead of 2”?
    On the truck or before the install?
    Pre load stays the same?
  12. Jan 14, 2020 at 6:58 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    You can do either, the spanner wrench adjusts the coil collar, which will make the preload on the springs less.
    If I remember right.
  13. Jan 14, 2020 at 7:10 AM
    1997tacomav6
    Denver
    Ok, I did email down south and he said they can adjust them before they ship them.
    What setting should I have them set at? For stock?
    I probably will install them myself,
    But am I missing something because
    Toytek said it was a 4 hour job to install these and would cost 520.00 to install?
    GQ7227 likes this.
  14. Jan 14, 2020 at 7:16 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    :jerkoff:500 bucks to swap out the two front coil overs??? You're not missing anything other than money in your pocket if you have them do it for that much. I'd be surprised they charge a regular customer of theirs that much for something like that. I've been surprised before though by business practice
    jubei, nagorb, JasonLee and 1 other person like this.
  15. Jan 14, 2020 at 7:20 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    how does it take 4 hours?
    and how bad are the roads in the Denver area?
  16. Jan 14, 2020 at 7:22 AM
    1997tacomav6
    Denver
    That’s what I thought, it should be 45 minutes per side unless I was missing something.
    Ok thanks
    cruiserguy[QUOTED] likes this.
  17. Jan 14, 2020 at 7:29 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    these are the local road conditions for me everyday,
    its near city wide too , not just the fast paced freeway
    5 mile stretch of stuff like this waiting to happen across 5 lanes
    [​IMG][​IMG]
    Das it mang likes this.
  18. Jan 14, 2020 at 7:36 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    That's a mini whoop for me to jump if I see something like that driving lol
  19. Jan 14, 2020 at 7:38 AM
    JKO1998
    Utah
    There aren’t really any settings like Bilsteins, just a big threaded tube. Just have them set them to whatever they think stock is, then you can adjust for settling and such
  20. Jan 14, 2020 at 7:43 AM
    nw_chris
    nw_chris Outside Everyday
    Albany, OR
    2022 DCSB TRD-OR
    I've been debating upgrading from the 650's to 700 lb springs myself but my truck is a bit of a pig soo..
