  1. Mar 10, 2020 at 8:53 PM
    jacobrippey
    jacobrippey It’s always Taco Tuesday Instagram #rippstik
    Jacob
    Surprise, Arizona. USA
    2004 Tacoma DC 4wd
    Find me on Instagram: @rippstik
    Door clips being the ones that go from the door panel into the door frame?
    Fernando[QUOTED] likes this.
  2. Mar 10, 2020 at 8:55 PM
    jacobrippey
    Jacob
    2004 Tacoma DC 4wd
  3. Mar 10, 2020 at 9:07 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    No just about springs.
    Not sure what would happen if they sold but deaver is still an option if something bad happened anyways.
    turbodb[QUOTED] likes this.
  4. Mar 10, 2020 at 9:14 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
  5. Mar 10, 2020 at 9:17 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
  6. Mar 10, 2020 at 9:26 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Are you going to do the mod where the bottom studs become bolts so that you can drain the diff via that and weld up the drain plug that gets trashed from rocks?
    My Alcans seem to be centered just fine. I think I could have gone slightly heavier. I liked how stiff they were when first installed. It was easy to slide the rear around corners. Now they give and the truck just rolls. @Squeaky Penguin didn't we get the same spring rate? I think I have ~500lbs on you.
  7. Mar 10, 2020 at 9:29 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Yes. Planning on shaving the drain plug. Need to do some reading on the proper way to do that. I still need the studs as my new used housing is missing most of them, and would rather just get news ones vs. swapping them from my current housing.
    And yes, same spring rate at 1k over. I think I should have gone 800lbs maybe. Either way, I can still easily get into the bumps.
    Reh5108[QUOTED] likes this.
  8. Mar 10, 2020 at 9:31 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I had that problem with my double cab when I put on OME Dakar leaf springs. The All-Pro relocation plate set at 3/4" shifted to the rear fixed my alignment.
    BeLance89 and eon_blue[QUOTED] like this.
  9. Mar 10, 2020 at 9:34 PM
    jacobrippey
    Jacob
    2004 Tacoma DC 4wd
    They should work!
  10. Mar 10, 2020 at 9:49 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Speaking of leaf springs, what's the consensus on re-using U-bolts?
    I've seen a good amount of people online say that you shouldn't re-use u-bolts after re-installing them a few times.
    Outside of obviously checking them after 100 & 500 miles for proper torque, not sure if it's really necessary on these trucks.
    Sure they should be replaced if the threads get boogered up, but otherwise :notsure:
  11. Mar 10, 2020 at 9:57 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Likely need replaced every so often. Mine have gotten wore down and tweaked in the past. They stretch a good amount so Id replace them every set of new springs at the very least.
    Digiratus likes this.
  12. Mar 10, 2020 at 10:00 PM
    betterbuckleup
    Ian
    Concord, CA
    I ordered a new set just to be safe.
    I removed & installed my current set like 3 times this last week when I was messing with my relocation plates.
    I'll put the new ones on when I install some better bumpstops back there.
  13. Mar 10, 2020 at 10:04 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    for something like that, I wouldn't worry. But after a couple seasons of hard miles, they can get sketchy.
    unless your bumps require a longer one than your current ubolts then its a good idea.
  14. Mar 10, 2020 at 11:25 PM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
  15. Mar 11, 2020 at 12:05 AM
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    Thanks I'll look into that.
  16. Mar 11, 2020 at 7:07 AM
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
    Not to sound dumb. What's Cpomilwaukee.com? I've seen the site come up through Google searches.
    Is it owned by Milwaukee or authorized reseller for new and refurbished tools?
  17. Mar 11, 2020 at 7:10 AM
    Venom
    Kevin
    Massachusetts
    Thanks for the reply!
  18. Mar 11, 2020 at 7:55 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    As far as I know it must just be an authorized reseller of their refurb/return stuff and of course the new stuff. I've only purchased refurb from them
    Venom[QUOTED] likes this.
  19. Mar 11, 2020 at 8:09 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    You are right... not sure what, exactly, cpo stands for, but I've bought a bunch of stuff from cpo-bosch in the past. It was all certified refurbished... some of it was even just simply resold return items that were good as new.
    Venom likes this.
  20. Mar 11, 2020 at 8:17 AM
    cruiserguy
    Elijah
    SEKS
    CPO and I only know it from working at a dealership service department years back but CPO is 'Certified Pre-Owned' at least that's what it means in the car business, I just assumed the same here
    Venom likes this.
