  1. Aug 22, 2012 at 4:20 PM
    04Tacomabuild
    04Tacomabuild Well-Known Member
    Reese
    Kenora, ON, Canada
    04 Tacoma TRD SR5 3.4l V6
    Toytec/Billistein coilovers, allpro leafs, OME greasable shackles, allpro ubolt flip kit, Billistein 5100's in rear.
    Nice cap! I believe i have the same on my truck. Had it for about two years now and its great!
  2. Aug 22, 2012 at 5:53 PM
    brannman
    brannman Well-Known Member
    Chesapeake, VA
    01 TRD
    new left front tierods. aligned, much better
  3. Aug 22, 2012 at 7:51 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    ian that smiley is awesome! And sucks to hear that your truck is leaking...from everywhere. Your taco might just be the most problematic 1st gen on this site! Way to ruin the reputation that tacos are indestructible.
  4. Aug 22, 2012 at 8:00 PM
    06texasedition
    06texasedition Well-Known Member
    Picayune ms
    06 Tacoma Texas edition(RIP) 14 tundra limited 4x4
    3" rough country lift. Blue interior lights courtesy of jumper led. Led tail lights avid front and rear bumper guard with 4 Hellas on front. Borla dual exhaust blue led reverse lights color matched satoshi grille
    That's freakn sweet
  5. Aug 22, 2012 at 8:34 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Noooo :eek: My truck is just getting old. Plus ive beaten the shit out of it in the last 2 years ive owned it. Everything is just at the point where it needs to be fix or replaced.
  6. Aug 22, 2012 at 8:37 PM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    Ok quick question guys, is it ok to cut downt he diameter of a wire (2 gauge) to make it fit inside one of them little prong things that go on the bolts of a battery?
    sorry if that doesnt make sense.
  7. Aug 22, 2012 at 8:45 PM
    Iceman2448
    Iceman2448 Well-Known Member
    Ga
    5100 OME 3" front lift 1.5 rear All Injen cold air Intake N-Fab light bar Hella 500FF lights Alpine Heand unit Type R 10 sub r500.1 amp Alpine 6x8 comps up front Alpine 6x9 in rear
    I wouldnt do it. It's a 2 gauge wire for a reason. Go to a audio shop a get a 2 gauge battery connecter
  8. Aug 22, 2012 at 8:47 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    Yea thats kinda what I thought lol Thanks man. 2 gauge should be ok up to about 100 amps right?
  9. Aug 22, 2012 at 9:14 PM
    Iceman2448
    Ga
    About 125. 3 gauge is 100 1/0 is 150!!
  10. Aug 22, 2012 at 9:22 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    sweet ill be good then. Thanks man I appreciate it
  11. Aug 22, 2012 at 9:25 PM
    Iceman2448
    Ga
    Np glad to help
  12. Aug 22, 2012 at 10:18 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    0/1 is like 300..or i thought..my Kicker 0 gauge amp kit came with a 300a fuse :eek:
  13. Aug 22, 2012 at 10:24 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Is fluid dripping off of it or are you just seeing a coating of oil on the outside case?
    Mine does the latter and I've read its kind of common. My friends '97 does the same thing. They never seem to leak enough to matter tho. At least mine doesn't.
  14. Aug 22, 2012 at 10:45 PM
    TacoJenn
    TacoJenn *~*
    Jennifer
    Houston, TX
    Campa shell, 5100s
    there's a coating of oil on the outside of the plate and I can see where it's getting thick and drops are starting to form (if that makes sense).. but I haven't seen anything on my driveway just some old spots. last time I used my 4x4 was in April up in the snow and it worked fine so I have no idea.....
  15. Aug 22, 2012 at 10:58 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    My transfer case looks like its leaking as well, but I can't seem to find any fresh oil or the source of it. Just looks wet around the seals.
  16. Aug 22, 2012 at 11:04 PM
    TacoJenn
    TacoJenn *~*
    Jennifer
    Houston, TX
    Campa shell, 5100s
    yeah I'm gonna clean it up tomorrow and see what happens if I can find where it's leaking from or if it's old
  17. Aug 23, 2012 at 12:11 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    everyone's t case must be just fucked. ill check mine and probably join the club:cool:
  18. Aug 23, 2012 at 5:43 AM
    Iceman2448
    Ga
    Okay. I mightt have been wrong. ImageUploadedByTapatalk1345725762.939531.jpg
  19. Aug 23, 2012 at 9:04 AM
    Digiratus
    Roaming the PNW
    The RedHead
    I sprayed mine up with brake clean to get all that oil off and have not seen it come back like it was. However, I haven't looked at it closely all summer. We'll see how it looks when I remove the BudBuilt belly pan in a few weeks to do my normal maintennence stuff. Probably change the t-case fluid at that time also.
  20. Aug 23, 2012 at 9:18 AM
    Jsimp
    Jsimp WV, VA, NC places i roam in the Yota
    Justin
    Winchester VA
    02 4runner
    E-Locker swapped! Limited swapppppp
    did a little wheelin with a buddy who received millions and lifted his chevy 6inch, nitto mud grapplers 37x17.5 and a lot more goodies. long story short he buried it and i came to the rescue in the Taco :yay: he was :crapstorm: for the rest of the night! here are some pictures from yesterday after out float down the james. the mud is still on the truck after it pouring 3 nights in a row on it.
