  1. Feb 8, 2020 at 9:43 AM
    CoWj
    CoWj Lost and Found at the same time.
    Wyatt
    Northern CO
    Burt: 1998 2.7 Regular 5 speed 4x4
    Bilstein 5100, ARB Bumper, Warn VR EVO 8, 34x10.50 Toyo 4.88s ARB Locker
    What there a large elevation change going between KOH and home?
    JKO1998 likes this.
  2. Feb 8, 2020 at 10:06 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    That would be interesting
  3. Feb 8, 2020 at 10:09 AM
    CoWj
    Wyatt
    Northern CO
    I wonder if the vent on the breather is stuck and if he went down in elevation to KOH it adjusted to that pressure and driving back home it pressurized and pushed some fluid out the breather tube or vent.
  4. Feb 8, 2020 at 10:48 AM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    Modified an old FJ cruiser emblem and used two sided tape to keep it there.
    buckmaster243, JPinFL, jubei and 5 others like this.
  5. Feb 8, 2020 at 10:51 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    I always liked that logo. In my highschool machining class I made this keychain on the CNC machine.
    Id be wrecked if I ever lost it.
  6. Feb 8, 2020 at 11:19 AM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
  7. Feb 8, 2020 at 11:38 AM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    Usually overfilling is the cause. I Dont think elevation change might be a factor since its not a pressurized system. when mine barfed fluid all over the place it was due to toyota overfilling it, I also called my buddy who ownes a gear shop and he said sometimes oil hits the breather hose creating a vacuum and sucks fluid out. Never a fun thing to deal with. if just check the fluid level and keep an eye on it.
  8. Feb 8, 2020 at 11:49 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Mine pukes out the breather all the time. Worried me initially but everything seems fine. Just keep an eye on it and don't worry about it too much. My theory is that some oil gets trapped above an air bubble (for some reason) in the tube, and then as the air expands/warms, it pushes the oil out.
    I've thought about a catch can thingy on the line (I think @drr's done this), but in the end laziness and trips have taken priority...
    Edit: fun time at Hammers? Pics?
  9. Feb 8, 2020 at 12:39 PM
    Phessor
    Phessor Well-Known Member
    I have one of those! Thanks for giving me an idea how to use it.
    cruiserguy and Ritchie[QUOTED] like this.
  10. Feb 8, 2020 at 1:14 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Do you have a flex coupling in your exhaust somewhere? Just had mine apart and noticed how restrictive it is.
  11. Feb 8, 2020 at 1:43 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Where is the KOH located at?
  12. Feb 8, 2020 at 1:55 PM
    Yetimetchkangmi
    Benjamin
    Newcastle, WA
    As soon as I read this, it was a Duh moment for me...:anonymous:
    m3bassman[QUOTED] likes this.
  13. Feb 8, 2020 at 2:57 PM
    megalodon
    megalodon Well-Known Member
    FingerLakes Ny
    2003 v6 Ex.Cab
    Replaced the rear proportioning valve today on my very slow rust repair / other projects on the truck that I have ripped apart for the current winter season. I had been contemplating what todo with this thing since I had the bed off and have been soaking it in pb blaster for quite a few weeks while working on other projects on the truck. I was successfully able to break the brake lines free without breaking them off (which is always nice) but the bolts holding the valve to the bracket did not budge. So I pulled the bracket which the proportioning valve goes on off and zipped the bolts off on the backside of the bracket, then cleaned and re-painted things before putting everything back together.
  14. Feb 8, 2020 at 3:06 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    I do on the muffler side of the exhaust. I'm 3" and it's pretty far down line. Better than before. I used to merge into the oem exhaust flange
    Reh5108[QUOTED] likes this.
  15. Feb 8, 2020 at 3:40 PM
    Ritchie
    Cool... when I put it on the 1st time, I had it on the PS side of the tailgate.
    Then I viewed where they were on the FJ's... left side, hence the move.
    Post pics when you get yours on.
    Phessor[QUOTED] and cruiserguy like this.
  16. Feb 8, 2020 at 3:44 PM
    CoWj
    Wyatt
    Northern CO
    Found a big truck and parked my little truck next to it.
    BYJOSHCOOK, Kwikvette, jubei and 3 others like this.
  17. Feb 8, 2020 at 3:51 PM
    Natenite
    Natenite Well-Known Member
    Springfield Mo
    2003 Tacoma 4d TRD Radiant Red
    Ole Bessie Mae got a face lift today.
  18. Feb 8, 2020 at 4:28 PM
    millerder
    millerder Member
    2000 Tacoma
    Stock
  19. Feb 8, 2020 at 4:29 PM
    2002Tacoma4x4
    2002Tacoma4x4 TRD 4x4 double cab
    C K
    Limited Edition Double Cab TRD off road 4WD
    I notice a drop on MPG 147/9.11 gallons= 16.14 , then i checked air filter :boom:.... 36 k miles..holy :crapstorm:....
    $29 if i order at dealer,OEM ... nope.....went to Amazon then
    I choose 9 dollars one... fits great !:broccoli:
  20. Feb 8, 2020 at 4:52 PM
    millerder
    millerder Member
    2000 Tacoma
    Stock
    Hi there, the truck looks great. I have a 2000 Tacoma (one and only owner) and I am thinking of putting some larger tires on it, 16" or 17" and possibly a lift. What size wheels and tires are on yours and how much lift did you add? Also have you seen any impact in performance or mpg? I have not been able to find solid information as to what size wheels and tires will fit.... Thanks for any input!
