  1. Mar 13, 2020 at 5:16 PM
    BenCO
    BenCO Well-Known Member
    CO
    04 Tacoma DC 4x4
    I offered mine up for free about 2 weeks ago!
    six5crèéd[QUOTED] likes this.
  2. Mar 13, 2020 at 5:19 PM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    And I thought this one was cheap :rofl:
  3. Mar 13, 2020 at 5:50 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    good looking truck man!
  4. Mar 13, 2020 at 6:53 PM
    ireymon
    ireymon Unknown Member
    Kenneth
    Winston-Salem, NC
    99 X-Cab 5 lug 5 speed
    Hyundai wheels, dings & dents...
    How much?? If I buy some too, does 2 people count as a group buy and we can get a discount?
    Link worked perfectly. I think it sounds good! Is it just the vid (EDIT: or my cheap ass headphones) or does it sound pretty close to stock? Maybe just a bit more good-er.
    cruiserguy likes this.
  5. Mar 13, 2020 at 7:13 PM
    2Runner
    2Runner Well-Known Member
    Scott
    So Cal
    2002 Regular Cab 2.4L MT 2WD
    $398.60 for the pair of custom made Deaver front springs painted black, and the final rate was 368 pounds and a 2.65" drop from stock. This rate was 25% above stock (295) based on input from the engineers so I was close with my original thoughts. They considered my goals (high performance handling yet maintain street manners) and other mods I had planned (thicker front sway bar, rear sway bar, and will be lowering the rear more than the front). So the truck should be handling like a Ferrari but riding like a Cadillac, ok maybe I am exaggerating just a tad! ;)
    I can ask next time I speak to the Deaver guy but I doubt two pairs would warrant much of a discount.. Plus, your extra cab would not get the same drop or rate as my regular cab.. sorry I ruined your dream of discounts, but ordering a set to suit your own needs would be even better!!
    The Borla is definitely a bit louder than stock with a meaner lower grumble, but no where near too loud to enjoy the ride for prolonged journeys. And there is no more trace of the "drone" sound I was getting in the cab at extended higher rpm's such as when passing on the freeway vs my leaky Flowmaster. I think it's a perfect balance of some fun sound without being annoying and actually dont think I will be installing the OEM muffler I had picked up at the yard just in case!!
    Even the wife admitted it sounded good, and she wasn't really hopping on the custom muffler band wagon when I first told her my plan! :D
  6. Mar 13, 2020 at 8:14 PM
    kuntry09
    kuntry09 Well-Known Member
    Cam
    Douglas, Georgia
    '99 extended cab Tacoma 4x4 converted Prerunner
    Could anyone help me with driveline angles? I’ve had a vibration ever since I installed a set of wheelers 8 packs. I know it’s in the driveline, anytime I add or take away a shim it will get better/worse but I haven’t been able to get it correct. I’ve read through the thread in the 2nd gen forum, I’m not sure if I’m measuring angles wrong, trying to line up the wrong angles, or not understanding any of it at all.
  7. Mar 13, 2020 at 8:47 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    There are some pretty good resources out there, depending on how much you want to nerd out about the geometry and physics involved. Tom Woods is something of an authority on the issue, and has some good reads on his website that are worth checking out:
    https://4xshaft.com/blogs/general-tech-info-articles/tail-shaft-conversion-kits
    What it boils down to is that for any angle in a u joint, there has to be an opposing angle that "cancels" it out. The u joint at the transfer case doesn't have an opposing u joint, since the center bearing is fixed in the middle of the shaft (which is why lowering the center bearing is not a good idea, since it induces an "un-cancelled" angle in the u joint at the transfer case). The double cardan just after the center bearing is self-cancelling, since there are two u joints riding on a centering ball. And finally there is the u joint at the differential pinion.
    When you lift your truck, the center bearing goes up and the differential stays in the same spot, which increases the angle in that pinion u joint. That can cause vibrations, and with a "CV" driveshaft, as Tom Woods calls it, the best way to set up the driveline for no vibrations is to point the differential pinion at the center bearing, which effectively takes all the angle out of the pinion u joint. In reality, you want to point the pinion about 1-2 degrees below the center bearing, so that during acceleration when the pinion lifts up it doesn't try to grenade the u joint. That slight angle also allows the needle bearings in the u joint to rotate like they're supposed to and will prolong their life.
    For our trucks, if you're not planning on cutting off your spring perches and rotating the axle housing, anything that's lifted in the 2"-3" range will need roughly a 3 degree shim under the leaf packs to point the pinion in the proper direction (thick part of the shim to the rear). You can get shims made by 4Crawler, which worked great for me:
    https://www.4crawler.com/4x4/ForSale/Shims.shtml#CustomWidthShim
  8. Mar 13, 2020 at 9:52 PM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    https://www.youtube.com/watch?v=f1m-Fh5kiRU&feature=emb_logo
    BeLance89 and Yetimetchkangmi like this.
  9. Mar 13, 2020 at 11:54 PM
    jdmstuff
    jdmstuff Well-Known Member
    Derrick
    Torrance, CA and Las Vegas, NV
    '18 TRD OR DCSB AT, '08 TRD Sport DCSB AT, '03 TRD 3.4l 4x4 MT Supercharged
    Picked up a pair of these today. Going to replace my Sparcos tomorrow afternoon.
  10. Mar 14, 2020 at 6:04 AM
    Hooks98tacoma
    Hooks98tacoma Well-Known Member
    Georgia
    98 Tacoma 2.4
    Lemme get them sparcos
  11. Mar 14, 2020 at 6:51 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    How do you like that Milwaukee rotary tool(dremel)? I've had it in my Amazon cart, but some of those reviews man, it sounds like there's a bearing or bushing that's lacking or something on it? You ever have an issue or complaint?
    OneWheelPeel likes this.
  12. Mar 14, 2020 at 9:48 AM
    Pyrifera
    Pyrifera Adventureswithdog.com
    Oregon
    '04 TRD 4x4, V6, 5-speed
    All nooks & crannies now upgraded with Dog Hair!
  13. Mar 14, 2020 at 10:27 AM
    Pyrifera
    Oregon
    Something like that is on the list to add to one swingout on my Aluminess rear. Am interested to see the details after you do your 2nd version. Hopefully you do a write-up :boink:
    nagorb[QUOTED] likes this.
  14. Mar 14, 2020 at 12:13 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 410K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    When I squirt water on this area of the injector (installed these about two months ago) the water doesn't bead up around the injector like I would expect it to, instead it seems to get sucked into the intake. I followed the instructions for installation and I just don't have a tight enough seal, any ideas? When I twist the injector side to side it moves smoothly with little resistance.
  15. Mar 14, 2020 at 12:30 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Are these OEM?
  16. Mar 14, 2020 at 12:31 PM
    Phessor
    Phessor Well-Known Member
    I did this today.
    And this!
    2ndToy, Bhakti, xtremewlr and 9 others like this.
  17. Mar 14, 2020 at 1:37 PM
    Kiloyard
    Phoenix, AZ
    No they are from MotorWest. They came highly recommended, but I'm going to pull them out and inspect them for problems. I still have my originals in case I run into an issue.
  18. Mar 14, 2020 at 2:51 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    I might try to do that, though who knows when I'll get around to v2. Took me a year from the time I cut the table to installing it...
    Here's some pics, eventually it will be all stainless hardware and some sort of latch, but the wing nut works well for now. The upright in the right is where my Jerry can mount bolts to, eventually I'll cut it off and have it bolt on and have another mount for the Jerry can mount.
  19. Mar 14, 2020 at 3:59 PM
    lightnfast
    lightnfast Well-Known Member
    PDX
    2001 TRD SR5 XCLB
    Stuff and things
    That’s awesome. My seats are suuuuch garbage. Post a pic of them mounted up!
  20. Mar 14, 2020 at 4:00 PM
    lightnfast
    PDX
    2001 TRD SR5 XCLB
    Stuff and things
    Pinch weld mod done. Bashed it good. Still rub a teensy bit with 285s :mad:
    03_taco_IN likes this.
