  1. Jan 21, 2020 at 8:40 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    You really only need new control arms if you’re lifting your truck or you gonna use it. From what I understand.
    If I were you, keeping my truck stock height (if I remember right), I’d just refresh the stock arms and roll with it.
    But if you’re stuck on them I’d look for something other than uniball.
  2. Jan 21, 2020 at 8:50 PM
    1997tacomav6
    Denver
    My upper control arms have 615,000 miles.
    Figured the joints all need to be replaced and a complete setup would be easier to install and a bit more strength added for the UCA ball joint, with the kings and add a leaf for towing I gained 1” lets say.
    cruiserguy likes this.
  3. Jan 21, 2020 at 8:59 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    I would stay with something that used a ball joint over a uniball. If you want the coolest, was it ICON that came out with a ball joint called Delta Joint? . And it could be run in any uniball spot i think. Super beefy and extra range of motion. I think. I better look at it again
    1997tacomav6[QUOTED] likes this.
  4. Jan 21, 2020 at 9:13 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    You really only need new UCAs if you can't get a good alignment with the stock UCAs. Get the alignment first and then see if you need to drop $500.
  5. Jan 21, 2020 at 10:08 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    What these guys say.
    I went for 5 or so years with stock arms and it worked just fine. I finally switched to jba uppers due to ball joints and bushings going bad. I've been happy with them for about a year now.
    GQ7227 and 1997tacomav6[QUOTED] like this.
  6. Jan 21, 2020 at 10:47 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    youd probably benefit from the SPC arms more than anything.. at 1" of lift you dont really need all the castor added by the uniball uppers.
  7. Jan 22, 2020 at 3:23 AM
    1997tacomav6
    Denver
    Sounds like that will be my choice then
  8. Jan 22, 2020 at 3:34 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    You dont need afternarket UCA's with 1.5" of lift.
  9. Jan 22, 2020 at 3:40 AM
    Phessor
    Phessor Well-Known Member
    Don't dismiss JBA.
    nagorb likes this.
  10. Jan 22, 2020 at 3:43 AM
    1997tacomav6
    Denver
  11. Jan 22, 2020 at 3:50 AM
    Phessor
    nagorb and 1997tacomav6[QUOTED] like this.
  12. Jan 22, 2020 at 4:56 AM
    Empty_Lord
    Dan
    The jba is nice, but I think he’ll end up with too mucb castor for his list. Maybe not. But I’ve never tried uppers with less than 2” lifts
    Phessor[QUOTED] likes this.
  13. Jan 22, 2020 at 5:02 AM
    JKO1998
    Utah
    Like everyone else has said, you don’t really need UCAs until your lift starts to affect your alignment, 1” shouldn’t do that.
    Really just new bushings and a balljoint if you need it. The stock joints have been plenty strong for 615k, why change it.
    Just my opinion
    1997tacomav6[QUOTED] and Phessor like this.
  14. Jan 22, 2020 at 7:37 AM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    Unless you plan on offroading it the stock arms is all you should need and rebuilding them will save you up to $600
  15. Jan 22, 2020 at 7:38 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    My truck was bought with one installed and I love it. Coming from a 2nd gen 4Runner the throw is super noticeable. I go back home and drive the 4runner every now and then and it feels so odd compared to my truck. Highly recommend the short shifter
    nagorb likes this.
  16. Jan 22, 2020 at 8:44 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Ah I have those too, still haven't addressed it.
    This ^ I was lifted on stock arms for years.
  17. Jan 22, 2020 at 9:19 AM
    Running Board Man
    Running Board Man Well-Known Member
    My upper bushings were no longer vulcanized somewhere around 250 and the upper joint started clunking over bumps around 270... i salute those bushings and balljoint
    cruiserguy and Phessor like this.
  18. Jan 22, 2020 at 9:25 AM
    2002Tacoma4x4
    2002Tacoma4x4 TRD 4x4 double cab
    C K
    Limited Edition Double Cab TRD off road 4WD
    Do you have to extend the brake lines due to the J59 springs?
    I just lurking for this quality of springs combine with 5100 all around set to 0 , don't wan't to go high .... prefer to stay as close as possible to stock BUT WITH SMOOTHEST RIDE AS CADILLAC...... :D
  19. Jan 22, 2020 at 9:27 AM
    1997tacomav6
    Denver
    They are making lots of noise now over any slow bump now, so time to address them
  20. Jan 22, 2020 at 9:28 AM
    cruiserguy
    Elijah
    SEKS
    We're getting old, my brother! :rofl:
    2002Tacoma4x4[QUOTED] likes this.
