  1. Mar 10, 2020 at 5:03 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    #manualhubproblems
    :p
    Running Board Man and JKO1998 like this.
  2. Mar 10, 2020 at 5:06 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    I feel for ya. Stuff like this is what makes me think I just may pay to have something like this done on a vehicle of mine smh, can't believe I'm saying that but... :oops:
  3. Mar 10, 2020 at 5:06 PM
    j4roe
    j4roe Well-Known Member
    Joe
    Phx, AZ
    1st Gen
    Solo Motorsports 3.5 with heimed tubular uppers, Total Chaos spindle gusset, King 8" CO, Glassworks 3'' front glass, tube bumper, 4 25w 1000L Bumper LED, 2 Rigid Pod lights, 35" Toyo Open Country AT, Fiberworx 3'' Bedsides, Deaver F55, Custom 9" Shackle, Bilstein 7100 14" 2.0 smooth body w/resi
    Thought you had a 6 lug. My bad. Not sure about that. I don't know anything about the 5 lugs...
  4. Mar 10, 2020 at 5:07 PM
    Squeaky Penguin
    Brett
    Did you weigh your truck? 250s sounds a little light if you're running a RTT/bedrack, camping gear, bumper, etc.
    Been happy with my Alcans. They're pricey but worth it when you get beyond what an off-the-shelf leaf pack can handle. Mine were finished exactly on the quoted time frame and came out exactly to the quoted specs.
    eon_blue[QUOTED] likes this.
  5. Mar 10, 2020 at 5:52 PM
    eon_blue
    Azusa, CA
    250# over stock carrying capacity was what Bob quoted me, the way I understood it was that would allow me to carry whatever the stock springs are normally rated for plus another 250lbs. I did give him my specs on the initial correspondence, RTT and a couple hundred lbs gear on a fully loaded trip, but day to day I don't really carry any weight with the RTT off.
    Im starting to think I should double check that with him, I'll give them a call tomorrow to verify. Definitely don't want to be on the bump stops with a loaded truck
  6. Mar 10, 2020 at 5:57 PM
    eon_blue
    Azusa, CA
    Oh also, did you have any trouble with the springs forcing your rear axle backward an inch or so? Was pointed out to me today that Dan ran into that issue with his and had to get a corrective spring made from Alcan to move it forward again
  7. Mar 10, 2020 at 6:00 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    200# over stock covers the 900# I carry around in bed regularly fine, truck sits about level anyway.
    They did a good job, be interesting to see what happens if they sell.
    eon_blue likes this.
  8. Mar 10, 2020 at 6:02 PM
    Squeaky Penguin
    Brett
    Does anyone have the part numbers for the studs/hardware between an elocker 3rd to the housing? Having a hard time finding them an any exploded views.
    I would load your rig up as you would use it on a trip, and go weigh it. That's going to give you the best answer.
    YMMV, but I would want them built to handle the weight carried when wheeling, and if they ride a little rough on the street so be it.
    No. I even measured the front eye to center pin between my old pack to compare.
    IMO, I think @turbodb 's orignal springs were fine, and he should have just trimmed a little bit to clear his bigger tires. :stirthepot: It may have solved his issue, but the original springs weren't the problem.
    jubei and eon_blue[QUOTED] like this.
  9. Mar 10, 2020 at 6:03 PM
    eon_blue
    Azusa, CA
    That's right I remember you telling me that yours was 200... I think I should be good at 250, maybe even a little stiff unloaded but I'd rather that than have a saggy arse loaded down
    Going to call him up tomorrow anyway just to double check
  10. Mar 10, 2020 at 6:06 PM
    JKO1998
    Utah
    Mine are rough as hell when empty, my spacer lift really compliments them.
  11. Mar 10, 2020 at 6:10 PM
    eon_blue
    Azusa, CA
    When the hell did you get a spacer lift
    I'm used to rough when unloaded, the Expos have familiarized me with that. Can't have it both ways I guess
  12. Mar 10, 2020 at 6:12 PM
    JKO1998
    Utah
    When I ditched my kings in 2018 :anonymous:
  13. Mar 10, 2020 at 7:39 PM
    04doublecab
    04doublecab Well-Known Member
    Jeff
    2004 Tacoma
    Nice! We have some spots we go to up off the 260 not quite to the beeline. Also been up off 300 road but it's too busy up there.
    Das it mang[QUOTED] likes this.
  14. Mar 10, 2020 at 7:44 PM
    04doublecab
    Jeff
    2004 Tacoma
    I used some clips from under the front bumper off a camry or Corolla.
    chrslefty[QUOTED] likes this.
  15. Mar 10, 2020 at 7:48 PM
    jdmstuff
    jdmstuff Well-Known Member
    Derrick
    Torrance, CA and Las Vegas, NV
    '18 TRD OR DCSB AT, '08 TRD Sport DCSB AT, '03 TRD 3.4l 4x4 MT Supercharged
    Installed a set of Spyder LED taillights. Not sure if I like them over the 01-04 stocks yet.
    Bhakti, megalodon, BYJOSHCOOK and 3 others like this.
  16. Mar 10, 2020 at 7:58 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Deavers start at $900 a set
    Usually that's only an issue with 01-04s from what I've seen, especially double cabs.
    I had pretty sever rubbing with my alcans on Igor. Nothing the plates didn't fix for me though.
    eon_blue[QUOTED] and turbodb like this.
  17. Mar 10, 2020 at 8:28 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Curious what you think the issue was then?
    I mean, I've seen it with other trucks as well - Monte even mentioned it with Igor. And they sell the plates, so it has to be pretty common...
    Here are two pics I took on the same day, before/after.
    Before - clearly the axle is not centered in the before (though, I admit that the distance to the center pin on the before is the same as on the stock leaf pack - 24 1/8").
    After (much more centered - distance is 23 3/8" to center pin)
    Monte @Blackdawg - did you talk to Bill about him selling the business (and did he confirm that)? Or just about ordering a pack? I'm wondering if I should order another pack for when mine eventually goes; I do like these springs...
  18. Mar 10, 2020 at 8:37 PM
    Squeaky Penguin
    Brett
    I think my point is that they came with the same measurement as stock, and you moved it forward, and that not centered is not a problem.
    Also, I had to trim the front of my rear wheels wells even with the longer measurement. If I had to cut another inch out I wouldn't have any flare left there.
  19. Mar 10, 2020 at 8:38 PM
    jacobrippey
    jacobrippey It’s always Taco Tuesday Instagram #rippstik
    Jacob
    Surprise, Arizona. USA
    2004 Tacoma DC 4wd
    Find me on Instagram: @rippstik
    Added 01-04 Door Panels to my 1995.5.
  20. Mar 10, 2020 at 8:52 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Im on Amazon trying to find door clips. My damn drivers side sounds looser than a sacramento whore. Any body have a link...to the clips, not the whore
    Silver02Taco and chrslefty like this.
