  1. Feb 29, 2020 at 6:28 AM
    megalodon
    megalodon Well-Known Member
    FingerLakes Ny
    2003 v6 Ex.Cab
    I'm a little jealous of the people who don't have to deal with rust, you're missing out on one of the joys of living in upstate NYS.
    Anyhow, while I'm messing with learning bodywork with the bed off to cut out / weld and paint. While these are easily accessible I've been taking things off which are pretty rusty (like my rear proportioning valve, spare tire brackets, etc) and trying to sand/refresh or replace it.
    I removed the rusted brackets, bent them a bit and stuffed a full size spare into the space. I think the distance from the exhaust is ok (what do you think?) my off road options here in Upstate NY are pretty limited so I think it's ok for the moment distance wise to the ground. have been thinking about a rear bumper replacement, may do the spare tire carrier that others have done to make it less of a pain to get to with cable hoist
    At some point in the future I may go with a different tire / rim combo but since the tread's ok on these I'll roll them for a bit.
    The Rear Tow hitch is next for assessing if it's to far gone to use, I think it's ok but I'll be wirebrushing /sanding that down, maybe beefing it up.
    and it seems that breaking off bolts instead of trying to save them is far faster.
    Grad school has slowed my progress on this project considerably...:turtleride:
  2. Feb 29, 2020 at 6:36 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I can't even count how many times I brought shit to friends with welders over the years. Pumped to not need to deal with that anymore.
  3. Feb 29, 2020 at 7:59 AM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    I put YJ springs and Toyota axles under my Samurai, I could not imagine the cost if I had to pay someone to do all the welding. A welder is for sure the best investment I have made for my offroading habit.
    Running Board Man likes this.
  4. Feb 29, 2020 at 8:06 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Thanks! It's made by Rawhide, I guess it's Canadian
  5. Feb 29, 2020 at 8:23 AM
    JBTacoma
    Jeff
    Cullman Alabama
    That is on my wish list.
  6. Feb 29, 2020 at 9:23 AM
    Dometic
    Dometic Well-Known Member Vendor
    2016 Tacoma
    :rofl:That would only hold three beers - definitely need a 100L CFX3 for a proper amount of around-the-fire evening beer!
    DOMETIC
    mobile living made easy
    shop.dometic.com
    Use promo code TacomaW20 for $25 off your order of $75+
    Shurban1227 and aknickyota22 like this.
  7. Feb 29, 2020 at 9:34 AM
    jonesbt
    jonesbt Well-Known Member
    Brett
    Monroe, La
    01 3.4L DC PreRunner—>4WD
    TRD Headers TRD Supercharger Custom Cavalry Blue Paint
    Don’t fab a bracket at all. That’s more work than necessary... especially if the seats in his truck now are pretty beat up(suggesting you me that the resale is already shot to hell).
    I removed the feet from my tacoma seats and welded them to the rails of my new seats. Simply bolt the makes taco fest into the floor pan and set the new seats on top of the rails. Line it all up and tack weld them in place. Remove from the truck and then weld it up solid. It’s super straight forward, but it definitely takes a bit of time to get everything all lined up and tacked on. You’ll have to do some prep work to ensure welding slag doesn’t burn any carpet while doing the initial tack welds in the truck. I didn’t care much during this step because I was replacing the carpet also. It would be a good idea to unbolt the center console and leave it sitting in place for the process of lining up the seats... then just move it out of the way for the tack welding.
    slander likes this.
  8. Feb 29, 2020 at 9:52 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    THAT sounds like a very good plan :thumbsup:
    Thanks for the info.
  9. Feb 29, 2020 at 10:27 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Well, this is what the old Neutral Safety Switch looked like.
    New one...
    Problem solved. Thanks to those who pointed it out. We had just replaced the auto shifter bushings and I was tunnel visioned in to thinking we were putting the shifter assembly back in wrong somehow. Must have just been coincidentally that the nuetral safety switch went out at the same time.
    SwampYota likes this.
  10. Feb 29, 2020 at 2:23 PM
    Robmonster117
    Robmonster117 Well-Known Member
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Turning a bad into a useful trail repair.
    Expensive ruined poly boots and some zip ties turned into a trail boot patch kit If I split a boot and need a quick fix on the go
    Taco critter, SwampYota and nagorb like this.
  11. Feb 29, 2020 at 2:48 PM
    seen20
    seen20 Well-Known Member
    Sean
    2000 3.4 Ext Cab 4x4 5-speed
    Adventure build
    Anybody know if 3rd gen 4runner 5100s will fit a Tacoma? Thought they were the same but they have different part numbers.
    I was going to order some for my 4runner but use them on the taco first while I rebuild my coilovers.
  12. Feb 29, 2020 at 2:55 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    do yourself a favor and add a piece of inch and a half pipe between bumper and spare tire cable hoist. Big help getting the handle in there, especially on a dark night.
  13. Feb 29, 2020 at 3:39 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Should be good to go
    seen20[QUOTED] likes this.
  14. Feb 29, 2020 at 3:46 PM
    JKO1998
    Utah
    I figured coilovers meant for the front.
  15. Feb 29, 2020 at 3:50 PM
    seen20
    Sean
    Adventure build
    @JKO1998 is right I only meant the fronts. Just wanted to throw em on while I get my SAW's rebuilt. I shoulda been more clear but I'm all set in the rear and yeah they have different style mounting points back there. Thanks guys!
    JKO1998 likes this.
  16. Feb 29, 2020 at 6:30 PM
    megalodon
    FingerLakes Ny
    2003 v6 Ex.Cab
    Thanks for the idea!
  17. Feb 29, 2020 at 6:39 PM
    TacoYankee
    TacoYankee Well-Known Member
    Spotsylvania, VA
    2024 Trailhunter
    Thanks for the link. Just picked one up!
    SellyKlater[QUOTED] likes this.
  18. Feb 29, 2020 at 6:52 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    :spending: because LeapDay
  19. Feb 29, 2020 at 10:07 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Going for a new look.
  20. Feb 29, 2020 at 10:08 PM
    tony2018
    tony2018 Well-Known Member
    parking my truck for a while, need to replace headers
    GQ7227 likes this.
