  1. Jan 27, 2020 at 7:44 AM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Great product, they just aren't geared for the supply/demand thing. It's great they only use all US produced materials too but if there is a supply shortage, they don't make shit and ignore the demand. There are good, viable options for non-US made materials that they could use temporarily and not compromise product quality.
  2. Jan 27, 2020 at 7:54 AM
    1997tacomav6
    Denver
    Good to know,
    I’m going to put this on my want list.
    Called and they will be back in stock in 4-6 weeks
    Kiloyard and xtremewlr[QUOTED] like this.
  3. Jan 27, 2020 at 7:57 AM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    I did . It was a pain in the ass to get one part of it done but otherwise not to bad to put in. I waited for a like 6 months for them to be in stock. I think that they sell out quick and they use them in there rebuildt transmissions. So he must only do small batches.
    I do like it . It dose seems to get better every time I drive it. My shifter doesn't wanr to pop out of gear any more. And the stick is up higher so that's nice too. And it's a nice engagement. My stick always come loose though I think I need to lock-tite it.
    Ace115[QUOTED] and 1997tacomav6 like this.
  4. Jan 27, 2020 at 8:09 AM
    Morden
    Morden Well-Known Member
    Cali Central Valley
    2002 Tacoma TRD PreRunner
    Cleaned the throttle body and IAC valve & wound up with a rough, stuttery idle. I was mystified...all vacuum hoses and electrical connections were secure and I used a new gasket (aftermarket). Cables were also properly adjusted as well, but she just wouldn't idle or run well below 2K rpm and to add insult to injury she also popped a CEL. I searched various threads here and also tried disconnecting the negative battery cable for ten minutes, but to no avail. Made some coffee and gave the situation some thought and wondered if the gasket was the issue so I decided to reinstall the stock one, which is thin steel compared to the thicker O'Reilly's part. Pulled the battery cable again, did the swap, buttoned everything back up and lo, back to her old self (still a little rumbling on idle but better than it was. Probably won't be buttery smooth until I replace the IAC assembly altogether). The CEL was also gone.
    Root cause of the problem was this bastard:
  5. Jan 27, 2020 at 8:38 AM
    Tacotimer
    Tacotimer Shade tree mechanic in training
    Harry
    OR
    01 DC SR5 4x4
    OEMs are filled with grease. Not sure what kind. In the pics I had wiped off most of the grease that had leaked out of the tops. The new ones have the same rubber grease boot design. I kinda wish the OEMs had zerk fittings like some aftermarket ones do.
  6. Jan 27, 2020 at 8:47 AM
    00_5VZ
    00_5VZ Dumbest smart guy you’ll ever meet
    Rob
    Thornton, CO
    2004 DC TRD, S/C, Impulse Red Pearl
    TRD S/C, URD 7th injector, Deck plate mod, gray wire mod, 2 low mod, magnaflow cat back exhaust
    I had one in my 2000 Tacoma and it was great!!!! Just be prepared for gear noise coming up through the shifter. It’s a 2 piece with no rubber isolator like the stock shifter handles have.
    1997tacomav6[QUOTED] likes this.
  7. Jan 27, 2020 at 8:57 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    From what I have read, the grease isn't really for lubrication. The metal ball rides inside of a liner. The grease is there in the beginning to condition the liner and keep water/moisture out.
    https://www.tacomaworld.com/threads/check-your-ball-joints.374853/page-2#post-10284167
    The aftermarket joints have a zerk for grease because they need the grease to function. They have a metal ball in a metal socket, so the grease helps to slow the wear down.
  8. Jan 27, 2020 at 9:12 AM
    Hooks98tacoma
    Hooks98tacoma Well-Known Member
    Georgia
    98 Tacoma 2.4
    I’ll have to check it with it running so
    cruiserguy[QUOTED] likes this.
  9. Jan 27, 2020 at 10:20 AM
    Tacotimer
    Harry
    OR
    01 DC SR5 4x4
    I didn't know that about the OEMs. Thanks for the info. I'm even happier that I went with them now. There is so much good information on this site its incredible!
    cruiserguy likes this.
  10. Jan 27, 2020 at 10:40 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    ...While on the Ring Loop hike, we'd spotted an ideal spot for camping just to the south of Hole in the Wall, and we made our way that direction so we could get setup and start dinner before the sun set completely. It was perfect timing as it turned out, a break in the clouds along the horizon providing an amazing show for us as the sun lit the sky from below. Combined with the snow-capped mountains, and tasty grilled hot dogs, it was a great way to...
    Well, you'll see... in Mojave Redemption #4 - Hidden Mines and Highway Robbery
  11. Jan 27, 2020 at 12:44 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Basically haha, I was going to go with their clutch kit but it was out of stock and didn't feel like waiting
  12. Jan 27, 2020 at 1:12 PM
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    Dose any on know what this module dose it says inigiter on it. Is it for the airbags?
    Has anyone ever relocated there cruise control module??
    Aslo I move my ditch lights down to my bumper. I think that they will work nicely as fogs. I'll find out tonight when I can aim them.
    Yetimetchkangmi and SwampYota like this.
  13. Jan 27, 2020 at 1:37 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    I don't know what that igniter module does but I moved mine to hang off a bolt on the windshield wiper motor and then moved my cruise box closer to the air cleaner box to make room for my air compressor.
    jubei and chrslefty[QUOTED] like this.
  14. Jan 27, 2020 at 2:02 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Ignition Model / Computer Video https://www.amazon.com/vdp/d2ea6ccdfe04422b8a16ef92fc938ded
    chrslefty[QUOTED] likes this.
  15. Jan 27, 2020 at 2:36 PM
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    Do you happen to have a pic??
  16. Jan 27, 2020 at 2:38 PM
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    JasonLee[QUOTED] likes this.
  17. Jan 27, 2020 at 3:32 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    I just noticed your name and avatar, haha. They are damn good tacos. In my travels with work I went through Auburn, WA and stopped at a Taco Time, it looked like it should’ve been an office building:
    Tacotimer[QUOTED] likes this.
  18. Jan 27, 2020 at 3:47 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Ignition module is actually bolted to the rubber boot thing leading into the cab. You have to untangle part of the loom to move it but there's no re-wiring, just rerouting. The cruise I moved forward as much as possible and only had to drill a couple holes for rivnut inserts.
  19. Jan 27, 2020 at 4:08 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    From reports around the web 4-6 weeks means months for them. It's a shame cause they make some nice stuff.
    I had been trying to find info on what grease is used, looked like a type of silicone paste rather than a normal moly grease. Thanks for the info!
  20. Jan 27, 2020 at 5:42 PM
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    Small world. I lived a few blocks from there for years. Have eaten a metric fuck ton of food there (as well as the Arby's just off to the left of this pic). That glass building used to be a bank.
    Tacotimer and SwampYota[QUOTED] like this.
