  1. Jan 29, 2020 at 1:53 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    xtremewlr[QUOTED] and Phessor like this.
  2. Jan 29, 2020 at 2:00 PM
    TacoSauce04
    TacoSauce04 Well-Known Member
    David
    2004 Lunar Mist SR5 TRD Double Cab 4x4 Tow Package
    ARE Shell
    I photoshopped this exact idea for my truck last year... it looks awesome.! I'm glad it worked out for you. Any tips for a smoother install now that you are done?
  3. Jan 29, 2020 at 2:35 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    Quick question on bed hooks. :crapstorm: What is the thread size/pitch of those screws/bolts? Have the hooks, that someone had pulled while removing the bed liner out of the bed that I purchased here in Florida. Just need to pick some up at Home Depot.
  4. Jan 29, 2020 at 3:55 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    You can try the local toyota, it's pretty cheap online.
  5. Jan 29, 2020 at 3:58 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
  6. Jan 29, 2020 at 4:15 PM
    Hooks98tacoma
    Hooks98tacoma Well-Known Member
    Georgia
    98 Tacoma 2.4
    On our 89 with the 22re we bought a throttle body gasket from the parts house and it had a extra little ear cut out and it leaked.
    nagorb[QUOTED] likes this.
  7. Jan 29, 2020 at 4:16 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    I want to say it's 1.5, but if you remind me later tonight I can get it for you.
    Edit had a set of gages in the truck for some reason, it's 1.25
  8. Jan 29, 2020 at 4:30 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Not on mine
    Edit:
    You may be right. For some reason I thought I pulled a flat square gasket with two holes for bolts off. Maybe I'm just hallucinating. Would explain why I can't find it around anywhere... :facepalm:
    The name on that is misleading. It goes between the air box and the tube the sensor is mounted on. I need the one between the MAF and tube.
  9. Jan 29, 2020 at 4:39 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    So the one under the sensor? It's just an o-ring I thought.
    Reh5108[QUOTED] likes this.
  10. Jan 29, 2020 at 5:35 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    I did the same thing, cause that's what I read on the internet. Got home and realized it was a no go. So maybe they used both. I just said screw it and taped again, works just fine. Someday I'll fix it good n proper, but I've got to figure out something other than aluminum, it gets too hot and to cold.
  11. Jan 29, 2020 at 5:59 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    Nice! Now that you mention it. I happen to have a piece of drop sitting in my cart, it's the perfect size as well.
  12. Jan 29, 2020 at 6:14 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    Yes.
    Titus94[QUOTED] likes this.
  13. Jan 29, 2020 at 7:11 PM
    tsab916
    tsab916 Well-Known Member
    Sacramento
    02 DC 4x4
    DONT USE A SAW ZAW!! Lol dam thing is too violent, broke some of the tabs.
    Take your time, and use the correct tools, I recommend a dremel, its has many attachment options that will work for this project.
    When you cut the 1st gen grill just cut out the grill and leave the "rim" so you'll have a dish like look when your done.
    For the pro grill if I did it again I would concentrate on fitting the center piece evenly on to the 1st gen grill because the outside of the pro grill won't be sitting inside of the rim of the 1st gen grill unless you like it like that. Doing it like that will give it a deep dish look, which i liked more.
    And use 5min epoxy, hot glue doesnt work..lol almost had to make a 2nd grill.
    Take your time and measure twice.
    Let me know if I can be of any help
  14. Jan 29, 2020 at 7:14 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    It's just an o-ring that you want right? Or do you want the weird square 4 bolt one for the 4 banger maf tube to airbox
  15. Jan 29, 2020 at 7:17 PM
    Speedytech7
    Lol same here. I heard drop and immediately thought there's no way, but sure enough there's two more of us floating around.
    cruiserguy and nagorb[QUOTED] like this.
  16. Jan 29, 2020 at 7:19 PM
    Speedytech7
    Nice! I work for a job shop, what I'm building depends on the day and hour.
  17. Jan 29, 2020 at 10:23 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    I can't/don't want to say publicly. But a super awesome one. Don't mind saying in pm though.
    I used to work job shops, mostly fabrication, we did some pretty cool stuff. It keeps you on your toes, and always thinking/learning. But there's times when you just wanna go on autopilot.
    And benefits and job security are nice.
    cruiserguy likes this.
  18. Jan 30, 2020 at 12:14 AM
    Falkor1
    Falkor1 Well-Known Member
    David
    Arizona
    95.5 Tacoma 2.7 4x4
    2,000 Tacoma rear axle with E-Locker.
    2B4C61FF-C0E3-4824-B36A-403540FC6609.jpg C8BF4DAA-F35B-4717-8943-114FECF60473.jpg
    Just put this together. I want to install a led light under the hood, any suggestions?
    Prayn4surf, SwampYota and chrslefty like this.
  19. Jan 30, 2020 at 5:15 AM
    1997tacomav6
    Denver
    After thinking this over I’m thinking my truck will be fine with the OEM UCA.
    Any suggestions for the best replacement bushing for the OEM arm?
    Toyota only sells the complete arm with the bushing
    GQ7227, Blue92 and cruiserguy like this.
  20. Jan 30, 2020 at 5:46 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    A lot of people go whiteline, do they really not sell just the bushing?
    1997tacomav6[QUOTED] likes this.
