  1. Feb 17, 2020 at 9:19 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I have one. I don't trust that the Scangauge is showing the correct temperature and it's not an official supported feature and people "figured" out the settings and math equation.
    Also, the times I see these higher temps are sustained grades on the highways when the truck is struggling to keep speed and running the torque converter unlocked. So I manually turn off and on the overdrive very frequently.
  2. Feb 17, 2020 at 9:20 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Autos don't like heat, and there are some activities that generate quite a bit of it. At a previous job we had a bunch of gm 2500 suburbans and pickups. The suburbans were all 4l80e autos, the pickups were all 5 speed nv4500 manuals. 85% of their miles were in the mountains, on dirt roads, at about 15 mph. The autos would regularly be roasted at 40,000 mi, but we never had issues with the manuals.
    Moral of the story: it depends. I'm pretty sure slipping the torque converter a lot is no bueno though
    cruiserguy and Reh5108 like this.
  3. Feb 17, 2020 at 9:24 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Wtf???:eek::eek:
    Had no idea it was different, that's freaking cool dude :D
    Speedytech7 likes this.
  4. Feb 17, 2020 at 9:30 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Same here. (except I'm using the Torque Pro app)
    I do have a thermostat controlled trans cooler. The cooler fans kick on at 180°. The temp shown on my Torque app is normally pretty close to 180° when I hear the fans kick on.
    I wish there was a way (or I had the patients to find a way) to rig the overdrive to stay off unless I turn it on, instead of staying on until I turn it off.
  5. Feb 17, 2020 at 9:36 AM
    eon_blue
    Azusa, CA
    yeah I've been on more than a few trail runs with heavily armored and loaded up 2nd gens w/autos and have had to stop along a climb because someone's AT Temp light came on and they needed to cool down. We don't even have a temp light for the manual transmissions. Just keep it in 1st gear/4lo for 95% of the climb and you don't even need to worry about touching the clutch unless you come up on a bigger obstacle.
    jubei and 0xDEADBEEF[QUOTED] like this.
  6. Feb 17, 2020 at 9:45 AM
    Pyrifera
    Pyrifera Adventureswithdog.com
    Oregon
    '04 TRD 4x4, V6, 5-speed
    All nooks & crannies now upgraded with Dog Hair!
    I swear I have seen somewhere that somebody just smashed/squeezed the square metal box section down to make the opening that the nylon bar passes through smaller
    jonesbt and Gyrkin[QUOTED] like this.
  7. Feb 17, 2020 at 9:53 AM
    JasonLee
    15 TRD OffRoad
    I’m working on it. Also, a manual switch to keep the torque converter locked if I want to - this will also be helpful when the supercharger goes on.
    BeLance89 likes this.
  8. Feb 17, 2020 at 9:55 AM
    Running Board Man
    Running Board Man Well-Known Member
    Well what type of trans cooler do you have?
    I have the stacked plate type... those do a lot more vs the type that's just a tube that snakes around with some fins around it
  9. Feb 17, 2020 at 9:55 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    I’ve torn them apart before, people lose fingers trying to remove the magnets..
    The magnets are stupid strong. I have one on an stick for picking up metal on the fmoor
    cruiserguy[QUOTED] likes this.
  10. Feb 17, 2020 at 9:55 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    If the autos would put it in 4 low/ 2nd they wouldn’t have a problem.
    I had my light come on twice before some told me what I was doing wrong
  11. Feb 17, 2020 at 10:00 AM
    Running Board Man
    I havnt seen that light on either of my trucks... and thats because i was towing a 2wd through sand with my foot to the floor
    Doing that got the trans tunnel got pretty hot... thats what made me get a trans cooler
  12. Feb 17, 2020 at 10:03 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    You have 100% got to do a write up that shit!
    Those are 2 of the most important things I'd like to do to my truck... only I have no fucking idea how to do it.
  13. Feb 17, 2020 at 10:08 AM
    Running Board Man
    http://www.radesignsproducts.com/rail-controller.html
    all you need to do is press the button on the shifter unless you just dont like the light on the dash
  14. Feb 17, 2020 at 10:13 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    They're totally badass for hitting the power to efficiency curve because they lock the engine in the power band during acceleration. But unfortunately the design hinges on pushing (not pulling) a metal band between cone shaped pulleys (very similar to a snow machine trans) and they cannot handle much torque as a result, and they torque they do handle seems to be a tenuous arrangement, as failure rates if CVTs vs conventional autos are much higher. Some people just dislike them because it makes the engine sound as if the trans is slipping (but it isn't, it's just varying ratios to keep the RPM in the power band as speed increases), and others don't like that they can't feel shifts. The tried to make it so you feel shifts with the CVTs on Nissans and the life went down more because it made them jump ratios and wear the band. I think CVTs are really cool, at least in concept, who doesn't want a trans that makes super efficient use of all their power on the fly? But until they're reliable and can handle power they're useless to me.
  15. Feb 17, 2020 at 10:14 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I see people post numbers like that and I'm sorry, I don't believe it. Not saying you are lying, I'm saying I question the accuracy of the numbers you're getting.
  16. Feb 17, 2020 at 10:16 AM
    Running Board Man
    Understandable thats with stock sized tires
  17. Feb 17, 2020 at 10:16 AM
    Speedytech7
    You can kill power to the solenoid, it might throw a code but with a resistive bypass load on the other pole of your switch you can defeat that. It's not hard, these transmissions are stupid simple on the electrical side
    Running Board Man likes this.
  18. Feb 17, 2020 at 10:17 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I don't like the fact that I always have to remember to push the button.
    I would drive 80-90% of the time without the OD on... which means every damn time I get in the truck, I have to push that button.
  19. Feb 17, 2020 at 10:18 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Transmission+electrical=I have no fucking clue what you just said
  20. Feb 17, 2020 at 10:19 AM
    Running Board Man
