  1. Feb 2, 2020 at 5:21 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    noticed some bad vibes going on in the fuel door locking mechanism getting limpish so attempted some preventative maintenance, will see how well it holds up! have previously read issues with it on TW with breaking or whatnot
    i may have had some abrasive blast media find its way up in there while i was under the rear wheel well last fall having fun...
    that grit might have started sticking the coil that springs it back or other when you take the key out :notsure:
    flexed it all the way over to lube up well and good, sprayed, soaked and penetrated
    used this product, its not just for tight nuts!
    the black latch thing seemed to fully & properly retract without finger help as has been the recent routine at fillup after opening the door
    i even gently pushed the door close and locked easily, for the past few months I have been using the key to close and lock it since i read of this issue
    riskadverb likes this.
  2. Feb 2, 2020 at 5:29 PM
    Ace115
    Ace115 Well-Known Member
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    :der:
  3. Feb 2, 2020 at 7:10 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Lol awesome
  4. Feb 2, 2020 at 8:25 PM
    kuntry09
    kuntry09 Well-Known Member
    Cam
    Douglas, Georgia
    '99 extended cab Tacoma 4x4 converted Prerunner
    Does Wilco still have them in production for a 1st gen? Last time I looked at there website I don’t recall seeing them
    Area51Runner likes this.
  5. Feb 2, 2020 at 8:42 PM
    Ace115
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    I couldn’t tell you either way. This one was originally for a full size truck but the PO cut it down to fit a Ranger.
    kuntry09[QUOTED] likes this.
  6. Feb 2, 2020 at 8:42 PM
    eon_blue
    Azusa, CA
    They stopped making them. I had a similar one made locally by @GHOST SHIP, if you're ever out this way in SoCal or can work out a good shipping deal hit him up about one
    Ace115 likes this.
  7. Feb 2, 2020 at 8:59 PM
    kuntry09
    Cam
    Douglas, Georgia
    I thought that was the case. Good to know though, thanks!
    eon_blue[QUOTED] likes this.
  8. Feb 2, 2020 at 9:11 PM
    Ace115
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    Keep an eye on Craigslist and other resale sites. I saw a lot of them on there floating around for between 50$-250$ pending damage/work needed.
  9. Feb 2, 2020 at 9:32 PM
    1997tacomav6
    Denver
    So I put new rotors on my truck and the drives side wheel stud snapped off when taking the wheel off.
    I put the rotors on and had to order the wheel stud that snapped and was driving with 5 bolts with no issues with the new rotors.
    I got 6 new wheel studs two days later and decided to replace all of them.
    I used a big hammer to get the studs out
    The rotor was stuck on too after all the bolts were removed. Odd because it was just installed two days ago.
    Did I just mess up my front wheel hub and bend it by hammering out the bolts?
    And or bend my new rotor?
    Now my steering has a bad shake above 40 mph past 80 mph.
  10. Feb 2, 2020 at 9:50 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Finally finished the Relentless Fabrication bumper. 2 layers of self-etching primer, and 3 layers of Rusto Oil Based Enamel Black sprayed with my HVLP gun. Wired all the lights and the horns too.
    I’m running Rigid SAE Fog Lights, along with Feinex T3’s for the turn signals. My spot lights are KC HiLites 711 LED pods.
    Yeah, I know the other headlight is out. The Ballast and the switchback driver went out.
    I bought these aftermarket smoked corner lights, but the fitment is so atrocious I’m returning them.
  11. Feb 2, 2020 at 11:09 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Nice job!
  12. Feb 2, 2020 at 11:27 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Good job :thumbsup:
    Now you need to add a winch...:evil:
  13. Feb 2, 2020 at 11:29 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Yup, I’m going to need one to pull my wallet out of the deep pit that it’s in.
  14. Feb 2, 2020 at 11:30 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Oof
    Least you don't need a lot of pull strength, since the load is already light amirite
  15. Feb 3, 2020 at 5:38 AM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Sweet, looks great!
  16. Feb 3, 2020 at 5:46 AM
    TacoSauce04
    TacoSauce04 Well-Known Member
    David
    2004 Lunar Mist SR5 TRD Double Cab 4x4 Tow Package
    ARE Shell
    approx how much did the new windshield cost? I need to do this.
  17. Feb 3, 2020 at 5:51 AM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    $234.32
    Blue92 and TacoSauce04[QUOTED] like this.
  18. Feb 3, 2020 at 7:00 AM
    BeLance89
    BeLance89 Well-Known Member
    Brandon
    Huntsville, AL
    2002 White TRD double cab
    free.99 for me in Florida through insurance. No deductible or anything.
  19. Feb 3, 2020 at 7:00 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    You sure a winch will fit with those horns set up that way?
    Prayn4surf likes this.
  20. Feb 3, 2020 at 7:22 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    ...The sun now below the horizon, it was time to find camp. We considered for a moment the possibility of camping here at the Evening Star Mine, but the snow on the ground, and the mountains to the east - which would result in a shady morning - quickly had us searching for lower ground as the orange horizon gleamed before us...
    Oh, and there was a bit of an issue with our rear bumper that we dealt with, and an RV that we winched out of a wash. Fun day!
    The full story and tons of photos are in: Mojave Redemption #6 - Blue Rocks and a Dozen Cabins
    CS_AR, Area51Runner, Phessor and 2 others like this.
