  1. Mar 8, 2020 at 7:52 PM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    Yeah halfway through the day my truck didnt wanna idle lol. I thought, well time to clean the maf and possibly the IAC, looks like I just cant stop and we laughed, then when i was airing up I saw it and said well looks like its not my maf or IAC but they may be a bit dirty now lol
  2. Mar 8, 2020 at 8:35 PM
    Prayn4surf
    Socal
    Fender skirts count for a lot :notsure:
    I have a feeling that mine has been cracked for a while and finally broke completely. But who knows.
  3. Mar 8, 2020 at 8:45 PM
    Pyrifera
    Pyrifera Adventureswithdog.com
    Oregon
    '04 TRD 4x4, V6, 5-speed
    All nooks & crannies now upgraded with Dog Hair!
    Good to know. I guess I'll let several thousand others be BETA testers and see what they come up with. There's also Deaver and those leafs with the number and letter name, something like J71 or whatever so...I have options :thumbsup:
    cruiserguy likes this.
  4. Mar 8, 2020 at 9:25 PM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    After pricing new ones, I fixed mine. I drilled holes in both parts and stitched it together with wire. I then used epoxy to seal the gap and holes. In hindsight I think calking would have worked better than the epoxy. The wire holds it together, the epoxy was just to seal it up. Anyway, my fix has held up for over three years so far.
    jubei, BYJOSHCOOK, cruiserguy and 5 others like this.
  5. Mar 8, 2020 at 9:51 PM
    Running Board Man
    Running Board Man Well-Known Member
    Maybe even riveting strips of aluminum inside so its less noticeable it would work as good if not better to secure it
  6. Mar 8, 2020 at 9:53 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Installed projectors mini morimotos into original headlight buckets - Thanks to @BlackPearl for technical support!!!
    Removed craptastic no-so-Champion aluminum radiator.
    Thing fought me tooth and nail to not get removed.
    Installed OEM radiator with new hoses upper and lower.
    cruiserguy, drr and Speedytech7 like this.
  7. Mar 8, 2020 at 10:24 PM
    Yetimetchkangmi
    Benjamin
    Newcastle, WA
    One more thing about the Champion rad:
    The petcock to drain the rad had no holes, so regardless of tightening or loosing - it didn't drain.
    Had to unscrew the petcock housing completely out of the rad.
    The petcock and it's mount are pointed to the rear on the passenger side.
    When it came off, the coolant came out like a fire hose.
    Luckily I anticipated this and used a liter bottle without a cap and pointed upside down with a hole cut to place over the petcock.
    I value it directed 65% coolant to the correct downward direction.
  8. Mar 9, 2020 at 6:10 AM
    bcrooms
    bcrooms Well-Known Member
    Brandon
    Georgia
    1999 Toyota Tacoma XCab 2.7L SR5 4WD
    How did you attach the '04 flares on your '00? Does your truck have the punch out holes on the fenders or did you attach them using 3M tape? I have a set of flares from an '01 that I'd like to try on my '99
  9. Mar 9, 2020 at 6:24 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    You can just use the existing holes in the wheel wells for the older flares, don’t need to clips in the fenders.
  10. Mar 9, 2020 at 6:26 AM
    bcrooms
    Brandon
    Georgia
    Did you have to add the protective rubber trim on the flares? I'll have to pick up some pins for the existing wheel well holes.
  11. Mar 9, 2020 at 6:29 AM
    JKO1998
    Utah
    I mean, I don’t think theyre required, but probably wouldn’t look very nice without them. You can buy them new from a dealer.
    You’ll need screws, they might already be there.
  12. Mar 9, 2020 at 8:24 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Washed the truck for the first time since I dunked it :D Was going on 4 months without a wash :anonymous:
    Pyrifera, cruiserguy, GQ7227 and 3 others like this.
  13. Mar 9, 2020 at 9:53 AM
    BlackPearl
    BlackPearl Well-Known Member
    Alex
    Toyota Tacoma TRD
    3” lift. Sway a ways 2.5 on 285 75 16 and much more
    Started the repair on my truck this weekend.
    70FA4DEE-4CF3-45A9-A3F5-27665723CEC5.jpg Also wife got me a gopro for my birthday. I've finally got around to making a YouTube channel and uploaded my first video. If any of you are interested to follow the repair progress make sure to subscribe. Hopefully will have truck back on the road in no time.
    https://youtu.be/2n6acPaUGl0
    jubei, kuntry09, JBTacoma and 6 others like this.
  14. Mar 9, 2020 at 10:54 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    Took the GF out for the weekend and had a great time up north.
    Truck didn't hiccup once, just want to lift it and get some new shocks all around soon
  15. Mar 9, 2020 at 10:59 AM
    Gyrkin
    Wyoming
    There are lots of ways you could do it. Just make sure anything you put on the inside is very secure. You don't want anything falling off and gong though your engine.
  16. Mar 9, 2020 at 1:08 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    1st rollout on the highway since the aquapel windshield treatment (2-22-20) in rain heavy enough that required intermittent wiper action :rain:
    was impressed with the action, barely had to use the wipers unless there was somebody spraying me from the front
    it looked like basic Freezing Drizzle pellets on the windshield rolling off, it is 35F here so maybe it was freezing drizzle idk, roads did not appear slippery so perhaps no
    .... in other news, more bs beef amongst the local 3rd gens & have to fend off :(
    getting the best of me
  17. Mar 9, 2020 at 1:33 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I'll feel better about wheeling next time; finally put on my skid plate since its been off ever since I put on my ARB
  18. Mar 9, 2020 at 1:37 PM
    eon_blue
    Azusa, CA
    what skid plate
    :luvya:
    Got my old Budbilt waiting for it's new owner when you make it down
  19. Mar 9, 2020 at 1:39 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    This one here
    :luvya:
  20. Mar 9, 2020 at 1:40 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Nice edit :rofl:
    eon_blue[QUOTED] likes this.
